Hello, I’m trying to do image processing and object detection from Jetson Nano. For example, I want to detect the letters A, B, C, D, F. How can I do this? Is there a study on this subject or a resource you can recommend?
I’m moving this issue to Jetson Nano category for resolution.
We do have an example for scene text recognition.
Does it meet your requirement?
I cloned the file you sent and tried to install it, but it gives a lot of errors, the libraries are not installed.
Which JetPack do you use?
It seems that the repository is built with JetPack 4.6
We have tested the repository on Jetson+JetPack4.6.
It can work with some updates. Please find the details below:
1. Prerequisites
$ sudo apt-get install gfortran libopenblas-dev liblapack-dev
$ sudo pip3 install scikit-build
2. Cloning the repo
$ git clone https://github.com/NVIDIA-AI-IOT/scene-text-recognition.git
$ cd scene-text-recognition/
$ git submodule update --init --recursive
scene.patch (274 Bytes)
$ mv {scene.patch} .
$ git apply scene.patch
easyocr.patch (956 Bytes)
$ cd EasyOCR/
$ mv {easyocr.patch} .
$ git apply easyocr.patch
3. Install pytorch, torchvision
$ wget https://raw.githubusercontent.com/tomek-l/jetson-install-pytorch/master/install_torch_v1.9.sh
$ sed -i 's/# install_torch/install_torch/g' install_torch_v1.9.sh
$ bash install_torch_v1.9.sh
$ pip3 install -r requirements.txt
4. Install torch2trt
$ cd torch2trt
$ sudo python3 setup.py install --plugins
$ cd ..
5. Install EasyOCR
$ cd EasyOCR
6. Testing
$ python3 easy_ocr_demo.py /home/nvidia/scene-text-recognition/docs/images/
