OpenCV mat to NvJPEGEncoder jpg limited range
I have an OpenCV mat of type CV_8UC3 with BGR data in it. I’m trying to convert it to the right format to save a jpg with NvJPEGEncoder.
I’m following the basics from this post: NvJPEGEncoder - Converting from OpenCV Mat
  1. Convert to YUV with
cvtColor(bayerMat, YUVmat, cv::COLOR_BGR2YUV_I420);
  1. Copy into an NvBuffer of type
NvBuffer nvbuf(V4L2_PIX_FMT_YUV420M, image_width, image_height, 0);
  1. Then save with the jpeg encoder
std::unique_ptr jpgEnc(NvJPEGEncoder::createJPEGEncoder(“jpenenc”));
jpgEnc->encodeFromBuffer(nvbuf, JCS_YCbCr, &out_buf_ptr, out_buf_size, jpgQuality);
however this produces a jpg with limited range (blacks and saturation missing). Using OpenCV imwrite on the BRG mat does not have this issue.
NvJPEGEncoder produced image histogram:
NvJPEGEncoder histogram
OpenCV imwrite produced image histogram:
Edit: it appears I can only embed one image in a post
Is there a different OpenCV conversion code I need to be using to get the full range?
The closest discussion I can find to my issue is this thread: cvtColor for BGR to YUV 4:2:0 returns darker image · Issue #13066 · opencv/opencv · GitHub which seems to indicate that the OpenCV YUV420 conversion is what’s limiting the range.
Any thoughts on a work around for this?
Please dump the YUV420 and check if it is limited range. Looks like it converts BGR to limited-range YUV420.
Sorry, I was pulled to another task at work.
First, it looks like I attached the wrong histogram from the OpenCV imwrite jpg. Here is the correct one.
OpenCV histogram
It does appear that the OpenCV YUV420 conversion is what’s limiting the range.
I don’t fully understand the YUV420 format, but from the raw dump after the conversion the Y portion has a range of 21-235
If the data is shifted after converting to YUV420, we would suggest encode BGR data through cv2::imwrite() directly to avoid the conversion.
