Hi, I’m writing a Fortran code using cuBLAS and cuSPARSE libraries and I need to perform the simple operation of multiplying each vector element with itself.
Since the Hadamard product is not supported in cuBLAS I have to write the accelerator code using OpenACC. Suppose that CPU vector X has the accelerator pointer XP, the following code gives me correct values
i=cuda_memcpy_c2fort_real(X,XP,n*8,2)
!$acc parallel
X(:)=X(:)X(:)
!$acc end parallel
i=cuda_memecpy_fort2c_real(XP,X,n8,1)
Is it possible to avoid moving vector’s values from accelerator to CPU in order to perform the operation in vector X with OpenACC ?
Hi emath,
Just to be clear, “X” is a device array created using CUDA C Malloc or acc_malloc? If so, then yes. Just add “deviceptr(X)” on the parallel directive to tell the compiler that X is a device array. Though, “X” must be a dummy argument and can’t have a pointer, allocatable or value attribute.
!$acc parallel deviceptr(X)
X(:)=X(:)*X(:)
!$acc end parallel
i=cuda_memecpy_fort2c_real(XP,X,n*8,1)
If you’re using a CUDA Fortran “device” array, then you shouldn’t need to do anything. The compiler knows to use the device array in this case.
Alternatively, you can use OpenACC to manage your device data. To pass in the device array to a CUDA routine, use the “host_data” directive:
!$acc host_data use_device(X)
!$acc end host_data
- Mat
Thank you Mat for your reply.
A demo version of the code eliminating cuSPARSE calls can be
use cublas
use cudafor
use openacc
implicit real*8 (a-h,o-z)
parameter (n=1000)
real*8 x(n)
integer*8 xp
do i=1,n
x(i)=dfloat(i)
enddo
is=cuda_malloc(xp,n*8)
is=cuda_memcpy_fort2c_real(xp,x,n*8,1)
call cublas_dscal(n,5.0d0,xp,1)
print*,cublas_dnrm2(n,xp,1)
C ------- OpenACC Region -----------------------------
is=cuda_memcpy_c2fort_real(x,xp,n*8,2)
!$acc parallel deviceptr(x)
x(:)=x(:)*x(:)
!$acc end parallel
is= cuda_memcpy_fort2c_real(xg,x,n*8,1)
C----- End for OpenACC Region --------------------
call cublas_dscal(n,3.0d0,xp,1)
stop
end
As you advise me I added the deviceptr clause in the acc parallel directive, but I get the execution error
Failing in Tread:1
call to cuStreamSyncgronize returned error 700: Illegal address during kernel execution
The compile parameters for 16.1 version are
pgf90 -mcmodel=medium -mp -O4 -acc -Mlarge_arrays -D_CUDAFOR -Minfo=accel -Mcuda=7.0,cc2x
with libraries
-L/opt/pgi/linux86-64/2016/cuda/7.0/lib64 -lcudart -lcublas -lcusparse
Without the deviseptr I get the correct values and I do not know why.
The two cuda_memcpy inside the OpenACC region causes an execution delay ? if so is it possible to avoid them ? or this the optimal way to use openacc with cuBLAS and cuSPARSE at the same time ?
Hi emath,
This is because “x” isn’t a device pointer. “xp” is the device pointer, “x” is a host array that you’re copying data back and forth to the device copy. In this case you’d want to use the OpenACC “acc_map_data” routine to associate x with xp on the device.
Though using straight CUDA Fortran instead of these cuBlas Fortran interface routines, is going to be much simpler and more portable. The following code can be used for both GPUs and CPUs depending upon which flags you use. It could be cleaned up a bit so you don’t have the extra copies in the CPU version.
% cat cblas.F90
#ifdef _CUDA
use cublas
use cudafor
use openacc
#define DEVICE ,device
#else
#define DEVICE
#endif
implicit real(8) (a-h,o-z)
parameter (n=1000)
real(8) :: x(n)
real(8) DEVICE :: xD(n)
do i=1,n
x(i)=dfloat(i)
enddo
xD=x
call dscal(n,5.0d0,xD,1)
print*,dnrm2(n,xD,1)
!$acc parallel
xD(:)=xD(:)*xD(:)
!$acc end parallel
call dscal(n,3.0d0,xD,1)
x=xD
print *, x(100)
stop
end
% pgfortran cblas.F90 -lblas -llapack -o cpu.out
% pgfortran cblas.F90 -Mcuda -acc -Mcudalib=cublas -o gpu.out
% ./cpu.out
91355.55538663207
750000.0000000000
Warning: ieee_inexact is signaling
FORTRAN STOP
% ./gpu.out
91355.55538663207
750000.0000000000
FORTRAN STOP
Hope this helps,
Mat
Mat, you are right about using straight CUDA Fortran in case of using BLAS routines. But I have also to perform sparse matrix vector multiplications. In other words I have also to use the cuSPARSE library. This is the reason of using the cuBLAS and cuSPARSE Fortran interface.
