One core 100% IRQ some times
Hello!
I have Mellanox Technologies MT28800 Family [ConnectX-5 Ex] card on server with AMD EPYC 7742 64-Core Processor. I used all recommendations about tuning this NIC, but some time I see one core with 100% irq. Ususaly it CPU0 or CPU68, if I try set_irq_affinity_bynode.sh 1 eth0.
What to do?
ethtool -i eth0
driver: mlx5_core
version: 5.0-0
firmware-version: 16.29.2002 (MT_0000000013)
expansion-rom-version:
bus-info: 0000:41:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
Now NIC stops working:
Hi Андрй,
In AMD based servers, please assign the affinities to cores belong to the numa nodes with the shortest distance to the closes numa node connected to the NIC.
HowTo Find the Numa node connected to the network adapter
cat /sys/class/net//device/numa_node
HowTo find the numa nodes with the shortest distance:
numactl --hardware
^Please choose the nodes with distance 10 and 11.
HowTo find the relevant cores:
lscpu
HowTo assign the cores:
set_irq_affinity_cpulist.sh
For example:
set_irq_affinity_cpulist.sh 72-95 ens0
Notes:
  • Make sure irqbalance service is not running on the hosts
  • Hyperthreading is disabled
Regards,
Chen
Thanks for your answer!
cat /sys/class/net/eth0/device/numa_node
0
numactl --hardware
available: 2 nodes (0-1)
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
node 0 size: 515906 MB
node 0 free: 3090 MB
node 1 cpus: 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
node 1 size: 516066 MB
node 1 free: 939 MB
node distances:
node 0 1
0: 10 32
1: 32 10
I made set_irq_affinity_bynode.sh 0 eth0
Discovered irqs for eth0: 563 569 575 581 587 593 599 605 611 617 623 629 635 641 647 653 658 663 668 673 678 683 688 693 698 703 708 713 718 723 728 733 738 743 748 753 758 763 768 773 778 783 788 793 798 803 808 813 818 823 828 833 838 843 847 850 853 855 857 858 859 860 861 862
Optimizing IRQs for Single port traffic
Assign irq 563 core_id 0
Assign irq 569 core_id 1
Assign irq 575 core_id 2
Assign irq 581 core_id 3
Assign irq 587 core_id 4
Assign irq 593 core_id 5
Assign irq 599 core_id 6
Assign irq 605 core_id 7
Assign irq 611 core_id 8
Assign irq 617 core_id 9
Assign irq 623 core_id 10
Assign irq 629 core_id 11
Assign irq 635 core_id 12
Assign irq 641 core_id 13
Assign irq 647 core_id 14
Assign irq 653 core_id 15
Assign irq 658 core_id 16
Assign irq 663 core_id 17
Assign irq 668 core_id 18
Assign irq 673 core_id 19
Assign irq 678 core_id 20
Assign irq 683 core_id 21
Assign irq 688 core_id 22
Assign irq 693 core_id 23
Assign irq 698 core_id 24
Assign irq 703 core_id 25
Assign irq 708 core_id 26
Assign irq 713 core_id 27
Assign irq 718 core_id 28
Assign irq 723 core_id 29
Assign irq 728 core_id 30
Assign irq 733 core_id 31
Assign irq 738 core_id 32
Assign irq 743 core_id 33
Assign irq 748 core_id 34
Assign irq 753 core_id 35
Assign irq 758 core_id 36
Assign irq 763 core_id 37
Assign irq 768 core_id 38
Assign irq 773 core_id 39
Assign irq 778 core_id 40
Assign irq 783 core_id 41
Assign irq 788 core_id 42
Assign irq 793 core_id 43
Assign irq 798 core_id 44
Assign irq 803 core_id 45
Assign irq 808 core_id 46
Assign irq 813 core_id 47
Assign irq 818 core_id 48
Assign irq 823 core_id 49
Assign irq 828 core_id 50
Assign irq 833 core_id 51
Assign irq 838 core_id 52
Assign irq 843 core_id 53
Assign irq 847 core_id 54
Assign irq 850 core_id 55
Assign irq 853 core_id 56
Assign irq 855 core_id 57
Assign irq 857 core_id 58
Assign irq 858 core_id 59
Assign irq 859 core_id 60
Assign irq 860 core_id 61
Assign irq 861 core_id 62
Assign irq 862 core_id 63
done.
