Hello, I am trying to launch a guest OS with H20 GPU * 8 + NVSwitch * 4 passed through into it, but only 4 of 8 GPUs can be successfully initialized.
- Environment:
- CPU: AMD EPYC 9K84 96-Core
- GPU: Nvidia H20 GPU * 8
- Driver: 580.95.05 open
- Cuda: 13.0.2
- qemu command:
QEMU_CMDLINE=${QEMU_REAL_PATH}
QEMU_CMDLINE+=" -enable-kvm -cpu EPYC-v4,host-phys-bits=on -machine q35"
QEMU_CMDLINE+=" -smp $CORES,maxcpus=255"
QEMU_CMDLINE+=" -m ${MEM}G,slots=2,maxmem=128G"
QEMU_CMDLINE+=" -no-reboot"
QEMU_CMDLINE+=" -bios $OVMF_REAL_PATH"
QEMU_CMDLINE+=" -drive file=$VM_IMAGE_REAL_PATH,if=none,id=disk0,format=qcow2"
QEMU_CMDLINE+=" -device virtio-scsi-pci,id=scsi0,disable-legacy=on,iommu_platform=true,romfile= "
QEMU_CMDLINE+=" -device scsi-hd,drive=disk0"
QEMU_CMDLINE+=" -netdev user,id=vmnic,hostfwd=tcp::2222-:22"
QEMU_CMDLINE+=" -device virtio-net-pci,disable-legacy=on,iommu_platform=true,netdev=vmnic,romfile= "
if [ -n "${SEV_SNP}" ]; then
QEMU_CMDLINE+=" -machine confidential-guest-support=sev0,vmport=off"
QEMU_CMDLINE+=" -object sev-snp-guest,id=sev0,policy=0x30002,cbitpos=51,reduced-phys-bits=1"
if [ -n "${KERNEL_HASH}" ]; then
QEMU_CMDLINE+=",kernel-hashes=on"
QEMU_CMDLINE+=" -kernel ${KERNEL_REAL_PATH}"
QEMU_CMDLINE+=" -initrd ${INITRD_REAL_PATH}"
QEMU_CMDLINE+=" -append \"root=/dev/sda2 console=ttyS0 pci=realloc,nocrs pci=assign-busses\""
fi
QEMU_CMDLINE+=" -object memory-backend-memfd,id=ram1,size=${MEM}G,share=true,prealloc=true"
QEMU_CMDLINE+=" -machine memory-backend=ram1"
fi
QEMU_CMDLINE+=" -nographic -vga none"
QEMU_CMDLINE+=" -monitor pty -monitor unix:monitor,server,nowait"
if [ -n "${MULTI_GPU}" ]; then
GPU_PCI_ID=("" "03:00.0" "16:00.0" "1c:00.0" "2e:00.0" "47:00.0" "48:00.0" "49:00.0" "4a:00.0" "84:00.0" "9c:00.0" "b6:00.0" "bb:00.0")
for i in {1..12}
do
QEMU_CMDLINE+=" -device pcie-root-port,id=pci.$i,bus=pcie.0,chassis=$i"
QEMU_CMDLINE+=" -device vfio-pci,host=${GPU_PCI_ID[$i]},bus=pci.$i"
done
else
QEMU_CMDLINE+=" -device pcie-root-port,id=pci.1,bus=pcie.0,chassis=1"
QEMU_CMDLINE+=" -device vfio-pci,host=03:00.0,bus=pci.1"
fi
echo "qemu cmd: $QEMU_CMDLINE"
sh -c "${QEMU_CMDLINE}" 2>&1 | tee -a ${LOG_DIR}/qemu.log
- dmesg output:
[ 31.356037] nvidia 0000:01:00.0: enabling device (0000 -> 0002)
[ 33.833812] nvidia 0000:02:00.0: enabling device (0000 -> 0002)
[ 36.217807] nvidia 0000:03:00.0: enabling device (0000 -> 0002)
[ 38.818882] nvidia 0000:04:00.0: enabling device (0000 -> 0002)
[ 41.161805] nvidia 0000:09:00.0: enabling device (0000 -> 0002)
[ 43.481820] nvidia 0000:0a:00.0: enabling device (0000 -> 0002)
[ 46.065811] nvidia 0000:0b:00.0: enabling device (0000 -> 0002)
[ 48.618831] nvidia 0000:0c:00.0: enabling device (0000 -> 0002)
[ 51.127814] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 580.95.05 Release Build (dvs-builder@U22-I3-B17-02-5) Tue Sep 23 09:55:41 UTC 2025
