New MLNX_OFED version will support OL 8.9 ?
Since our Oracle RAC will be running on Oracle Linux 8.9, it’s great that MLNX_OFED is supported. Or can we compile it ourselves to make MLNX_OFED support Oracle 8.9?
Unfortunately, MLNX_OFED latest release (and upcoming release as well) do not support Oracle Linux 8.9.
It is possible to download the SRC .tgz of any other version from here: Linux InfiniBand Drivers
And compile it from source yourself, however, please keep in mind that since it’s not officially supported and tested, it might not install or function properly and we will not be able to provide support for it.
I hope this helps.
Best Regards,
Jonathan.
Thank you for your response. I have attempted to compile MLNX_OFED on Oracle Linux 8.9 and 9.4, but encountered the following error message when compiling mlnx-ofa_kernel 23.10-2.1.3.1. However, compiling mlnx-ofa_kernel 5.8-4.1.5.0 works fine. Do you have any ideas or suggestions?
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx4/main.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1321:10: error: 'const struct vfio_device_ops' has no member named 'bind_iommufd'
1321 | .bind_iommufd = vfio_iommufd_physical_bind,
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/irdma/irdma.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/mm_util.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/ah.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1321:25: error: 'vfio_iommufd_physical_bind' undeclared here (not in a function)
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1322:10: error: 'const struct vfio_device_ops' has no member named 'unbind_iommufd'
1322 | .unbind_iommufd = vfio_iommufd_physical_unbind,
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/cmd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/cong.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/counters.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/cq.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx4/mlx4_ib.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1322:27: error: 'vfio_iommufd_physical_unbind' undeclared here (not in a function)
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1322:27: error: excess elements in struct initializer [-Werror]
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1322:27: note: (near initialization for 'mlx5vf_pci_ops')
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1323:10: error: 'const struct vfio_device_ops' has no member named 'attach_ioas'
1323 | .attach_ioas = vfio_iommufd_physical_attach_ioas,
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/ocrdma/ocrdma.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/uuid.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlxfw/mlxfw.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1323:24: error: 'vfio_iommufd_physical_attach_ioas' undeclared here (not in a function)
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1323:24: error: excess elements in struct initializer [-Werror]
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1323:24: note: (near initialization for 'mlx5vf_pci_ops')
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1374:10: error: 'struct pci_driver' has no member named 'driver_managed_dma'
1374 | .driver_managed_dma = true,
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1374:31: error: initialization of 'const struct attribute_group **' from 'int' makes pointer from integer without a cast [-Werror=int-conversion]
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.c:1374:31: note: (near initialization for 'mlx5vf_pci_driver.groups')
cc1: all warnings being treated as errors
make[3]: *** [scripts/Makefile.build:288: /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5/main.o] Error 1
make[2]: *** [scripts/Makefile.build:551: /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vfio/pci/mlx5] Error 2
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/rhashtable.o
make[2]: *** Waiting for unfinished jobs....