Now all fine, most loaded core 64% irq. But sometimes one core loaded 100% irq, and trafic goes down from 45 Gbps to 30 Gbps
2 weeks all was fine. Now every evening the same picture: today 100% load irq CPU004. Helps to change the node for a few minutes set_irq_affinity_bynode.sh 1 eth0 after that 2 CPU load 100% CPU068 and CPU072, after that I change it again to 0 node set_irq_affinity_bynode.sh 0 eth0 and almost a day all fine until the evening peaks. What wrong?
The same picture with Mellanox Technologies MT28908 Family [ConnectX-6]
ethtool -i eth0
driver: mlx5_core
version: 5.3-1.0.0
firmware-version: 20.30.1004 (MT_0000000225)
supports-test: yes
Every day such picture:
Hello, now have better result? we can push 85gbps on same server spec.
on u graphs i see few nginx workers… total 8 workers per 128core ? try with 64 core (one socket) and bind affinity to CPU near socket NIC (cat /sys/class/net//device/numa_node)
We can push even 96gbps on this server.
with 18 nginx workers ?
i see u have 5781% irq, if total 6400% one socket, thats mean nginx affinity bind on another socket or nginx affinity not binded ?
u delivery mp4 or hls video ?
nginx not binded. Number of workers plays no role. If there is no work, like today, they are sleeping
# ps ax | grep nginx
 11714 ?        Ss     0:23 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
206897 ?        RN   427:11 nginx: worker process
206898 ?        RN   395:34 nginx: worker process
206899 ?        RN   347:19 nginx: worker process
206900 ?        RN   285:39 nginx: worker process
206901 ?        SN   211:30 nginx: worker process
206902 ?        SN   144:16 nginx: worker process
206903 ?        RN    90:29 nginx: worker process
206904 ?        SN    51:01 nginx: worker process
206905 ?        SN    24:41 nginx: worker process
206906 ?        SN     9:21 nginx: worker process
206907 ?        SN     2:20 nginx: worker process
206908 ?        SN     0:00 nginx: worker process
206909 ?        SN     0:06 nginx: worker process
206910 ?        SN     0:00 nginx: worker process
206911 ?        SN     0:00 nginx: worker process
206912 ?        SN     0:00 nginx: worker process
206913 ?        SN     0:00 nginx: worker process
206914 ?        SN     0:00 nginx: worker process
206915 ?        SN     0:00 nginx: worker process
206916 ?        SN     0:00 nginx: worker process
206917 ?        SN     0:00 nginx: worker process
206918 ?        SN     0:00 nginx: worker process
206919 ?        SN     0:00 nginx: worker process
206920 ?        SN     0:00 nginx: worker process
206921 ?        SN     0:00 nginx: worker process
206922 ?        SN     0:00 nginx: worker process
206923 ?        SN     0:00 nginx: worker process
206924 ?        SN     0:00 nginx: worker process
206925 ?        SN     0:00 nginx: worker process
206926 ?        SN     0:00 nginx: worker process
206927 ?        SN     0:00 nginx: worker process
206928 ?        SN     0:00 nginx: worker process
206929 ?        SN     0:00 nginx: worker process
206930 ?        SN     0:00 nginx: worker process
206931 ?        SN     0:00 nginx: worker process
206932 ?        SN     0:00 nginx: worker process
206933 ?        SN     0:00 nginx: worker process
206934 ?        SN     0:00 nginx: worker process
206935 ?        SN     0:00 nginx: worker process
206936 ?        SN     0:00 nginx: worker process
206937 ?        SN     0:00 nginx: worker process
206938 ?        SN     0:00 nginx: worker process
206939 ?        SN     0:00 nginx: worker process
206940 ?        SN     0:00 nginx: worker process
206941 ?        SN     0:00 nginx: worker process
206942 ?        SN     0:00 nginx: worker process
206943 ?        SN     0:00 nginx: worker process
206944 ?        SN     0:00 nginx: worker process
206945 ?        SN     0:00 nginx: worker process
206946 ?        SN     0:00 nginx: worker process
206947 ?        SN     0:00 nginx: worker process
206948 ?        SN     0:00 nginx: worker process
206949 ?        SN     0:00 nginx: worker process
206950 ?        SN     0:00 nginx: worker process
206951 ?        SN     0:00 nginx: worker process
206952 ?        SN     0:00 nginx: worker process
206953 ?        SN     0:00 nginx: worker process
206954 ?        SN     0:00 nginx: worker process
206955 ?        SN     0:00 nginx: worker process
206956 ?        SN     0:00 nginx: worker process
u have a lower cpu usage system% and user%. we on 85gbps have 1200%system and 500-600%user.