[ 51.132332] nvidia-nvswitch0: open (major=240)
[ 51.132586] nvidia-nvswitch1: open (major=240)
[ 51.132861] nvidia-nvswitch2: open (major=240)
[ 51.133045] nvidia-nvswitch3: open (major=240)
[ 51.138009] nvidia-nvlink: nvlink driver open
[ 51.138014] nvidia-nvlink: nvlink driver close
[ 51.138017] nvidia-nvlink: nvlink driver open
[ 51.138185] nvidia-nvswitch0: open (major=240)
[ 51.138190] nvidia-nvswitch0: open (major=240)
[ 51.138192] nvidia-nvswitch0: open (major=240)
[ 51.138194] nvidia-nvswitch0: open (major=240)
[ 51.138196] nvidia-nvswitch0: open (major=240)
[ 51.138199] nvidia-nvswitch1: open (major=240)
[ 51.138201] nvidia-nvswitch1: open (major=240)
[ 51.138203] nvidia-nvswitch1: open (major=240)
[ 51.138205] nvidia-nvswitch1: open (major=240)
[ 51.138208] nvidia-nvswitch1: open (major=240)
[ 51.138211] nvidia-nvswitch2: open (major=240)
[ 51.138213] nvidia-nvswitch2: open (major=240)
[ 51.138215] nvidia-nvswitch2: open (major=240)
[ 51.138235] nvidia-nvswitch2: open (major=240)
[ 51.138237] nvidia-nvswitch2: open (major=240)
[ 51.138239] nvidia-nvswitch3: open (major=240)
[ 51.138241] nvidia-nvswitch3: open (major=240)
[ 51.138243] nvidia-nvswitch3: open (major=240)
[ 51.138246] nvidia-nvswitch3: open (major=240)
[ 51.138248] nvidia-nvswitch3: open (major=240)
[ 51.180751] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.95.05 Release Build (dvs-builder@U22-I3-B17-02-5) Tue Sep 23 09:42:01 UTC 2025
[ 51.240262] ACPI Warning: \_SB.PCI0.S18.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 53.994835] ACPI Warning: \_SB.PCI0.S20.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 56.677962] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 56.776636] ACPI Warning: \_SB.PCI0.S28.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 59.573637] ACPI Warning: \_SB.PCI0.S30.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 62.307918] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 62.307937] nvidia 0000:01:00.0: [drm] No compatible format found
[ 62.307940] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 62.307977] [drm] [nvidia-drm] [GPU ID 0x00000200] Loading driver
[ 62.383695] ACPI Warning: \_SB.PCI0.S58.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 65.188756] ACPI Warning: \_SB.PCI0.S60.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 69.587765] NVRM: gpuClearFbhubPoisonIntrForBug2924523_GA100: FBHUB Interrupt detected. Clearing it.
[ 69.588332] ACPI Warning: \_SB.PCI0.S68.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 72.368332] NVRM: gpuClearFbhubPoisonIntrForBug2924523_GA100: FBHUB Interrupt detected. Clearing it.
[ 72.368913] ACPI Warning: \_SB.PCI0.S70.S00._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 75.588764] NVRM: kgspCheckGspRmCcCleanup_GH100: CC secret cleanup successful!
