I am trying to install MLNX_OFED_LINUX-5.6-2.0.9.0-rhel7.9-x86_64 on centOS with kernel 3.10.0-1160.66.1.el7.x86_64. But it gives this msg as :
General log file: /tmp/MLNX_OFED_LINUX.30324.logs/general.log
Verifying KMP rpms compatibility with target kernel…
The kernel KMP rpms coming with MLNX_OFED_LINUX are not compatible with kernel: 3.10.0-1160.66.1.el7.x86_64
See log at /tmp/MLNX_OFED_LINUX.30324.logs/is_kmp_compat_check.log
The 3.10.0-1160.66.1.el7.x86_64 kernel is installed, MLNX_OFED_LINUX does not have drivers available for this kernel.
You can run mlnx_add_kernel_support.sh in order to to generate an MLNX_OFED_LINUX package with drivers for this kernel .
Or, you can provide ‘–add-kernel-support’ flag to generate an MLNX_OFED_LINUX package and automatically start the installation.
On checking the logs it states that :
warning: /opt/astellia/flex/melanox/MLNX_OFED_LINUX-5.6-2.0.9.0-rhel7.9-x86_64/RPMS/kmod-mlnx-ofa_kernel-5.6-OFED.5.6.2.0.9.1.rhel7u9.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 6224c050: NOKEY
depmod: WARNING: /tmp/kmp_check.7gJULTZ/lib/modules/3.10.0-1160.66.1.el7.x86_64/extra/mlnx-ofa_kernel/drivers/infiniband/core/ib_uverbs.ko needs unknown symbol fget_light
depmod: WARNING: /tmp/kmp_check.7gJULTZ/lib/modules/3.10.0-1160.66.1.el7.x86_64/extra/mlnx-ofa_kernel/drivers/infiniband/core/rdma_ucm.ko needs unknown symbol fget_light
Can someone provide any inputs on this ? Any help would be appreciated