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/srp/ib_srp_dummy.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vdpa/mlx5/core/mr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/vmw_pvrdma/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/exec.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/pci.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/srp/ib_srp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/rw.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_verbs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/srpt/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_vlan.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/vmw_pvrdma/vmw_pvrdma.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/usnic/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/syscall.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/sysfs.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/srpt/ib_srpt.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/mmu_notifier.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/iser/ib_iser_dummy.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_ethtool.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/usnic/usnic_verbs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/xarray.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/rdma_dim.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/dm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vdpa/mlx5/net/debug.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/verbs_nvmf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/doorbell.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/iser/ib_iser.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/device.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/gsi.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/dim.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/net_dim.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/file.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/ib_virt.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/flow_offload.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_netlink.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/mad.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_genetlink.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_cm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/cls_api.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/bitmap.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ipoib_fs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cache.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/cmd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/macsec.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/netlink.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/vdpa/mlx5/mlx5_vdpa.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/roce_gid_mgmt.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/main_ext.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/mr_pool.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/mem.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/mr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/addr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/nvmf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/qp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/qpc.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/sa_query.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/multicast.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/qp_nvmf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/restrack.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/compat/mlx_compat.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/mad.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/ipoib/ib_ipoib.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/isert/ib_isert_dummy.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/srq.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/isert/ib_isert.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/smi.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/opa_vnic/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/srq_cmd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/agent.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/srq_nvmf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/umr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/hfi1/main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/wr.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/ulp/opa_vnic/opa_vnic.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/mad_rmpp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/nldev.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/qedr/main.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/hfi1/hfi1.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/bnxt_re/main.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/qedr/qedr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/restrack.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/counters.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/odp.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/bnxt_re/bnxt_re.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/ib_rep.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/devx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/fs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_core_uverbs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/debugfs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/trace.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/qos.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/lag.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/std_types.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/security.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/macsec.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cgroup.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/umem.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fw.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/eq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/umem_dmabuf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/peer_mem.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/umem_odp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cm_trace.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/iwcm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/uar.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/iwpm_util.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/iwpm_msg.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cma.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cma_trace.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/cma_configfs.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/hw/mlx5/mlx5_ib.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/user_mad.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_cmd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_marshall.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/rdma_core.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_ioctl.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_cq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_flow_action.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_dm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_mr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_counters.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/pagealloc.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_uapi.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_device.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_async_fd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_srq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_wq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/uverbs_std_types_qp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ucma.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/health.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_ucm_dummy.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/rdmaip_notify.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/resilient_rdmaip.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_core.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/iw_cm.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_umad.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/mcg.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/cq.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_ucm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/alloc.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/port.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/mr.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/pd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/transobj.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/vport.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/sriov.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fs_cmd.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fs_core.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/pci_irq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fs_counters.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fs_ft_pool.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/rl.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lag/debugfs.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/rdma_ucm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lag/lag.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_uverbs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/dev.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/rdma_cm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/events.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/wq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/gid.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/devcom.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/pci_vsc.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/dm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/fs_ttc.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/fs_tracepoint.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/fw_tracer.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/crdump.o
