OpenCV 3.1 compilation on TX1 - let's collect the
Hi everybody
we all know that opencv4tegra shipped with TX1 has some TX1-specific optimizations, but also that it is lacking some features that strongly limit its usability: amongst the firsts, no opengl support, no gstreamer support meaning no hardware acceleration for encoding/decoding. These alone are showstoppers for many application scenarios, expecially for those NOT using the embedded camera on the development board.
Recompiling OpenCV (3.1 in particular) is an option but here’s where things get confusing. I have compiled it successfully on TX1 with gstreamer support, but I have been unable to add opengl support and I have been unable to obtain a GPU module, as opposite to opencv4tegra. I am also unsure about generic cpu/gpu acceleration of opencv algorithms.
This seems a recurring theme for TK1/TX1 users, see for example here: https://devtalk.nvidia.com/default/topic/907780/jetson-tx1/-python-how-to-use-tx1-camera-with-opencv/ or here https://devtalk.nvidia.com/default/topic/917386/jetson-tx1/usb-3-0-port-unstable-on-jetson-tx1-/1 but many other similar posts are present.
So, in my opinion it would really be useful to clarify the matter and try to get a sticky post or an addendum to manuals, hopefully with some intervention from nVidia, where it is clearly stated:
  • TX1-specific features that it is possible to get by recompiling OpenCV 3.1 (and related CMake settings), with focus on CPU, GPU settings and hardware acceleration for encoding/decoding.
  • TX1-specific features that it is NOT possible to get at the moment
  • a clear feature comparison table between opencv4tegra and opencv3.1
The goal is to have the “definitive” CMake line for anybody willing to give OpenCV 3.1 a try without missing any important feature and using the “state-of-the-art”.
To have a starting point, here are three topics
  1. for TX1, is it correct to use "5.3" arch_bin instead as suggested here?
  2. -DWITH_CUDA=ON -DCUDA_ARCH_BIN="<b>5.3</b>" -DCUDA_ARCH_PTX=""
  3. is "FAST_MATH" needed? What will it provide?
  4. DCUDA_FAST_MATH=ON
  5. Enabling OpenGL seems to have no effect on the CMake configuration printout you get at the end of CMake run. I still got "GUI OpenGL support = OFF". Did anyone have the same experience?
  6. -DWITH_OPENGL=ON
Thanks to anybody willing to contribute.
Cheers
Hi there, perhaps the following guide to compiling OpenCV on Tegra from GitHub may be useful in some way:
https://github.com/dusty-nv/jetson-scripts/blob/master/Building-O4T.md
Hello Dusty,
Out of curiosity, why do you not include NEON instructions from your recommended configuration on the TX1?
  • Mark
Hi Dusty
thanks for your support. Is there a reason for not including gstreamer support? If I compile including it, will I get h.264/265 hardware acceleration for encoding/decoding through cv::VideoWriter("") API?
Giacomo
Hmm it looks like NEON on TK1 is enabled in the script:
-DENABLE_NEON=ON
However for TX1 it is precluded. Perhaps it is related to ARMv8 defining NEON as an inherently supported and gcc -mfpu=neon is no longer an option, meaning this CC flag would need removed from openCV makefile. You could try adding in -DENABLE_NEON=ON on TX1 and see if it builds.
At the time I think the gstreamer support may not have been required in the example script posted above, however you should be able to compile with it enabled I believe.
I can answer some of the earlier questions by @benelgiac, so let me contribute here:
  1. What does “-DCUDA_FAST_MATH=ON” do? I believe by defining this flag, the GPU accelerated OpenCV code would use intrinsic math functions which run faster but are slightly less accurate (reference: http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#intrinsic-functions). I’d consider this a useful feature to turn on in OpenCV.
  2. I think GStreamer support would be enabled in OpenCV if you install the following 2 packages before doing cmake. More specifically, after installing these 2 packages cmake would configure OpenCV to integrate Gstreamer pipeline support automatically.
$ sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
  1. OpenGL in OpenCV would require Qt as the backend. So you’ll need to install the following for OpenGL support to work. Note this should be also done before doing cmake.
$ sudo apt-get install qtbase5-dev
This link is no longer available. I would be interested in the cmake settings, too.
Hi maxinho, here are the contents:
## This Document
What this document is: This document is a basic guide to building the OpenCV libraries with CUDA support for use in the Tegra environment. It will cover the basic elements of building the version 3.1.0 libraries from source code for four different platforms:
* Linux4Tegra Jetson (L4T)
* Desktop Linux (Ubuntu 14.04LTS and 16.04LTS)
* Microsoft Windows (8)
What this document is not: This document is not an exhaustive guide to all of the options available when building OpenCV. Specifically, it will cover the basic options used when building each platform but will not cover any options that are not needed (or are unchanged from their default values). Additionally, the installation of the CUDA toolkit is not covered here.
This document is focused on building the 3.1.0 version of OpenCV, but the guidelines here should also work for building from the "master" branch of the git repository. There are differences in some of the CMake options for builds of the 2.4.13 version of OpenCV, which are summarized below in the "Building OpenCV 2.4.X" section.
Most of the configuration commands are based on the system having CUDA 8.0 installed. In some cases, an older CUDA is used because 8.0 is not supported for that platform.
## Native Compilation vs. Cross-Compilation
The OpenCV build system supports native compilation for all the supported platforms, as well as cross-compilation for platforms such as ARM and others. The native compilation process is simpler, whereas the cross-compilation is generally faster.
At the present time, this document will focus only on native compilation.
## Getting the Source Code
There are two ways to get the OpenCV source code: direct download from the [OpenCV downloads](http://opencv.org/downloads.html) page, or by cloning the git repositories hosted on [GitHub](https://github.com/opencv).
For this guide, the focus will be on using the git repositories. This is because the 3.1.0 version of OpenCV will not build with CUDA 8.0 without applying a small upstream change from the repository.
### OpenCV
Start with the `opencv` repository:
    # Clone the opencv repository locally:
    $ git clone https://github.com/opencv/opencv.git
To build the 3.1.0 version (as opposed to building the most-recent source), you will need to check out a branch based on the `3.1.0` tag:
    $ cd opencv
    $ git checkout -b v3.1.0 3.1.0
Note that this operation will create a new local branch in your clone's repository.
If you will be building OpenCV with CUDA 8.0, you will need to execute one additional git command. This is to apply a fix for building specifically with the 8.0 version of CUDA that was not part of the 3.1.0 release. To do this, you will use the "git cherry-pick" command:
    # While still in the opencv directory:
    $ git cherry-pick 10896
You should see the following output from the command:
    [v3.1.0 d6d69a7] GraphCut deprecated in CUDA 7.5 and removed in 8.0
     Author: Vladislav Vinogradov <vlad.vinogradov@itseez.com>
     1 file changed, 2 insertions(+), 1 deletion(-)
This step is not needed if you are building with CUDA 7.0 or 7.5.
### OpenCV Extra
The `opencv_extra` repository contains extra data for the OpenCV library, including the data files used by the tests and demos. It must be cloned separately:
    # In the same base directory from which you cloned opencv:
    $ git clone https://github.com/opencv/opencv_extra.git
As with the OpenCV source you will need to use the same method as above to set the source tree to the 3.1.0 version. When you are building from a specific tag, both repositories should be checked out at that tag.
    $ cd opencv_extra
You may opt to not fetch this repository if you do not plan on running the tests or installing the test-data along with the samples and example programs. If it is not referenced in the invocation of CMake or the running of tests, it will not be used. Note that some tests expect the data to be present, and will fail without it.
