ONNX fails to load
Description
Running Triton quickstart:
https://docs.nvidia.com/deeplearning/triton-inference-server/user-guide/docs/getting_started/quickstart.html
on a 16GB Jetson Orin with docker command:
docker run --gpus all --runtime=nvidia --rm -p8000:8000 -p8001:8001 -p8002:8002 -v/home/nvidia/server/docs/examples/model_repository:/models nvcr.io/nvidia/tritonserver:23.09-py3 tritonserver --model-repository=/models
Receive:
| densenet_onnx | 1 | UNAVAILABLE: Internal: onnx runtime error 6: Exception during initialization: /workspace/onnxruntime/onnxruntime/core/providers/cuda/cuda_call.cc:121 std::conditional_t<THRW, void, onnxruntime::common::Status> onnxruntime::CudaCall(ERRTYPE, const char*, const char*, ERRTYPE, const char*, const char*, int) [with ERRTYPE = cublasStatus_t; bool THRW = true; std::conditional_t<THRW, void, onnxruntime::common::Status> = void] /workspace/onnxruntime/onnxruntime/co |
| | | re/providers/cuda/cuda_call.cc:114 std::conditional_t<THRW, void, onnxruntime::common::Status> onnxruntime::CudaCall(ERRTYPE, const char*, const char*, ERRTYPE, const char*, const char*, int) [with ERRTYPE = cublasStatus_t; bool THRW = true; std::conditional_t<THRW, void, onnxruntime::common::Status> = void] CUBLAS failure 3: CUBLAS_STATUS_ALLOC_FAILED ; GPU=0 ; hostname=a43d498cbac4 ; file=/workspace/onnxruntime/onnxruntime/core/providers/cuda/cuda_executio |
| | | n_provider.cc ; line=168 ; expr=cublasCreate(&cublas_handle_);
Environment
TensorRT Version: 8.6.2.3
GPU Type:
Nvidia Driver Version:
CUDA Version: 12.2.140
CUDNN Version: 8.9.4.25
Operating System + Version: Jetpack 6 L4T 36.3.0
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Hi @user62193 ,
Request you to reach out to Jetson or Triton Forum for better assistance on the topic.
Thanks. Actually just managed to solve this by using an igpu image!
docker run --gpus=1 --runtime=nvidia --rm -p8000:8000 -p8001:8001 -p8002:8002 -v/home/nvidia/server/docs/examples/model_repository:/models nvcr.io/nvidia/tritonserver:24.05-py3-igpu tritonserver --model-repository=/models --backend-config=tensorrt,–version-compatible=true