LD [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/infiniband/core/ib_cm.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/devlink.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/rsc_dump.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/reporter_vnic.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fw_reset.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/qos.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/tout.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/aso.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/mst_dump.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_diag.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/sriov_sysfs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/crdump.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/diag/diag_cnt.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/fw_exp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/eswitch_devlink_compat.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/ecpf.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/compat.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/rqt.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/tir.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/rss.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/rx_res.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/channels.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_main.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_common.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_fs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_ethtool.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_rx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_tx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_dim.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_txrx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/xdp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_stats.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_sysfs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_ecn.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_selftest.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/port.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/monitor_stats.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/health.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/reporter_tx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/reporter_rx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/params.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/xsk/pool.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/xsk/setup.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/xsk/rx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/xsk/tx.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/devlink.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/ptp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/qos.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/htb.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/fs_tt_redirect.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/trap.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/selq.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/crypto.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_debugfs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_arfs.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_fs_ethtool.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_dcbnl.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/port_buffer.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lag/mp.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lag/port_sel.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/geneve.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/lib/port_tun.o
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_rep.o
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/devlink.c: In function 'mlx5e_get_devlink_port':
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/devlink.c:198:16: error: implicit declaration of function 'mlx5e_devlink_get_dl_port' [-Werror=implicit-function-declaration]
198 | return mlx5e_devlink_get_dl_port(priv);
/var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/devlink.c:198:16: error: returning 'int' from a function with return type 'struct devlink_port *' makes pointer from integer without a cast [-Werror=int-conversion]
CC [M] /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/rep/bond.o
make[3]: *** [scripts/Makefile.build:288: /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en/devlink.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [scripts/Makefile.build:551: /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default/drivers/net/ethernet/mellanox/mlx5/core] Error 2
make[1]: *** [Makefile:1988: /var/tmp/OFED_topdir/BUILD/mlnx-ofa_kernel-23.10/obj/default] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.15.0-206.153.7.el9uek.x86_64'
make: *** [makefile:169: kernel] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.eluBYW (%build)
RPM build errors:
user builder does not exist - using root
group dip does not exist - using root
line 92: It's not recommended to have unversioned Obsoletes: Obsoletes: kernel-ib
line 93: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en
line 94: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx_en
line 95: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-utils
line 96: It's not recommended to have unversioned Obsoletes: Obsoletes: kmod-mlnx-en
line 97: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-default
line 98: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-xen
line 99: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-trace
line 100: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-doc
line 101: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-debuginfo
line 102: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-sources
line 133: It's not recommended to have unversioned Obsoletes: Obsoletes: kmod-mlnx-rdma-rxe, mlnx-rdma-rxe-kmp
extra tokens at the end of %else directive in line 137: %else # not KMP
extra tokens at the end of %endif directive in line 162: %endif #end if "%{KMP}" == "1"
line 172: It's not recommended to have unversioned Obsoletes: Obsoletes: kernel-ib-devel
line 173: It's not recommended to have unversioned Obsoletes: Obsoletes: kernel-ib
line 174: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en
line 175: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx_en
line 176: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-utils
line 177: It's not recommended to have unversioned Obsoletes: Obsoletes: kmod-mlnx-en
line 178: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-default
line 179: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-xen
line 180: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-kmp-trace
line 181: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-doc
line 182: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-debuginfo
line 183: It's not recommended to have unversioned Obsoletes: Obsoletes: mlnx-en-sources
extra tokens at the end of %endif directive in line 232: %endif # end of setup module sign scripts
extra tokens at the end of %endif directive in line 459: %endif # end KMP=1
extra tokens at the end of %endif directive in line 645: %endif # end rh
extra tokens at the end of %endif directive in line 646: %endif # end KMP=1
---------------- START OF DEBUG INFO -------------------
Install command: ./install.pl -vvv
Vars dump:
- ofedlogs: /tmp/OFED.1811976.logs
- DISTRO: OL9.4
- dist_rpm: oraclelinux-release-9.4-1.0.6.el9
- rpm_distro: ol9u4
- arch: x86_64
- kernel: 5.15.0-206.153.7.el9uek.x86_64
- kmp: 1
- config: /home/zzz/MLNX_OFED_SRC-23.10-2.1.3.1/ofed.conf
- target_cpu: x86_64
- update: 0
Setup info:
- uname -r: 5.15.0-206.153.7.el9uek.x86_64
- uname -m: x86_64
- rpm -qf /etc/issue: oraclelinux-release-9.4-1.0.6.el9.x86_64
- cat /etc/issue: \S
Kernel \r on an \m
- rpm -qf /etc/os-release: oraclelinux-release-9.4-1.0.6.el9.x86_64
- cat /etc/os-release: NAME="Oracle Linux Server"
VERSION="9.4"
ID="ol"
ID_LIKE="fedora"
VARIANT="Server"
VARIANT_ID="server"
VERSION_ID="9.4"
PLATFORM_ID="platform:el9"
PRETTY_NAME="Oracle Linux Server 9.4"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:oracle:linux:9:4:server"
HOME_URL="https://linux.oracle.com/"
BUG_REPORT_URL="https://github.com/oracle/oracle-linux"
ORACLE_BUGZILLA_PRODUCT="Oracle Linux 9"
ORACLE_BUGZILLA_PRODUCT_VERSION=9.4
ORACLE_SUPPORT_PRODUCT="Oracle Linux"
ORACLE_SUPPORT_PRODUCT_VERSION=9.4
- cat /proc/version: Linux version 5.15.0-206.153.7.el9uek.x86_64 (mockbuild@host-100-100-224-52) (gcc (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3.0.1), GNU ld version 2.35.2-43.0.1.el9) #2 SMP Thu May 9 15:59:05 PDT 2024
- gcc --version: gcc (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3.0.1)
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- lspci -n | grep 15b3: 5e:00.0 0200: 15b3:1017
5e:00.1 0200: 15b3:1017