### Building on Microsoft Windows
If you are building 3.1.0 on a Microsoft Windows platform, there is one additional step needed. The Windows build includes the `opencv_world` module, which fails to build at the 3.1.0 tag. Run the following command in the directory of the `opencv` repository:
    C:\opencv-build\opencv>git cherry-pick c8ff7
You should see output like this from the command:
    [v3.1.0 fdf6d4b] build: fix opencv_world with CUDA
     Author: Alexander Alekhin <alexander.alekhin@itseez.com>
     4 files changed, 9 insertions(+), 19 deletions(-)
This is not necessary for any of the other platforms, as they do not use the `opencv_world` module.
## Preparation and Prerequisites
To build OpenCV, you will need a directory in which to create the configuration and build the libraries. You will also need a number of 3rd-party libraries upon which OpenCV depends.
### Prerequisites for Ubuntu Linux
These are the basic requirements for building OpenCV for Tegra on Linux:
* CMake 2.8.10 or newer
* CUDA toolkit 7.0 or newer
* Build tools (make, gcc, g++)
* Python 2.6 or greater
These are the same regardless of the platform (Drive PX2, Desktop, etc.).
A number of development packages are required for building on Linux:
* libglew-dev
* libtiff5-dev
* zlib1g-dev
* libjpeg-dev
* libpng12-dev
* libjasper-dev
* libavcodec-dev
* libavformat-dev
* libavutil-dev
* libpostproc-dev
* libswscale-dev
* libeigen3-dev
* libtbb-dev
* libgtk2.0-dev
* pkg-config
Some of the packages above are in the `universe` repository for Ubuntu Linux systems. If you have not already enabled that repository, you will need to do the following before trying to install all of the packages listed above:
    sudo apt-add-repository universe
    sudo apt-get update
If you want the Python bindings to be built, you will also need the appropriate packages for either or both of Python 2 and Python 3:
* python-dev / python3-dev
* python-numpy / python3-numpy
* python-py / python3-py
* python-pytest / python3-pytest
Once all the necessary packages have been installed, you can configure the build.
### Prerequisites for Microsoft Windows
### Preparing the build area
For configuring and building OpenCV, create a directory called "build" in the same base directory into which you cloned the git repositories:
    $ mkdir build
    $ cd build
You are now ready to configure and build OpenCV.
## Jetson L4T Compilation
> Supported platforms: Jetson TK-1, Jetson TX-1
As with V4L, the configuration options given to `cmake` below are targeted towards the functionality needed for Tegra. They are based on the original configuration options used for building OpenCV 2.4.13 on Jetson.
### Configuring
Configuration is slightly different for the Jetson TK-1 and the Jetson TX-1 systems.
#### Jetson TK-1 Configuration
For Jetson TK-1, the following invocation of CMake is recommended:
    $ cmake \
        -DCMAKE_BUILD_TYPE=Release \
        -DCMAKE_INSTALL_PREFIX=/usr \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_JASPER=OFF \
        -DBUILD_ZLIB=OFF \
        -DBUILD_EXAMPLES=ON \
        -DBUILD_opencv_java=OFF \
        -DBUILD_opencv_python2=ON \
        -DBUILD_opencv_python3=OFF \
        -DENABLE_NEON=ON \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_GSTREAMER=OFF \
        -DWITH_GSTREAMER_0_10=OFF \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        -DWITH_OPENEXR=OFF \
        -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-6.5 \
        -DCUDA_ARCH_BIN=3.2 \
        -DCUDA_ARCH_PTX="" \
        -DINSTALL_C_EXAMPLES=ON \
        -DINSTALL_TESTS=ON \
        -DOPENCV_TEST_DATA_PATH=../opencv_extra/testdata \
        ../opencv
Note that this uses CUDA 6.5, not 8.0.
#### Jetson TX-1 Configuration
For Jetson TX-1, the following invocation of CMake is recommended:
    $ cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DENABLE_PRECOMPILED_HEADERS=OFF \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-8.0 \
        -DCUDA_ARCH_BIN=5.3 \
        ../opencv
Note that this configuration does not include the `ENABLE_NEON` parameter.
