Hi all,
We have used nx production board on our carrier board.
Some time boot successfully, however some times we find it is hung on:
boot_fail.log (33.0 KB)
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (git@CI_Server) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon1
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069a000
��WARNING: pll_d2 has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 3.264186] cgroup: cgroup2: unknown option "nsdelegate"
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 4.637153] random: crng init done
[ 4.637296] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.793541] esw_tca6408_drv: loading out-of-tree module taints kernel.
[ 4.817400] using random self ethernet address
[ 4.817561] using random host ethernet address
[ 5.283898] lt6911uxc 0-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 5.284814] lt6911uxc 0-002b: mclk absent,assuming sensor driven externally
[ 5.289526] lt6911uxc 0-002b: detected lt6911uxc sensor
[ 5.290435] lt6911uxc 1-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 5.291128] lt6911uxc 1-002b: mclk absent,assuming sensor driven externally
[ 5.292293] lt6911uxc 1-002b: couldn't create debugfs
[ 5.296242] lt6911uxc 1-002b: detected lt6911uxc sensor
[ 5.296763] lt6911uxc 8-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[ 5.296999] lt6911uxc 8-002b: mclk absent,assuming sensor driven externally
[ 5.303768] lt6911uxc 8-002b: couldn't create debugfs
[ 5.329829] lt6911uxc 8-002b: detected lt6911uxc sensor
[ 5.468199] using random self ethernet address
[ 5.468367] using random host ethernet address
[ 5.477973] Bridge firewalling registered
[ 6.748280] Unable to handle kernel NULL pointer dereference at virtual address 0000011f
[ 6.748533] Mem abort info:
[ 6.749685] ESR = 0x96000005
[ 6.749811] Exception class = DABT (current EL), IL = 32 bits
[ 6.749982] SET = 0, FnV = 0
[ 6.750072] EA = 0, S1PTW = 0
[ 6.750161] Data abort info:
[ 6.750250] ISV = 0, ISS = 0x00000005
[ 6.750357] CM = 0, WnR = 0
[ 6.750443] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc1dfd14000
[ 6.751174] [000000000000011f] *pgd=0000000000000000, *pud=0000000000000000
[ 6.751464] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 6.751636] Modules linked in: cp210x zram esw_bd(O) esw_okr(O) br_netfilter esw_lt6911gpio5_drv(O) overlay esw_lt6911uxc_drv(O) at24 esw_tca6408_drv(O) spidev userspace_alert nvgpu bluedroid_pm ip_tas
[ 6.752389] CPU: 2 PID: 3541 Comm: systemd-udevd Tainted: G O 4.9.201-tegra #1
[ 6.752392] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 6.752397] task: ffffffc1db120000 task.stack: ffffffc1dc86c000
[ 6.752412] PC is at kernfs_find_ns+0x60/0x110
[ 6.752417] LR is at kernfs_find_ns+0x54/0x110
[ 6.752421] pc : [<ffffff80082f0be0>] lr : [<ffffff80082f0bd4>] pstate: 80400145
[ 6.752423] sp : ffffffc1dc86fb70
[ 6.752431] x29: ffffffc1dc86fb70 x28: ffffffc1db120000
[ 6.752438] x27: ffffff8008f72000 x26: 0000000000000000
[ 6.752445] x25: ffffffc1dc86fd48 x24: 0000000000004000
[ 6.752452] x23: ffffffc1cae20638 x22: 0000000000000000
[ 6.752459] x21: 0000000024644567 x20: 00000000000000e7
[ 6.752465] x19: 00000000000000ff x18: 0000000000000000
[ 6.752472] x17: 0000007fb3c965c0 x16: ffffff8008262ae8
[ 6.752479] x15: 0000000000000010 x14: 0000000000000015
[ 6.752485] x13: 0000000000000000 x12: 0000000000000030
[ 6.752492] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 6.752510] x9 : feff716475687163 x8 : ffffffffffffffff
[ 6.752520] x7 : fefefefefefefefe x6 : 0000000000008080
[ 6.752527] x5 : 0000000000000000 x4 : ffffffffffffffff
[ 6.752534] x3 : 0000000000000007 x2 : ffffffc1cae2063e
[ 6.752540] x1 : 000000007ffffffe x0 : 0000000024acbac5
[ 6.752542]
[ 6.752546] Process systemd-udevd (pid: 3541, stack limit = 0xffffffc1dc86c000)
[ 6.752549] Call trace:
[ 6.752556] [<ffffff80082f0be0>] kernfs_find_ns+0x60/0x110
[ 6.752564] [<ffffff80082f0d50>] kernfs_iop_lookup+0x58/0xd0
[ 6.752579] [<ffffff80082686e8>] lookup_slow+0x98/0x160
[ 6.752585] [<ffffff800826bee8>] walk_component+0x1b8/0x2f8
[ 6.752590] [<ffffff800826c664>] path_lookupat+0x9c/0x148
[ 6.752596] [<ffffff800826e7d8>] filename_lookup+0x88/0x150
[ 6.752601] [<ffffff800826e9b8>] user_path_at_empty+0x58/0x70
[ 6.752606] [<ffffff8008262b48>] SyS_readlinkat+0x60/0x170
[ 6.752613] [<ffffff800808395c>] __sys_trace_return+0x0/0x4
[ 6.752619] ---[ end trace 522ac2d007d32a81 ]---
[ 6.810632] usb 1-3.2.4: new low-speed USB device number 17 using tegra-xusb
[ 6.840383] usb 1-3.2.4: New USB device found, idVendor=04f2, idProduct=1516
[ 6.840390] usb 1-3.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.840394] usb 1-3.2.4: Product: USB Keyboard
[ 6.840397] usb 1-3.2.4: Manufacturer: Chicony
[ 8.731900] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.735682] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.634866] FAN rising trip_level:4 cur_temp:66800 trip_temps[5]:140000
[ 34.138675] vdd-sdmmc1-sw: disabling
[ 34.141472] vdd-1v8-sd: disabling
[ 34.144169] vdd-1v8-cvb: disabling
[ 34.146264] vdd-epb-1v0: disabling
[ 34.148327] avdd-cam-2v8: disabling
[ 34.150368] vdd-fan: disabling
[ 34.152435] vdd_sys_en: disabling
Do you have any ideas?
