I had some problems with runing OpenCl on the newwest version of NVIDIA driver - 195.17 ??
the code throws outsyptic error #-1 during bulding the program…??
the same works fine with the earlier driver version - 190.29
any help would be much appreciated??
thanks
poona
January 12, 2010, 2:22pm
2
thanks
I am running 195.30 on linux. What errors are you having while building the program? There are certain changes with the 195 drivers though, like it was pointed out to by Big_Mac_ here http://forums.nvidia.com/index.php?showtop…mp;#entry979817
thanks
solved,
clBuildProgram was throwing at the cryptic error#-1
this was apparently because of one of the arguments to the kernel, which was not a pointer had a address space specifier (__global)
The weird part, which i don’t understand is that this worked perfectly fine with the older driver (v190.29) ??
any reasons as to why ??
poona
January 13, 2010, 6:20am
4
solved,
Without going into the details of how you specified the kernel arg, the 190.29 accepted many things that were wrong. 195.xx seems to have solved a lot of my issues.
the kernel is somewhat like -
__kernel my_kernel (__global int * myarr1, __global int* myarr2, __global int var1 )
So, the '__global" address space specifier for var1 - was the culprit
the above kernel declaration worked on the 190.29, but throws out an error on the 195.17 !!
changing it to -
__kernel my_kernel (__global int * myarr1, __global int* myarr2, int var1 )
works fine !!