### Building
Once the `cmake` command has completed, your `build` directory should be ready to go:
    $ make -j6
### Testing
The OpenCV package comes with an extensive set of tests. To run the tests, you need only execute:
    $ make test
If you fetched the `opencv_extra` repository for the test data, it will be necessary to specify the path to that test data:
    # For bash:
    $ OPENCV_TEST_DATA_PATH=../opencv_extra/testdata make test
    # For csh/tcsh:
    $ setenv OPENCV_TEST_DATA_PATH ../opencv_extra/testdata
    $ make test
Note that some of the tests are dependent on the test data from `opencv_extra`, and will fail without it.
### Installing
Installing OpenCV requires only:
    # From within the "build" directory:
    $ make install
(It may be necessary to use "sudo" for root privileges, depending on the location being installed to.)
This will install the OpenCV libraries and header files, as well as the tests and samples.
## Ubuntu Desktop Linux Compilation
> Supported platforms: Ubuntu Desktop Linux 14.04LTS, Ubuntu Desktop Linux 16.04LTS
The configuration options given to `cmake` below are targeted towards the functionality needed for Tegra. For a desktop system, you may wish to adjust some options to enable (or disable) certain features. The features enabled below are based on the building of OpenCV 2.4.13.
### Configuring
For Desktop Ubuntu, the recommended invocation of CMake is:
    $ cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        ../opencv
This configuration is basically identical to that for V4L and L4T, except that it does not pass the `ENABLE_NEON` or `CUDA_ARCH_BIN` parameters. The `ENABLE_NEON` parameter controls the the use of NEON SIMD extensions. The `CUDA_ARCH_BIN` parameter specifies the CUDA architectures that the installed NVIDIA board supports. For a desktop this is dependent on the card you have installed, so CMake will instead run a small test program that probes for the supported architectures.
As with previous examples, the configuration given above will build the Python bindings for Python 2 (but not Python 3) as part of the build process.
### Building
Building is the same as for the previous examples:
    $ make
As before, you may wish to allow make to use parallel processing:
    # Execute with as many as 7 jobs in parallel:
    $ make -j7
### Testing
Run the tests as in the previous examples:
    $ make test
Or (if you have the test data):
    # For bash:
    # For csh/tcsh:
    $ make test
Again, note that some tests are dependent on data from the `opencv_extra` repository.
### Installing
Install as with other examples:
    $ make install
## Microsoft Windows Desktop Compilation
(this section still in development)
### Tools
To build OpenCV with CUDA support, you will need the Microsoft Visual Studio C/C++ compilers. While you can build most of OpenCV with other compilers, code that links with the CUDA libraries must be built with MSVC.
Additionally, building OpenCV on Microsoft Windows uses the [Ninja build tool](https://ninja-build.org/) in conjunction with CMake. You can find a Windows version on their [releases](https://github.com/ninja-build/ninja/releases) page, in the form of a ZIP archive file.
### Configuring
    C:\opencv-build\build>cmake \
        -GNinja \
        -DWITH_OPENCL=OFF \
        -DBUILD_SHARED_LIBS=ON \
        -DBUILD_TESTS=ON \
        -DBUILD_opencv_python2=OFF \
        -DBUILD_PERF_TESTS=ON \
        -DWITH_FFMPEG=ON \
        -DINSTALL_CREATE_DISTRIB=ON \
        -DENABLE_SSE=ON \
        -DENABLE_SSE2=ON \
        -DWITH_CUDA=ON \
        "-DCUDA_TOOLKIT_ROOT_DIR=C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v8.0" \
        -DWITH_MSMF=OFF \
        -DWITH_TBB=OFF \
        -DWITH_1394=OFF \
        -DWITH_VFW=OFF \
        -DBUILD_DOCS=OFF \
        -DBUILD_EXAMPLES=OFF \
        -DWITH_VTK=OFF \
        -DOPENCV_TEST_DATA_PATH=..\opencv_extra\testdata \
        ..\opencv
## Building OpenCV 2.4.X
If you wish to build your own version of the 2.4 version of OpenCV, there are only a few adjustments that need to be made. At the time of writing this, the latest version on the 2.4 tree is 2.4.13. These instructions should work for later versions of 2.4 (though they have not been tested for any earlier versions).
