I’m trying to use OpenCL on Linux using a GTX 260m on kubuntu 10.4 64 bits and I have big performance problems and crashes with both the default driver and the OpenCL 1.1 beta. For example, I have a 100 ms transfer for a 2 Mega pixel image that should take less than 1ms. The kernels are working but are maybe a little bit slower than on Windows. For information, all my code is working on Windows 7 64 bit in the same machine, so it is really a software problem. I also have all the examples in the SDK crashing. Here are some outputs:
~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release$ ./oclBandwidthTest
./oclBandwidthTest Starting…
Segmentation fault
Segmentation fault
:~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release$ ./oclMatrixMul
./oclMatrixMul Starting…
Error: Failed to create OpenCL context!
TEST FAILED !!!
Press to Quit…
As you can see the programs peek the good dll:
julian@tanek:~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release$ ldd ./oclMatrixMul
linux-vdso.so.1 => (0x00007fff07bff000)
libOpenCL.so.1 => /usr/lib/nvidia-current/libOpenCL.so.1 (0x00007ffdeef95000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007ffdeec81000)
libm.so.6 => /lib/libm.so.6 (0x00007ffdee9fd000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007ffdee7e6000)
libc.so.6 => /lib/libc.so.6 (0x00007ffdee463000)
libdl.so.2 => /lib/libdl.so.2 (0x00007ffdee25e000)
/lib64/ld-linux-x86-64.so.2 (0x00007ffdef0bb000)
It is the same OpenCL dll used by my program which is working, slowly but still working.
Any idea?
