I have a problem with the NvVideoConverter on the Jetson AGX Xavier.
JetPack 4.5.1 : nvidia-l4t-jetson-multimedia-api_32.5.1-20210219084708_arm64
R32 (release), REVISION: 5.1, GCID: 27362550, BOARD: t186ref, EABI: aarch64, DATE: Wed May 19 18:16:00 UTC 2021
It seems that some pixels of my image are becoming 0 once converted to another format.
To simplify the problem to the maximum I convert the format of my image from V4L2_PIX_FMT_UYVY to V4L2_PIX_FMT_UYVY, and yet the artifacts are still appearing. As you can see on the pictures below:
Here is my code without error handling.
m_inPixFmt = m_outPixFmt = V4L2_PIX_FMT_UYVY;
m_width = 1456;
m_height = 1088;
m_conv = NvVideoConverter::createVideoConverter("conv0");
m_conv->setOutputPlaneFormat(m_inPixFmt, m_width, m_height, V4L2_NV_BUFFER_LAYOUT_PITCH);
m_conv->setCapturePlaneFormat(m_outPixFmt, m_width, m_height, V4L2_NV_BUFFER_LAYOUT_PITCH);
m_conv->output_plane.setupPlane(V4L2_MEMORY_MMAP, m_outputPlaneBufferNbr, true, false);
m_conv->capture_plane.setupPlane(V4L2_MEMORY_MMAP, m_capturePlaneBufferNbr, true, false);
m_conv->output_plane.setStreamStatus(true);
m_conv->capture_plane.setStreamStatus(true);
m_conv->capture_plane.setDQThreadCallback(capturePlaneCallback);
m_conv->capture_plane.startDQThread(this);
m_conv->output_plane.setDQThreadCallback(outputPlaneCallback);
m_conv->output_plane.startDQThread(this);
// Enqueue all the empty capture plane buffers.
for (uint32_t buffer_idx = 0; buffer_idx < m_conv->capture_plane.getNumBuffers(); buffer_idx++)
queueOutputBuffer(buffer_idx); // Queue capture plane buffers (output of the converter)
Then to write on the output plane buffer (input buffer of the converter)
I get the list of output plane buffers.
for(int bufferIndex = 0; bufferIndex < nBuffers; bufferIndex++)
NvBuffer *pBuffer = inputBuffers[bufferIndex];
VmbUchar_t *pMemory = pBuffer->planes[0].data;
VmbInt64_t nBufferSize = pBuffer->planes[0].length;
pBuffer->planes[0].bytesused = 3168256; // payload size of my image (width * height * 2 bytes per pixel)
And I write the image into my pMemory pointer.
My end goal is to convert the image into other format V4L2_PIX_FMT_YUV420M, but it has the same issue.
Also I use the same method to save the bmp file from the capture_plane.buffers.planes[0].data. So I’m pretty sure the issue is from the converter. I do it in the callback “capturePlaneCallback”.
Thank you in advance for your answers.
