Error -6 when creating context, Linux 64 bit, ION Error -6 occurs when creating a context, 64bit Fed
Hello.
I am running Fedora11 64 bit on an Atom330 with an ION chipset. i have the nvdrivers_2.3_linux_64_190.29 installed
oclDeviceQuery passes, returning the following:
oclDeviceQuery.exe Starting...
OpenCL SW Info:
CL_PLATFORM_NAME: 	NVIDIA
 CL_PLATFORM_VERSION: 	OpenCL 1.0
 OpenCL SDK Version: 	4788711
OpenCL Device Info:
1 devices found supporting OpenCL:
 Device ION
  CL_DEVICE_NAME: 			ION
  CL_DEVICE_VENDOR: 			NVIDIA Corporation
  CL_DRIVER_VERSION: 			190.29
  CL_DEVICE_TYPE:			CL_DEVICE_TYPE_GPU
  CL_DEVICE_MAX_COMPUTE_UNITS:		2
  CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS:	3
  CL_DEVICE_MAX_WORK_ITEM_SIZES:	512 / 512 / 64
  CL_DEVICE_MAX_WORK_GROUP_SIZE:	512
  CL_DEVICE_MAX_CLOCK_FREQUENCY:	1100 MHz
  CL_DEVICE_ADDRESS_BITS:		32
  CL_DEVICE_MAX_MEM_ALLOC_SIZE:		128 MByte
  CL_DEVICE_GLOBAL_MEM_SIZE:		61 MByte
  CL_DEVICE_ERROR_CORRECTION_SUPPORT:	no
  CL_DEVICE_LOCAL_MEM_TYPE:		local
  CL_DEVICE_LOCAL_MEM_SIZE:		16 KByte
  CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE:	64 KByte
  CL_DEVICE_QUEUE_PROPERTIES:		CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
  CL_DEVICE_QUEUE_PROPERTIES:		CL_QUEUE_PROFILING_ENABLE
  CL_DEVICE_IMAGE_SUPPORT:		1
  CL_DEVICE_MAX_READ_IMAGE_ARGS:	128
  CL_DEVICE_MAX_WRITE_IMAGE_ARGS:	8
CL_DEVICE_IMAGE <dim>			2D_MAX_WIDTH	 8192
					2D_MAX_HEIGHT	 8192
					3D_MAX_WIDTH	 2048
					3D_MAX_HEIGHT	 2048
					3D_MAX_DEPTH	 2048
CL_DEVICE_EXTENSIONS:			cl_khr_byte_addressable_store
					cl_nv_compiler_options
					cl_nv_device_attribute_query
					cl_khr_global_int32_base_atomics
					cl_khr_global_int32_extended_atomics
CL_NV_DEVICE_COMPUTE_CAPABILITY:	1.1
  CL_NV_DEVICE_REGISTERS_PER_BLOCK:	8192
  CL_NV_DEVICE_WARP_SIZE:		32
  CL_NV_DEVICE_GPU_OVERLAP:		CL_FALSE
  CL_NV_DEVICE_KERNEL_EXEC_TIMEOUT:	CL_TRUE
  CL_NV_DEVICE_INTEGRATED_MEMORY:	CL_TRUE
  CL_DEVICE_PREFERRED_VECTOR_WIDTH_<t>	CHAR 1, SHORT 1, INT 1, FLOAT 1, DOUBLE 1
oclDeviceQuery, Platform Name = NVIDIA, Platform Version = OpenCL 1.0 , SDK Version = 4788711, NumDevs = 1, Device = ION
System Info:
Local Time/Date =  14:36:19, 10/19/2009
 CPU Name: Intel(R) Atom(TM) CPU 330 @ 1.60GHz
 # of CPU processors: 4
 Linux version 2.6.30.8-64.fc11.x86_64 (mockbuild@x86-5.fedora.phx.redhat.com) (gcc version 4.4.1 20090725 (Red Hat 4.4.1-2) (GCC) ) #1 SMP Fri Sep 25 04:43:32 EDT 2009
TEST PASSED
Press <Enter> to Quit...
However that’s the only success I get :(
oclBandwidthTest fails, as do oclConvolutionSeparable and oclNbody
./oclBandwidthTest Starting...
Running on...
Device ION
 Quick Mode
Failed to create OpenCL context!
TEST FAILED !!!
./oclConvolutionSeparable Starting...
Allocating and initializing host memory...
Initializing OpenCL...
!!! Error # -6 at line 59 , in file src/main.cpp !!!
Exiting...
./oclNbody Starting...
!!! Error # -6 at line 178 , in file src/oclNbody.cpp !!!
Starting Cleanup...
oclNbody.exe Exiting...
Each time I am unable to create a context. Can someone help me with this please.
-6 is CL_OUT_OF_HOST_MEMORY. However, what I suspect is that the error happens in the first clGetContextInfo() call (one that is fetching the amount of memory needed for storing IDs for available devices), in both SDK examples, so I would try with checking error immediately after this call.
I have a test program where the first thing I do is create a context via clCreateContextFromType(0, CL_DEVIDE_TYPE_GPU, NULL, NULL, &ciErrNum) and that returns -6. I never get to call clGetContextInfo
