I have the same error with this small piece if test code:
make test
pgf90 -g -Mcuda -Minfo -c precision_m.F90
pgf90 -g -Mcuda -Minfo -c test_host_gen.CUF
pgf90 -g -Mcuda -Minfo -c test_global.CUF
nvvmCompileProgram error: 9.
Error: /tmp/pgcudaforf6KgpUvKTkXq.gpu (19, 0): parse error: global variable reference must have pointer type
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (test_global.CUF: 1)
PGF90/x86-64 Linux 14.10-0: compilation aborted
make: *** [test_global.o] Error 2
module precision_m
integer , parameter :: singlePrecision = kind (0.0)
integer , parameter :: doublePrecision = kind (0.0d0)
! Comment out one of the lines below
integer , parameter :: fp_kind = singlePrecision
!integer , parameter :: fp_kind = doublePrecision
integer , parameter :: hb_kind = doublePrecision
end module precision_m
module test_host_gen
use precision_m
implicit none
real(fp_kind) , device :: D_M_he
real(fp_kind) :: M_he
contains
subroutine read_control_file(ctrl_file)
character(len=100) , intent(in) :: ctrl_file
character(len=100) :: buffer, label
integer :: pos , swch
integer, parameter :: fh = 15
integer :: ios = 0
integer :: line = 0
open(fh, file=ctrl_file)
do while (ios == 0)
read(fh, '(A)', iostat=ios) buffer
if (ios == 0) then
line = line + 1
! Find the first instance of whitespace. Split label and data.
pos = scan(buffer, ' ')
label = buffer(1:pos)
buffer = buffer(pos+1:)
select case (label)
case ('M_he')
read(buffer, *, iostat=ios) M_he
print *, 'Read Mass of Helium M_he : ', M_he
case default
print *, 'Skipping invalid label at line', line
end select
end if
end do
end subroutine read_control_file
end module test_host_gen
module test_global
use test_host_gen
contains
attributes(global) subroutine rnd12(rnd0)
integer , device :: is,js,ks,ns
real(fp_kind) , intent(out):: rnd0
save
mzran = is - ks
if (mzran .lt. 0) then
mzran = mzran + 2147483579
endif
is = js
js = ks
ks = mzran
ns = 69069*ns + 1013904243
mzran = mzran + ns
rnd0 = 0.5d0 + mzran/2.d0**32
end subroutine rnd12
end module test_global
program test
use test_global
implicit none
real(fp_kind) , device :: k_M_he , d_random
character(len=100) :: ctrl_file
real(fp_kind) :: tempo , random
integer :: tmp_int
ctrl_file = "input.txt"
rnd_file = "random.txt"
open(unit=1, file=name, iostat=ios, status="new", action="write")
if ( ios /= 0 ) stop "Error opening file name"
! test Random numbers
do i = 1 : 1000000
call rnd12<<<1,1>>>(d_random)
random = d_random
write(1,*) random
enddo
end program test
Compiler:
pgf90 14.10-0 64-bit target on x86-64 Linux -tp istanbul
The Portland Group - PGI Compilers and Tools
Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved.
