I updated CentOS 7.9.2009 kernel using elrepo-kernel.
And then when I tried to run mlnxofedinstall --add-kernel-support, it failed.
I installed both the mainline kernel and also the mainline-devel kernel from elrepo-kernel.
uname -r
5.15.11-1.el7.elrepo.x86_64
ofed_info -n
5.5-1.0.3.2
./mlnxofedinstall --add-kernel-support
Note: This program will create MLNX_OFED_LINUX TGZ for rhel7.9 under /tmp/MLNX_OFED_LINUX-5.5-1.0.3.2-5.15.11-1.el7.elrepo.x86_64
directory.
See log file /tmp/MLNX_OFED_LINUX-5.5-1.0.3.2-5.15.11-1.el7.elrepo.x86_64/mlnx_iso.24347_logs/mlnx_ofed_iso.24347.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX RPMS . Please wait…
ERROR: Failed executing "MLNX_OFED_SRC-5.5-1.0.3.2/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-5.5-1.0.3.2-5.15.11-1.el7.elrepo.x86_6
4/mlnx_iso.24347_logs --kernel-only --kernel 5.15.11-1.el7.elrepo.x86_64 --kernel-sources /lib/modules/5.15.11-1.el7.elrepo.x86_64
/build --builddir /tmp/MLNX_OFED_LINUX-5.5-1.0.3.2-5.15.11-1.el7.elrepo.x86_64/mlnx_iso.24347 --disable-kmp --build-only --distro
rhel7.9"
ERROR: See /tmp/MLNX_OFED_LINUX-5.5-1.0.3.2-5.15.11-1.el7.elrepo.x86_64/mlnx_iso.24347_logs/mlnx_ofed_iso.24347.log
Failed to build MLNX_OFED_LINUX for 5.15.11-1.el7.elrepo.x86_64
systemctl status openibd
? openibd.service - openibd - configure Mellanox devices
Loaded: loaded (/usr/lib/systemd/system/openibd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2021-12-24 01:40:37 EST; 34min ago
Docs: file:/etc/infiniband/openib.conf
Process: 1076 ExecStart=/etc/init.d/openibd start bootid=%b (code=exited, status=3)
Main PID: 1076 (code=exited, status=3)
Dec 24 01:40:36 aes18 openibd[1076]: [93B blob data]
Dec 24 01:40:36 aes18 openibd[1076]: [95B blob data]
Dec 24 01:40:36 aes18 openibd[1076]: [94B blob data]
Dec 24 01:40:36 aes18 openibd[1076]: [49B blob data]
Dec 24 01:40:37 aes18 openibd[1076]: [94B blob data]
Dec 24 01:40:37 aes18 systemd[1]: openibd.service: main process exited, code=exited, status=3/NOTIMPLEMENTED
Dec 24 01:40:37 aes18 systemd[1]: Failed to start openibd - configure Mellanox devices.
Dec 24 01:40:37 aes18 systemd[1]: Unit openibd.service entered failed state.
Dec 24 01:40:37 aes18 systemd[1]: openibd.service failed.
I’ve attached the log files and hopefully that will be of use/help.
Your help is greatly appreciated.
Thank you.
mlnx_ofed_iso.24347.log (3.07 KB)
mlnx-ofa_kernel-5.5.rpmbuild.log (322 KB)