It looks that the acc_map_data subroutine will give me the ability to use OpenACC directives. I have tried to use it in the following demo code
use cublas
use cudafor
use openacc
parameter (n=1000)
real*8 :: x(n)
integer*8 xp
do i=1,n
x(i)=dfloat(i)
enddo
print*,dnrm2(n,x,1)
call acc_map_data(x,xp,n*8)
CCCCCCC OpenACC Region CCCCCCCCCCCCCCCCCCCCCC
c is=cuda_memcpy_c2fort_real(x,xp,n*8,2)
!$acc parallel
x(:)=x(:)*x(:)
!$acc end parallel
c is= cuda_memcpy_fort2c_real(xp,x,n*8,1)
CCCCCCC End for OpenACC Region CCCCCCCCCCCCCCCCCCCCCC
print*,x(100)
stop
end
but I get the compilation error
PGF90-S-0155-Could not resolve generic procedure acc_map_data
A special compiler option is needed ? more than -acc in order to include this API subroutine. Do you think that this is the right use of it and I can remove the to cud_memcpy calls from the OpenACC region ?
My fault. acc_map_data is C only. Let’s try a different tack and use OpenACC to manage your data. Using the “host_data” directive, we can pass the device pointer to the cuBlas routines. I’m still going to use the generic interfaces instead of “cublas_…” since I would need to write my own interfaces for these.
On a side note, we do ship modules for cuSparse that you can use. The modules are included with the CUDA include installation that ship with the compilers. The interface did change from release to release but the compiler will use the correct one depending upon which CUDA version you’re using. I’d recommend using CUDA 7.5 (-Mcuda=cuda7.5) or later since there were some bugs in cuSparse that have been fixed.
Also for array syntax, use “kernels” instead of “parallel” since “kernels” allows the compiler to discover parallelism so will parallelize the implicit loop. With “parallel”, you’re telling the compiler which loops to parallelize. Since there’s no loop here, there’s no parallelism used.
% cat test.f
#ifdef _CUDA
use cublas
use cudafor
use openacc
#endif
parameter (n=1000)
real*8 :: x(n)
!$acc enter data create(x)
!$acc kernels loop
do i=1,n
x(i)=dfloat(i)
enddo
!$acc host_data use_device(x)
print*,dnrm2(n,x,1)
call dscal(n,5.0d0,x,1)
print*,dnrm2(n,x,1)
!$acc end host_data
!$acc kernels present(x)
x(:)=x(:)*x(:)
!$acc end kernels
call dscal(n,3.0d0,x,1)
print*,dnrm2(n,x,1)
!$acc end host_data
!$acc update host (x)
print*,x(100)
!$acc exit data delete(x)
stop
end
Compile for the host:
% pgf90 test.f -Mpreprocess -lblas -llapack; a.out
18271.11107732642
91355.55538663207
1061986052.168206
750000.0000000000
FORTRAN STOP
Compile for the GPU
% pgf90 -acc -Mcuda test.f -Mcudalib=cublas -Mpreprocess ; a.out
18271.11107732642
91355.55538663207
1061986052.168206
750000.0000000000
FORTRAN STOP
Hope this helps,
Mat
It will be a great help for scientists, if PGI creates a cuSPARSE module as the one for cuBLAS and give the opportunity to everyone to write code for CPUGPU applications in Fortran.
Thank you again for your useful comments.
-Manolis
Hi Manolis,
As I note above, we do ship a cuSparse module. It’s located with the CUDA libraries and tools that accompany the PGI compilers. Ideally we could put in the PGI include directory with cuBlas, but since the cuSparse interfaces has changed between different CUDA releases, we had to have different modules depending on the version of cuSPARSE.
- Mat