### Selecting the 2.4 source
First you will need to select the correct source branch or tag. If you want a specific version such as 2.4.13, you will want to make a local branch based on the tag, as was done with the 3.1.0 tag above:
    # Within the opencv directory:
    $ git checkout -b v2.4.13 2.4.13
    # Within the opencv_extra directory:
If you simply want the newest code from the 2.4 line of OpenCV, there is a `2.4` branch already in the repository. You can check that out instead of a specific tag:
    $ git checkout 2.4
### Configuring
Configuring is done with CMake as before. The primary difference is that OpenCV 2.4 only provides Python bindings for Python 2, and thus does not distinguish between Python 2 and Python 3 in the CMake parameters. There is just the one parameter, `BUILD_opencv_python`. In addition, there is a build-related parameter that controls features in 2.4 that are not in 3.1.0. This parameter is `BUILD_opencv_nonfree`.
Configuration still takes place in a separate directory that should be a sibling to the `opencv` and `opencv_extra` directories.
#### Configuring Vibrante V4L
For Drive PX2:
    cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DBUILD_opencv_nonfree=OFF \
        -DBUILD_opencv_python=ON \
        -DENABLE_NEON=ON \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        -DCUDA_ARCH_BIN=6.2 \
        ../opencv
#### Configuring Jetson L4T
For Jetson TK-1:
    cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DENABLE_NEON=ON \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        ../opencv
For Jetson TX-1:
    cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        ../opencv
#### Configuring Desktop Ubuntu Linux
For both of 14.04LTS and 16.04LTS:
    cmake \
        -DBUILD_PNG=OFF \
        -DBUILD_TIFF=OFF \
        -DBUILD_TBB=OFF \
        -DBUILD_JPEG=OFF \
        -DBUILD_ZLIB=OFF \
        -DWITH_OPENCL=OFF \
        -DWITH_FFMPEG=ON \
        -DWITH_CUDA=ON \
        -DWITH_GTK=ON \
        -DWITH_VTK=OFF \
        -DWITH_TBB=ON \
        -DWITH_1394=OFF \
        ../opencv
#### Configuring Microsoft Windows
For Windows:
    cmake \
        -GNinja \
        -DWITH_OPENCL=OFF \
        -DBUILD_TESTS=ON \
        -DBUILD_opencv_python=OFF \
        -DWITH_FFMPEG=ON \
        -DENABLE_SSE=ON \
        -DENABLE_SSE2=ON \
        -DWITH_CUDA=ON \
        -DWITH_MSMF=OFF \
        -DWITH_TBB=OFF \
        -DWITH_1394=OFF \
        -DWITH_VFW=OFF \
        -DBUILD_DOCS=OFF \
        -DWITH_VTK=OFF \
        ..\opencv
### Building, Testing and Installing
Once configured, the steps of building, testing and installing should be the same as above for the 3.1.0 source.
## CMake Parameter Reference
Below is a table of all the parameters passed to CMake in the recommended invocations above. Some of these are parameters from CMake itself, while most are specific to OpenCV.
