• Hardware Platform (Jetson / GPU): Jetson Orin NX
• DeepStream Version: 7.0
• JetPack Version (valid for Jetson only): 6.0
• TensorRT Version: 8.6.2.3
• Issue Type( questions, new requirements, bugs): questions
Pipeline
nvurisrcbin → nvvideoconvert → nvstreammux(batch-size=1) → nvinfer(PGIE, unique-id=1) → [nvtracker(IOU)] → nvinfer(SGIE#1, unique-id=2) → nvinfer(SGIE#2, unique-id=3) → identity(pad-probe) → fakesink
(PGIE = trafficcamnet, both SGIEs = vehiclemakenet with identical config files. Both SGIEs operate on PGIE’s detections (operate-on-gie-id=1).)
Expectation
Since both SGIEs are identical and operate on the same PGIE objects, each object should have either 0 or 2 classifier results (never exactly 1) on a given frame.
Actual Behavior
Only when the tracker is enabled, we intermittently observe frames where car objects (class_id=0) carry only one classifier meta. Without the tracker, we never see this. A pad-probe after the second SGIE counts classifier_meta entries per object and prints:
class_id=0 has only 1 classifier result
This appears dozens of times per run when the tracker is present.
Repro
Minimal Python script attached below (uses DeepStream sample video sample_1080p_h265.mp4).
Flip ENABLE_TRACKER=True/False to compare behavior.
Question
I am trying to create a pipeline application using DeepStream where objects are first detected by PGIE, then tracked, and afterward classified by two SGIEs for each detected object (PGIE → Tracker → SGIE1 → SGIE2).
While verifying the behavior, I noticed that only when there is a Tracker between the PGIE and SGIEs, the execution result of one of the SGIEs occasionally does not appear in the metadata. To confirm this, I conducted the following experiment:
I created a verification program using Gst-Python.
To compare the behavior with and without the Tracker, I defined ENABLE_TRACKER in the script so that the Tracker is linked between the PGIE and SGIEs only when it is set to True.
For the PGIE model, I used trafficcamnet.
For the Tracker model, I used IOU.
For both SGIEs, I used exactly the same configuration file and model (vehiclemakenet). Since both are set to perform inference on the PGIE detection results, they are expected to produce exactly the same output. (In other words, every object should always have either zero or two SGIE classification results attached. A situation where only one SGIE classification result is attached is not expected.)
I added a Probe to the pad of the identity element linked after the SGIEs. In this Probe, using PyDS, I counted the number of classification results attached to every object in every frame, and if the number was one, I printed the message “class_id=0 has only 1 classifier result.”
When I ran the experiment, dozens of “class_id=0 has only 1 classifier result” messages were printed when the Tracker was present, but no such messages were printed when the Tracker was absent. This shows that without the Tracker, both SGIEs attach inference results to the objects at exactly the same timing.
However, since the actual application needs to use a Tracker, I have been looking for a configuration that allows both SGIEs to produce exactly the same results while the Tracker is enabled, but I have not been able to find one.
Am I overlooking some configuration? I would greatly appreciate any help with this issue. Thank you in advance.
I have attached below the program I used for testing. I would appreciate it if you could review it.
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GLib", "2.0")
from gi.repository import Gst, GLib
import pyds
ENABLE_TRACKER = True
INPUT_SOURCE_URI = 'file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4'
PGIE_CONFIG_FILE = '/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt'
PGIE_ENGINE_FILE = '/opt/nvidia/deepstream/deepstream/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine'
SGIE1AND2_CONFIG_FILE = '/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_vehiclemake.txt'
SGIE1AND2_ENGINE_FILE = '/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b1_gpu0_int8.engine'
TRACKER_LIB_FILE = '/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so'
TRACKER_CONFIG_FILE = '/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_IOU.yml'
def on_message(bus, message, data) -> bool:
pipeline, loop = data
msg_type = message.type
src = message.src.name
if msg_type == Gst.MessageType.EOS:
print(f"{src} :: End-of-stream")
pipeline.set_state(Gst.State.NULL)
loop.quit()
elif msg_type == Gst.MessageType.WARNING:
