Hello everyone,
I have this pipeline : appsrc - omxh264enc - filter - appsink.
I am using appsrc to push raw video frames to the pipeline, frame size (resolution) is changing dynamically, so I must change appsrc caps before pushing frame to the pipeline.
So I should be able to just (according to gstreamer-devel):
- push buffer in old format.
- set new caps on appsrc.
- push buffer in new format.
This should work but I it seems that omxh264enc does not change resolution when changing appsource caps. So is it possible to change resolution/ frame size at runtime ?
If not, is it something related to hardware or source code of plugins ? so can we change the source code to let coder support dynamic resolution change ?
Regards,
