Hello!
I see tegra_multimedia_api/samples/common/classes/NvVideoEncoder.cpp and I have question
int
NvVideoEncoder::setOutputPlaneFormat(uint32_t pixfmt, uint32_t width,
uint32_t height)
struct v4l2_format format;
uint32_t num_bufferplanes;
NvBuffer::NvBufferPlaneFormat planefmts[MAX_PLANES];
if (pixfmt != V4L2_PIX_FMT_YUV420M && pixfmt != V4L2_PIX_FMT_YUV444M &&
pixfmt != V4L2_PIX_FMT_P010M)
NvVideoEncoder::setCapturePlaneFormat(uint32_t pixfmt, uint32_t width,
uint32_t height, uint32_t sizeimage)
memset(&format, 0, sizeof(struct v4l2_format));
format.type = V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE;
switch (pixfmt)
case V4L2_PIX_FMT_H264:
case V4L2_PIX_FMT_H265:
case V4L2_PIX_FMT_VP8:
case V4L2_PIX_FMT_VP9:
According to this code capture plane format is a encoder output, output plane format is encoder input, right?
But at same time setFrameRate() apply parameters to output plane, but if it encoder input this configure sensor framerate? So I can’t capture from sensor 60 fps and encode 30 fps?
Thank you.