[ 76.006763] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:02:00.0 on minor 1
[ 76.006776] nvidia 0000:02:00.0: [drm] No compatible format found
[ 76.006780] nvidia 0000:02:00.0: [drm] Cannot find any crtc or sizes
[ 76.006831] [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
[ 76.382932] NVRM: kgspCheckGspRmCcCleanup_GH100: CC secret cleanup successful!
[ 77.173214] NVRM: kgspCheckGspRmCcCleanup_GH100: CC secret cleanup successful!
[ 77.653649] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:03:00.0 on minor 2
[ 77.653676] nvidia 0000:03:00.0: [drm] No compatible format found
[ 77.653680] nvidia 0000:03:00.0: [drm] Cannot find any crtc or sizes
[ 77.653721] [drm] [nvidia-drm] [GPU ID 0x00000400] Loading driver
[ 78.057580] NVRM: kgspCheckGspRmCcCleanup_GH100: CC secret cleanup successful!
[ 78.507070] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:04:00.0 on minor 3
[ 78.507084] nvidia 0000:04:00.0: [drm] No compatible format found
[ 78.507087] nvidia 0000:04:00.0: [drm] Cannot find any crtc or sizes
[ 78.507121] [drm] [nvidia-drm] [GPU ID 0x00000900] Loading driver
[ 78.566046] NVRM: gpumgrCheckRmFirmwarePolicy: Disabling GSP offload -- GPU not supported
[ 78.566071] NVRM: nvAssertFailedNoLog: Assertion failed: pVGpu != NULL @ objvgpu.c:148
[ 78.566099] NVRM: osInitNvMapping: *** Cannot attach gpu
[ 78.566118] NVRM: RmInitAdapter: osInitNvMapping failed, bailing out of RmInitAdapter
[ 78.566147] NVRM: GPU 0000:09:00.0: RmInitAdapter failed! (0x22:0x56:763)
[ 78.567796] NVRM: GPU 0000:09:00.0: rm_init_adapter failed, device minor number 4
[ 78.607338] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000900] Failed to allocate NvKmsKapiDevice
[ 78.608259] [drm] [nvidia-drm] [GPU ID 0x00000a00] Loading driver
[ 78.677499] NVRM: gpumgrCheckRmFirmwarePolicy: Disabling GSP offload -- GPU not supported
[ 78.677526] NVRM: nvAssertFailedNoLog: Assertion failed: pVGpu != NULL @ objvgpu.c:148
[ 78.677552] NVRM: osInitNvMapping: *** Cannot attach gpu
[ 78.677571] NVRM: RmInitAdapter: osInitNvMapping failed, bailing out of RmInitAdapter
[ 78.677599] NVRM: GPU 0000:0a:00.0: RmInitAdapter failed! (0x22:0x56:763)
[ 78.679126] NVRM: GPU 0000:0a:00.0: rm_init_adapter failed, device minor number 5
[ 78.704316] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Failed to allocate NvKmsKapiDevice
[ 78.705255] [drm] [nvidia-drm] [GPU ID 0x00000b00] Loading driver
[ 78.778935] NVRM: gpumgrCheckRmFirmwarePolicy: Disabling GSP offload -- GPU not supported
[ 78.778960] NVRM: nvAssertFailedNoLog: Assertion failed: pVGpu != NULL @ objvgpu.c:148
[ 78.778989] NVRM: osInitNvMapping: *** Cannot attach gpu
[ 78.779008] NVRM: RmInitAdapter: osInitNvMapping failed, bailing out of RmInitAdapter
[ 78.779067] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x22:0x56:763)
[ 78.780591] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 6
[ 78.812416] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to allocate NvKmsKapiDevice
[ 78.813349] [drm] [nvidia-drm] [GPU ID 0x00000c00] Loading driver
[ 78.872103] NVRM: gpumgrCheckRmFirmwarePolicy: Disabling GSP offload -- GPU not supported
[ 78.872130] NVRM: nvAssertFailedNoLog: Assertion failed: pVGpu != NULL @ objvgpu.c:148
[ 78.872157] NVRM: osInitNvMapping: *** Cannot attach gpu
[ 78.872175] NVRM: RmInitAdapter: osInitNvMapping failed, bailing out of RmInitAdapter
[ 78.872210] NVRM: GPU 0000:0c:00.0: RmInitAdapter failed! (0x22:0x56:763)
[ 78.873734] NVRM: GPU 0000:0c:00.0: rm_init_adapter failed, device minor number 7
[ 78.912314] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000c00] Failed to allocate NvKmsKapiDevice
[ 79.054523] NVRM: gpumgrCheckRmFirmwarePolicy: Disabling GSP offload -- GPU not supported
[ 79.054548] NVRM: nvAssertFailedNoLog: Assertion failed: pVGpu != NULL @ objvgpu.c:148