|Parameter|Our default value|What it does|Notes|
|BUILD_EXAMPLES|ON|Governs whether the C/C++ examples are built||
|BUILD_JASPER|OFF|Governs whether the Jasper library (`libjasper`) is built from source in the `3rdparty` directory||
|BUILD_JPEG|OFF|As above, for `libjpeg`||
|BUILD_PNG|OFF|As above, for `libpng`||
|BUILD_TBB|OFF|As above, for `tbb`||
|BUILD_TIFF|OFF|As above, for `libtiff`||
|BUILD_ZLIB|OFF|As above, for `zlib`||
|BUILD_opencv_java|OFF|Controls the building of the Java bindings for OpenCV|Building the Java bindings requires OpenCV libraries be built for static linking only|
|BUILD_opencv_nonfree|OFF|Controls the building of non-free (non-open-source) elements|Used only for building 2.4.X|
|BUILD_opencv_python|ON|Controls the building of the Python 2 bindings in OpenCV 2.4.X|Used only for building 2.4.X|
|BUILD_opencv_python2|ON|Controls the building of the Python 2 bindings in OpenCV 3.1.0|Not used in 2.4.X|
|BUILD_opencv_python3|OFF|Controls the building of the Python 3 bindings in OpenCV 3.1.0|Not used in 2.4.X|
|CMAKE_BUILD_TYPE|Release|Selects the type of build (release vs. development)|Is generally either `Release` or `Debug`|
|CMAKE_INSTALL_PREFIX|/usr|Sets the root for installation of the libraries and header files||
|CUDA_ARCH_BIN|(varies)|Sets the CUDA architecture(s) for which code is compiled|Only passed for platforms with known specific cards|
|CUDA_ARCH_PTX|""|Specify virtual PTX architectures to build PTX intermediate code for|Here, used only for Microsoft Windows|
|CUDA_TOOLKIT_ROOT_DIR|/usr/local/cuda-8.0 (for Linux)|Specifies the location of the CUDA include files and libraries||
|ENABLE_NEON|ON|Enables the use of NEON SIMD extentions for ARM chips|Only passed for builds on ARM platforms|
|ENABLE_PRECOMPILED_HEADERS|OFF|Enable/disable support for pre-compiled headers|Only specified on some of the ARM platforms|
|INSTALL_C_EXAMPLES|ON|Enables the installation of the C example files as part of `make install`||
|INSTALL_TESTS|ON|Enables the installation of the tests as part of `make install`||
|OPENCV_TEST_DATA_PATH|../opencv_extra/testdata|Path to the `testdata` directory in the `opencv_extra` repository clone||
|WITH_1394|OFF|Whether to include IEEE-1394 support||
|WITH_CUDA|ON|Whether to include CUDA support||
|WITH_FFMPEG|ON|Whether to include FFMPEG support||
|WITH_GSTREAMER|OFF|Whether to include GStreamer 1.0 support||
|WITH_GSTREAMER_0_10|OFF|Whether to include GStreamer 0.10 support||
|WITH_GTK|ON|Whether to include GTK 2.0 support|Only given on Linux platforms, not Microsoft Windows|
|WITH_OPENCL|OFF|Whether to include OpenCL Runtime support||
|WITH_OPENEXR|OFF|Whether to include ILM support via OpenEXR||
|WITH_TBB|ON|Whether to include Intel TBB support||
|WITH_VTK|OFF|Whether to include VTK support||
Dear Dusty,
I was attempting to follow the directions provided to compile OpenCV on Tegra from GitHub and I get the following error message after running: git cherry-pick 10896
error: Your local changes would be overwritten by cherry-pick.
hint: Commit your changes or stash them to proceed.
fatal: cherry-pick failed
Any idea why that would happen?
I was successful in running/using opencv4tegra but as benelgiac mentioned, I do need the OpenGl support.
Thanks for your help,
Zahi
There is also the new tutorial on installing OpenCV on Tegra platforms by Randy J. Ray: http://docs.opencv.org/master/d6/d15/tutorial_building_tegra_cuda.html
Zahi,
Were you ever able to address this issue? I’m getting the same error when I try to execute the cherry-pick. Would love any help solving this problem.
-Harris
Dear Harris,
The solution was simple, but I had done it a long while back.
