opencv compilation error
i try to compile a code that include opencv function and i get always “fatal error: blabla.hpp: No such file or directory” error. I can compile the same code in my machine and it run without an error. when i try to compile the same code in nvidia tx2 and i also use same Makefile, i get error. I reinstall opencv and the problem still remain.
Not sure if Build OpenCV on the NVIDIA Jetson TX2 - JetsonHacks, included in Jetson TX2 - eLinux.org, is still valid.
after you write the answer, i did it. It didnt work either. I get the same error
It seems a header file cannot be found on the Jetson.
Do you which version of opencv is installed on your host, and which version is installed on your Jetson ?
Could you precise which header file is not found (blabla.hpp doesn’t help), and how it is included (ex: #include “opencv2/opencv.hpp”) ?
Could you precise how you try to compile ?
If you are using opencv4tegra that is installed in /usr, then compiling with -I/usr/include should be enough for finding the opencv headers.
I solved the problem. I run this script “buildOpenCVTX2/buildOpenCV.sh at master · jetsonhacks/buildOpenCVTX2 · GitHub”. i forgot to run “make install” command. After the command it works fine. Thanks.