[ 79.054574] NVRM: osInitNvMapping: *** Cannot attach gpu
nvidia-smiandnvidia-smi conf-compute -qoutput:Mon Jan 5 15:29:21 2026 +-----------------------------------------------------------------------------------------+ | NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 | +-----------------------------------------+------------------------+----------------------+ | GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |=========================================+========================+======================| | 0 NVIDIA H20 On | 00000000:01:00.0 Off | 0 | | N/A 35C P0 74W / 500W | 0MiB / 97871MiB | 0% Default | | | | N/A | +-----------------------------------------+------------------------+----------------------+ | 1 NVIDIA H20 On | 00000000:02:00.0 Off | 0 | | N/A 34C P0 75W / 500W | 0MiB / 97871MiB | 0% Default | | | | N/A | +-----------------------------------------+------------------------+----------------------+ | 2 NVIDIA H20 On | 00000000:03:00.0 Off | 0 | | N/A 30C P0 73W / 500W | 0MiB / 97871MiB | 0% Default | | | | N/A | +-----------------------------------------+------------------------+----------------------+ | 3 NVIDIA H20 On | 00000000:04:00.0 Off | 0 | | N/A 30C P0 71W / 500W | 0MiB / 97871MiB | 0% Default | | | | N/A | +-----------------------------------------+------------------------+----------------------+ +-----------------------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=========================================================================================| | No running processes found | +-----------------------------------------------------------------------------------------+ ==============NVSMI CONF-COMPUTE LOG============== CC State : OFF Multi-GPU Mode : Protected PCIe CPU CC Capabilities : AMD SEV-SNP GPU CC Capabilities : CC Capable CC GPUs Ready State : Ready5.
lspci -nnk -v -d 10de:output:01:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0 Flags: bus master, fast devsel, latency 0, IRQ 23 Memory at 1002000000 (64-bit, prefetchable) [size=16M] Memory at 2000000000 (64-bit, prefetchable) [size=128G] Memory at 1000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable+ Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 2e-ff-31-94-70-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 02:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-2 Flags: bus master, fast devsel, latency 0, IRQ 20 Memory at 6002000000 (64-bit, prefetchable) [size=16M] Memory at 4000000000 (64-bit, prefetchable) [size=128G] Memory at 6000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable+ Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number b6-3b-47-a2-c4-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 03:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-3 Flags: bus master, fast devsel, latency 0, IRQ 21 Memory at 7002000000 (64-bit, prefetchable) [size=16M] Memory at 8000000000 (64-bit, prefetchable) [size=128G] Memory at 7000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable+ Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 72-4b-35-2a-02-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 04:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-4 Flags: bus master, fast devsel, latency 0, IRQ 22 Memory at 12002000000 (64-bit, prefetchable) [size=16M] Memory at 10000000000 (64-bit, prefetchable) [size=128G] Memory at 12000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable+ Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 8d-90-d6-b4-22-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 05:00.0 Bridge [0680]: NVIDIA Corporation Device [10de:22a3] (rev a1) Subsystem: NVIDIA Corporation Device [10de:1796] Physical Slot: 0-5 Flags: bus master, fast devsel, latency 0, IRQ 59 Memory at 86000000 (64-bit, non-prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [100] Null Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2f0] Device