[root@localhost MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64]# ./mlnxofedinstall --without-dkms --add-kernel-support --force
Note: This program will create MLNX_OFED_LINUX TGZ for rhel7.7 under /tmp/MLNX_OFED_LINUX-4.7-1.0.0.1-3.10.0-1062.el7.x86_64 directory.
See log file /tmp/MLNX_OFED_LINUX-4.7-1.0.0.1-3.10.0-1062.el7.x86_64/mlnx_iso.65645_logs/mlnx_ofed_iso.65645.log
Checking if all needed packages are installed…
Unsupported package: dkms
/lib/modules/3.10.0-1062.el7.x86_64/build/scripts is required to build mlnx-ofa_kernel RPM.
Please install the corresponding kernel-source or kernel-devel RPM.
Error: One or more required packages for installing OFED-internal are missing.
Please install the missing packages using your Linux distribution Package Management tool.
Run:
yum install kernel-devel-3.10.0-1062.el7.x86_64
Failed to build MLNX_OFED_LINUX for 3.10.0-1062.el7.x86_64
[root@localhost MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64]# yum -y install kernel-devel-3.10.0-1062.el7.x86_64
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
base | 3.6 kB 00:00:00
extras | 2.9 kB 00:00:00
updates | 2.9 kB 00:00:00
Package kernel-devel-3.10.0-1062.el7.x86_64 already installed and latest version
Nothing to do
samerka
#2
Hi Jenny,
Could you please try the following?
#[mlnxofedinstall --add-kernel-support --force]
If this not working you need to install manually the kernel devel 3.10.0-1062
https://centos.pkgs.org/7/centos-x86_64/kernel-devel-3.10.0-1062.el7.x86_64.rpm.html
Thanks,
Samer
Hi Samer,
I have manually installed the kernel devel 3.10.0-1062
[root@localhost MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64]# yum install kernel-devel-3.10.0-1062.el7.x86_64
epel/x86_64/metalink | 15 kB 00:00:00
ius | 1.3 kB 00:00:00
Nothing to do
It still does not work. Any other suggestion?
samerka
#4
Hi ,
Did you try the following command :
#mlnxofedinstall --add-kernel-support --force --skip-distro-check
Thanks,
Samer
I have tried you suggestion and it still does not work.
[root@localhost MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64]# ./mlnxofedinstall --add-kernel-support --force --skip-distro-check
See log file /tmp/MLNX_OFED_LINUX-4.7-1.0.0.1-3.10.0-1062.el7.x86_64/mlnx_iso.170485_logs/mlnx_ofed_iso.170485.log
Run:
Do I need to install the corresponding kernel-source? I have already done the kernel-devel RPM install.
Please let me know any suggestion.
Or is that possible for us to have a chat?
Thanks,
Jenny
samerka
#6
Hi Jenny,
For further debug and analysis, please open a support case at support@mellanox.com
Thanks,
Samer
Hi Samer,
I have opened a support case.
Mellanox Case 00690363: Error Installing MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64 on CentOS Linux release 7.7.1908 (Core)
Thank you very much for help.
Best regards,
Jenny
[root@localhost MLNX_OFED_LINUX-4.7-1.0.0.1-rhel7.7-x86_64]# ./mlnxofedinstall --add-kernel-support --fw-image-dir /tmp/my_fw_bin_files
See log file /tmp/MLNX_OFED_LINUX-4.7-1.0.0.1-3.10.0-1062.el7.x86_64/mlnx_iso.232501_logs/mlnx_ofed_iso.232501.log
Run:
How do I install the corresponding kernel-source or kernel-devel RPM?
I have already done the: yum install kernel-devel-3.10.0-1062.el7.x86_64.
Thanks for your information.