I believe all I had to do was to act as if stashing changes (I had not done any changes of course), so just try: “git stash”
Hope this helps you out,
Zahi
Dear Harris,
Zahi
Zahi,
A simple solution indeed. I had to resolve a few conflicts in my case, so I simply resolved them to include the changes from the cherry-picked commit and added them to the staging area then ran
git cherry-pick --continue
. Thanks for your prompt reply!
-Harris
Hi Guys,
I am trying to find an optimized version of “findContours” OpenCV function. I intend to this in a real-time application. I am currently using OpenCV 3.1 on TX1. Is there OpenCV4Tegra version for OpenCV 3.1 or any specific instructions to build OpenCV specifically for optimized performance on TX1 platform.
Kindly help me out.
Hi lamegeorge,
Here are some cmake configuration from other users. Although it is from 3.3, I think most of them can be worked on opencv3.1.
-- General configuration for OpenCV 3.3.0 =====================================
--   Version control:               unknown
--   Platform:
--     Timestamp:                   2017-09-22T04:46:20Z
--     Host:                        Linux 4.4.38-tegra aarch64
--     CMake:                       3.5.1
--     CMake generator:             Unix Makefiles
--     CMake build tool:            /usr/bin/make
--     Configuration:               RELEASE
--   CPU/HW features:
--     Baseline:                    NEON FP16
--       required:                  NEON
--       disabled:                  VFPV3
--   C/C++:
--     Built as dynamic libs?:      YES
--     C++ Compiler:                /usr/bin/c++  (ver 5.4.0)
--     C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
--     C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
--     C Compiler:                  /usr/bin/cc
--     C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
--     C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
--     Linker flags (Release):
--     Linker flags (Debug):
--     ccache:                      NO
--     Precompiled headers:         YES
--     Extra dependencies:          gtk-3 gdk-3 pangocairo-1.0 pango-1.0 atk-1.0 cairo-gobject cairo gdk_pixbuf-2.0 gio-2.0 gthread-2.0 /usr/lib/aarch64-linux-gnu/libpng.so /usr/lib/aarch64-linux-gnu/libz.so /usr/lib/aarch64-linux-gnu/libtiff.so /usr/lib/aarch64-linux-gnu/libjasper.so /usr/lib/aarch64-linux-gnu/libjpeg.so gstbase-1.0 gstreamer-1.0 gobject-2.0 glib-2.0 gstvideo-1.0 gstapp-1.0 gstriff-1.0 gstpbutils-1.0 dc1394 v4l1 v4l2 avcodec-ffmpeg avformat-ffmpeg avutil-ffmpeg swscale-ffmpeg dl m pthread rt cudart nppc nppi npps cublas cufft -L/usr/local/cuda-8.0/lib64
--     3rdparty dependencies:
--   OpenCV modules:
--     To be built:                 cudev core cudaarithm flann imgproc ml objdetect video cudabgsegm cudafilters cudaimgproc cudawarping dnn imgcodecs photo shape videoio cudacodec highgui features2d calib3d cudafeatures2d cudalegacy cudaobjdetect cudaoptflow cudastereo stitching superres videostab python2 python3
--     Disabled:                    world
--     Disabled by dependency:      -
--     Unavailable:                 java ts viz
--   GUI:
--     QT:                          NO
--     GTK+ 3.x:                    YES (ver 3.18.9)
--     GThread :                    YES (ver 2.48.2)
--     GtkGlExt:                    NO
--     OpenGL support:              NO
--     VTK support:                 NO
--   Media I/O:
--     ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
--     JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
--     WEBP:                        build (ver encoder: 0x020e)
--     PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
--     TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 - 4.0.6)
--     JPEG 2000:                   /usr/lib/aarch64-linux-gnu/libjasper.so (ver 1.900.1)
--     OpenEXR:                     build (ver 1.7.1)
--     GDAL:                        NO
--     GDCM:                        NO
--   Video I/O:
--     DC1394 1.x:                  NO
--     DC1394 2.x:                  YES (ver 2.2.4)
--     FFMPEG:                      YES