Serial Number 2e-9f-9d-4e-b0-2d-b0-48 Kernel driver in use: nvidia-nvswitch Kernel modules: nvidia_drm, nvidia 06:00.0 Bridge [0680]: NVIDIA Corporation Device [10de:22a3] (rev a1) Subsystem: NVIDIA Corporation Device [10de:1796] Physical Slot: 0-6 Flags: bus master, fast devsel, latency 0, IRQ 60 Memory at 84000000 (64-bit, non-prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [100] Null Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2f0] Device Serial Number a4-5c-9a-21-10-2d-b0-48 Kernel driver in use: nvidia-nvswitch Kernel modules: nvidia_drm, nvidia 07:00.0 Bridge [0680]: NVIDIA Corporation Device [10de:22a3] (rev a1) Subsystem: NVIDIA Corporation Device [10de:1796] Physical Slot: 0-7 Flags: bus master, fast devsel, latency 0, IRQ 61 Memory at 82000000 (64-bit, non-prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [100] Null Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2f0] Device Serial Number 46-3e-ae-50-80-2d-b0-48 Kernel driver in use: nvidia-nvswitch Kernel modules: nvidia_drm, nvidia 08:00.0 Bridge [0680]: NVIDIA Corporation Device [10de:22a3] (rev a1) Subsystem: NVIDIA Corporation Device [10de:1796] Physical Slot: 0-8 Flags: bus master, fast devsel, latency 0, IRQ 62 Memory at 80000000 (64-bit, non-prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [100] Null Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2f0] Device Serial Number 5c-f8-18-14-d4-2d-b0-48 Kernel driver in use: nvidia-nvswitch Kernel modules: nvidia_drm, nvidia 09:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-9 Flags: bus master, fast devsel, latency 0, IRQ 23 Memory at 13002000000 (64-bit, prefetchable) [size=16M] Memory at 14000000000 (64-bit, prefetchable) [size=128G] Memory at 13000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable- Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 9f-21-0f-69-a4-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 0a:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-10 Flags: bus master, fast devsel, latency 0, IRQ 20 Memory at 18002000000 (64-bit, prefetchable) [size=16M] Memory at 16000000000 (64-bit, prefetchable) [size=128G] Memory at 18000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable- Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number e3-56-92-5a-7d-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 0b:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-11 Flags: bus master, fast devsel, latency 0, IRQ 21 Memory at 19002000000 (64-bit, prefetchable) [size=16M] Memory at 1a000000000 (64-bit, prefetchable) [size=128G] Memory at 19000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable- Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 3b-27-8d-fa-bc-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia 0c:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:2329] (rev a1) Subsystem: NVIDIA Corporation Device [10de:198b] Physical Slot: 0-12 Flags: bus master, fast devsel, latency 0, IRQ 22 Memory at 1e002000000 (64-bit, prefetchable) [size=16M] Memory at 1c000000000 (64-bit, prefetchable) [size=128G] Memory at 1e000000000 (64-bit, prefetchable) [size=32M] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable- Count=1/16 Maskable+ 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [9c] Vendor Specific Information: Len=14 <?> Capabilities: [b0] MSI-X: Enable- Count=9 Masked- Capabilities: [100] Null Capabilities: [12c] Latency Tolerance Reporting Capabilities: [134] Physical Resizable BAR Capabilities: [1b8] Advanced Error Reporting Capabilities: [2a4] Vendor Specific Information: ID=0001 Rev=1 Len=014 <?> Capabilities: [2b8] Power Budgeting <?> Capabilities: [2f0] Device Serial Number 73-4d-fa-97-9a-2d-b0-48 Kernel driver in use: nvidia Kernel modules: nvidia_drm, nvidia