and nginx wokers have balanced busy, because we use reuseport
mp4 content ?
u have different busy workers nginx, its no good… u use multi_accept on, right ? why ? i test with this options, not have different in load CPU, but only 8-10 workers is work with 80-90%, another is sleeping. without this options all workers ~ 15%
Андрей, спасибо за reuseport, давно не читал ченджлог нгинкс, эта опция прошла мимо меня. Добавил, нагрузка на процессор снизилась.
Относительно описанной мной проблемы, когда прерывания сетевой карты грузят одно ядро. У меня сейчас 5 идентичных серверов с 100Г картой. Конфиги фирмавари, ядро итд - идентичное. На 4 сейчас все нормально, на одном все равно есть проблема с загрузкой одного ядра. Это при том, что нигде нет нагрузки даже 50 гбит/с
У меня не было таких проблем, прерывания сетевой карты всегда раскидываются по ядрам по дефолту, может у вас дистрибутив старый? я тестил на дебиане 11 и убунту 22.04. У нас сейчас 2 сервера как раз на этих ОС. примерно на 80-85 гигабит хватает. На дебиане кстате постабильнее, падения очень легкие - 1-3% трафика, в отличии от убунты - 20-30% ).
Еще я заметил у вас высокий уровень нагрузки irq, можно же сетевые прерывания оттюнить. У нас в 2 раза меньше irq)) но тем не менее падаем.
А вообще на 96 гигабит стабилен был сервер? или это так уже с фризами? )
Собственно видно, как около 12 ночи отпускает это ядро. При чем, если перекинуть интерапты на другую нума ноду set_irq_affinity_bynode.sh 0 enp161s0f0np0, все равно остается загрузка одного ядра на 100%, cpu064 меняется на cpu000. К сожалению инженеры меланокс не проявляют интерес к этой проблеме.
Где-то примерно после 70 Гбит/с проблема пропадает. А до этой нагрузки бывают вот такие залипания. На северах сейчас везде дебиан с ядром 4.19.0-20-amd64
интерапты нельзя переносить на другой сокет, это ведь на уровне железа, если сетевая в сокете CPU2, то на CPU1 ты не сможешь ее поставить.
lspci -s 81:00.0 -v | grep NUMA
Flags: bus master, fast devsel, latency 0, IRQ 2403, NUMA node 1, IOMMU group 115
если сделать так
echo 0 > /sys/class/net/enp129s0f0np0/device/numa_node
то драйвер сразу ругается:
[Firmware Bug]: Overriding NUMA node to 0. Contact your vendor for updates.
Соответственно, если перенести интерапты на CPU1 ядра, наверно нагрузка будет и там и там ) ну или ни чего хорошего не будет))
А вторую сетевую поставить в CPU1 тоже не получится :). А это бы решило проблему.
ну у нас похожие проблемы в час пике, только на трафике > 80гигабит… 84-85 гигабит.
a1
а это на дебиане, падение реально слабое.
a2
с падениями мы решили, мы искуственно после 80 гигабит сбрасываем качество, и сразу ровная линяя канала идет ~80гигабит
и кстате там драйвер недавно обновился, у нас 5.6 везде, там 5.7 появился.
Почему это нельзя переносить? Все можно, скрипт set_irq_affinity_bynode.sh нормально отрабаывает, переносит все интерапты на другой CPU. С точки зрения оптимизации - это не оптимально, потому что будет еще использована межпроцессорная шина.