--       avcodec:                   YES (ver 56.60.100)
--       avformat:                  YES (ver 56.40.101)
--       avutil:                    YES (ver 54.31.100)
--       swscale:                   YES (ver 3.1.101)
--       avresample:                NO
--     GStreamer:
--       base:                      YES (ver 1.8.3)
--       video:                     YES (ver 1.8.3)
--       app:                       YES (ver 1.8.3)
--       riff:                      YES (ver 1.8.3)
--       pbutils:                   YES (ver 1.8.3)
--     OpenNI:                      NO
--     OpenNI PrimeSensor Modules:  NO
--     OpenNI2:                     NO
--     PvAPI:                       NO
--     GigEVisionSDK:               NO
--     Aravis SDK:                  NO
--     UniCap:                      NO
--     UniCap ucil:                 NO
--     V4L/V4L2:                    Using libv4l1 (ver 1.10.0) / libv4l2 (ver 1.10.0)
--     XIMEA:                       NO
--     Xine:                        NO
--     Intel Media SDK:             NO
--     gPhoto2:                     NO
--   Parallel framework:            pthreads
--   Trace:                         YES ()
--   Other third-party libraries:
--     Use Intel IPP:               NO
--     Use Intel IPP IW:            NO
--     Use VA:                      NO
--     Use Intel VA-API/OpenCL:     NO
--     Use Lapack:                  NO
--     Use Eigen:                   YES (ver 3.2.92)
--     Use Cuda:                    YES (ver 8.0)
--     Use OpenCL:                  YES
--     Use OpenVX:                  NO
--     Use custom HAL:              YES (carotene (ver 0.0.1))
--   NVIDIA CUDA
--     Use CUFFT:                   YES
--     Use CUBLAS:                  YES
--     USE NVCUVID:                 NO
--     NVIDIA GPU arch:             62
--     NVIDIA PTX archs:
--     Use fast math:               YES
--   OpenCL:                        <Dynamic loading of OpenCL library>
--     Include path:                /home/nvidia/src/opencv-3.3.0/3rdparty/include/opencl/1.2
--     Use AMDFFT:                  NO
--     Use AMDBLAS:                 NO
--   Python 2:
--     Interpreter:                 /usr/bin/python2.7 (ver 2.7.12)
--     Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
--     numpy:                       /usr/local/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.1)
--     packages path:               lib/python2.7/dist-packages
--   Python 3:
--     Interpreter:                 /usr/bin/python3 (ver 3.5.2)
--     Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.5m.so (ver 3.5.2)
--     numpy:                       /usr/local/lib/python3.5/dist-packages/numpy/core/include (ver 1.13.1)
--     packages path:               lib/python3.5/dist-packages
--   Python (for build):            /usr/bin/python2.7
--   Java:
--     ant:                         NO
--     JNI:                         NO
--     Java wrappers:               NO
--     Java tests:                  NO
--   Matlab:                        Matlab not found or implicitly disabled
--   Documentation:
--     Doxygen:                     NO
--   Tests and samples:
--     Tests:                       NO
--     Performance tests:           NO
--     C/C++ Examples:              NO
--   Install path:                  /usr/local
--   cvconfig.h is in:              /home/nvidia/src/opencv-3.3.0/build
-- Configuring done
-- Generating done
-- Build files have been written to: /home/nvidia/src/opencv-3.3.0/build
Hi
thanks everybody for periodically updating this post. My turn: based on the script to compile OpenCV3.1 on Jetson published by JetsonHacks(http://www.jetsonhacks.com/2017/09/05/build-opencv-on-the-nvidia-jetson-tx1/) I’ve just successfully compiled OpenCV 3.4, with Jetson settings, Python2 and 3 support, and including also the opencv_contrib repository that nobody seem to include ever, but that includes interesting algorithm (tracking, to mention one).
It’s just a few modifications, you can check those out here (https://github.com/jetsonhacks/buildOpenCVTX1/pull/1).
Hope this helps
Cheers
Giacomo
