I compiled opencv 3.4.1 on jetson nano,the build info in the below.
but ,I write a sample c++ code to use check envirment it tell INCOMPATIBLE.
General configuration for OpenCV 3.4.1 =====================================
Version control: unknown
Extra modules:
Location (extra): /root/opencv_contrib-3.4.1/modules
Version control (extra): unknown
Platform:
Timestamp: 2019-09-23T16:53:13Z
Host: Linux 4.9.140-tegra aarch64
CMake: 3.10.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: Release
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++11: YES
C++ Compiler: /usr/bin/c++ (ver 7.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: NO
Extra dependencies: dl m pthread rt /usr/lib/aarch64-linux-gnu/libtbb.so cudart nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda-10.0/lib64
3rdparty dependencies:
OpenCV modules:
To be built: aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dpm face features2d flann freetype fuzzy hfs highgui img_hash imgcodecs imgproc java_bindings_generator line_descriptor ml objdetect optflow phase_unwrapping photo plot python2 python_bindings_generator reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking ts video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
Disabled: js python3 world
Disabled by dependency: -
Unavailable: cnn_3dobj cvv dnn_modern hdf java matlab ovis sfm viz
Applications: tests perf_tests apps
Documentation: NO
Non-free algorithms: NO
GUI:
GTK+: YES (ver 2.24.32)
GThread : YES (ver 2.56.4)
GtkGlExt: NO
Media I/O:
ZLib: zlib (ver 1.2.11)
JPEG: libjpeg (ver 90)
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
JPEG 2000: build (ver 1.900.1)
Video I/O:
FFMPEG: NO
avcodec: YES (ver 57.107.100)
avformat: YES (ver 57.83.100)
avutil: YES (ver 55.78.100)
swscale: YES (ver 4.8.100)
avresample: NO
GStreamer:
base: YES (ver 1.14.5)
video: YES (ver 1.14.5)
app: YES (ver 1.14.5)
riff: YES (ver 1.14.5)
pbutils: YES (ver 1.14.5)
libv4l/libv4l2: NO
v4l/v4l2: linux/videodev2.h
gPhoto2: NO
Parallel framework: TBB (ver 2017.0 interface 9107)
Trace: YES (built-in)
Other third-party libraries:
Lapack: NO
Eigen: YES (ver 3.3.4)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
NVIDIA CUDA: YES (ver 10.0, CUFFT CUBLAS)
NVIDIA GPU arch: 62
NVIDIA PTX archs:
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.15)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15+)
numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
packages path: lib/python2.7/dist-packages
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Matlab: NO
Install to: /usr
invoking >>>cv::cuda::getCudaEnabledDeviceCount()
return -1,
and some info from opencv :
OpenCV(3.4.1) Error: Gpu API call (CUDA driver version is insufficient for CUDA runtime version) in allocate, file /root/opencv-3.4.1/modules/core/src/cuda/gpu_mat.cu, line 116
terminate called after throwing an instance of âcv::Exceptionâ
what(): OpenCV(3.4.1) /root/opencv-3.4.1/modules/core/src/cuda/gpu_mat.cu:116: error: (-217) CUDA driver version is insufficient for CUDA runtime version in function allocate