err, debug = message.parse_warning()
print(f"{src} :: Warning: {err}: {debug}")
elif msg_type == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f"{src} :: Error: {err}: {debug}")
loop.quit()
elif msg_type == Gst.MessageType.STATE_CHANGED:
msg = message.parse_state_changed()
if src == "pipeline":
print(f"{src} :: State change: {msg.oldstate.value_name} -> {msg.newstate.value_name}")
return True
def on_pad_added(src, new_pad, sink_element):
sink_pad = sink_element.get_static_pad("sink")
if not sink_pad.is_linked():
new_pad.link(sink_pad)
def callback(pad, info, u_data) -> None:
gst_buffer = info.get_buffer()
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
if obj_meta.class_id == 0:
class_length = 0
l_class = obj_meta.classifier_meta_list
while l_class is not None:
try:
class_meta = pyds.NvDsClassifierMeta.cast(l_class.data)
class_length += 1
l_class = l_class.next
except StopIteration:
break
if class_length == 1:
print("class_id=0 has only 1 classifier result")
l_obj = l_obj.next
break
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def main():
Gst.init(None)
pipeline = Gst.Pipeline.new("pipeline")
nvurisrcbin = Gst.ElementFactory.make("nvurisrcbin", "nvurisrcbin_0")
nvurisrcbin.set_property("gpu-id", 0)
nvurisrcbin.set_property("cudadec-memtype", 0)
nvurisrcbin.set_property("uri", INPUT_SOURCE_URI)
nvurisrcbin.set_property("file-loop", 0)
nvurisrcbin.set_property("drop-frame-interval", 0)
pipeline.add(nvurisrcbin)
nvvideoconvert = Gst.ElementFactory.make("nvvideoconvert", "nvvideoconvert_0")
pipeline.add(nvvideoconvert)
nvurisrcbin.connect("pad-added", on_pad_added, nvvideoconvert)
post_queue_0 = Gst.ElementFactory.make("queue", "post_queue_0")
pipeline.add(post_queue_0)
nvvideoconvert.link(post_queue_0)
streammux = Gst.ElementFactory.make("nvstreammux", "streammux")
streammux.set_property("batch-size", 1)
streammux.set_property("sync-inputs", 0)
pipeline.add(streammux)
srcpad = post_queue_0.get_static_pad("src")
sinkpad = streammux.request_pad_simple("sink_0")
srcpad.link(sinkpad)
preinfer_queue = Gst.ElementFactory.make("queue", "preinfer_queue")
pipeline.add(preinfer_queue)
streammux.link(preinfer_queue)
primary_gie = Gst.ElementFactory.make("nvinfer", "primary_gie")
primary_gie.set_property("unique-id", 1)
primary_gie.set_property("batch-size", 1)
primary_gie.set_property("config-file-path", PGIE_CONFIG_FILE)
primary_gie.set_property("model-engine-file", PGIE_ENGINE_FILE)
pipeline.add(primary_gie)
preinfer_queue.link(primary_gie)
if ENABLE_TRACKER:
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
tracker.set_property("gpu-id", 0)
tracker.set_property("qos", 0)
tracker.set_property("tracker-width", 960)
tracker.set_property("tracker-height", 544)
tracker.set_property("display-tracking-id", 1)
tracker.set_property("ll-lib-file", TRACKER_LIB_FILE)
tracker.set_property("ll-config-file", TRACKER_CONFIG_FILE)
pipeline.add(tracker)
primary_gie.link(tracker)
secondary_gie_1 = Gst.ElementFactory.make("nvinfer", "secondary_gie_1")
secondary_gie_1.set_property("unique-id", 2)
secondary_gie_1.set_property("batch-size", 1)
secondary_gie_1.set_property("config-file-path", SGIE1AND2_CONFIG_FILE)
secondary_gie_1.set_property("model-engine-file", SGIE1AND2_ENGINE_FILE)
pipeline.add(secondary_gie_1)
if ENABLE_TRACKER:
tracker.link(secondary_gie_1)
else:
primary_gie.link(secondary_gie_1)
secondary_gie_2 = Gst.ElementFactory.make("nvinfer", "secondary_gie_2")
secondary_gie_2.set_property("unique-id", 3)
secondary_gie_2.set_property("batch-size", 1)
secondary_gie_2.set_property("config-file-path", SGIE1AND2_CONFIG_FILE)
secondary_gie_2.set_property("model-engine-file", SGIE1AND2_ENGINE_FILE)
pipeline.add(secondary_gie_2)
secondary_gie_1.link(secondary_gie_2)
posttracker_queue = Gst.ElementFactory.make("queue", "posttracker_queue")
pipeline.add(posttracker_queue)
secondary_gie_2.link(posttracker_queue)
identity = Gst.ElementFactory.make("identity", "identity")
pipeline.add(identity)
posttracker_queue.link(identity)
identity.get_static_pad("src").add_probe(Gst.PadProbeType.BUFFER, callback, None)
fakesink = Gst.ElementFactory.make("fakesink", "fakesink")
pipeline.add(fakesink)
identity.link(fakesink)
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus_id = bus.connect("message", on_message, (pipeline, loop))
pipeline.set_state(Gst.State.PLAYING)
print("Pipeline started")
loop.run()
print("Pipeline stopped")
bus.remove_signal_watch()
bus.disconnect(bus_id)
if __name__ == '__main__':
main()
