I am trying to develope a “live-video-stabilizer” application on the jetson nano.
The requirements are, that I need to push 720p50 on the HDMI port in “console mode”.
So for letting the nano boot without the graphical target, i set
systemctl set-default multi-user.target
which just works fine.
Trying out without stabilization, I used the following g-streamer-1.0 pipeline:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=50/1' ! nvdrmvideosink
which is also working as intended.
For implementing the stabilization, I want to use OpenCV (Version 4).
For the first part, I wanted to test if my gstreamer pipeline is able to play using the OpenCV Classes VideoCapture and VideoWriter.
My code is the following:
#include <iostream>
#include <chrono>
#include <opencv2/opencv.hpp>
#include <opencv2/videoio.hpp>
#include <opencv2/highgui.hpp>
#include <gst/gst.h>
#include <glib.h>
using namespace std;
using namespace cv;
int main()
const char* gst_in_pipe = "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=1280, height=720, format=NV12, framerate=50/1 ! nvvidconv ! video/x-raw, format=I420 ! appsink";
VideoCapture cap(gst_in_pipe, CAP_GSTREAMER);
const char* gst_out_pipe = "appsrc ! video/x-raw, format=BGR, framerate=50/1, width=1280, height=720 ! videoconvert ! video/x-raw, format=BGRx ! nvvidconv ! video/x-raw(memory:NVMM), format=NV12 ! nvdrmvideosink";
VideoWriter out(gst_out_pipe, CAP_GSTREAMER, 0, 50, Size(1280,720));
if(!cap.isOpened()) {
cout << "Failed to open camera." << endl;
return (-1);
Mat frame, bgr;
for(;;) {
auto start = chrono::high_resolution_clock::now();
cap >> frame;
cvtColor(frame, bgr, COLOR_YUV2BGR_I420);
out << bgr;
waitKey(1);
auto finish = chrono::high_resolution_clock::now();
chrono::duration<double> elapsed = finish - start;
cout << "Elapsed time: " << elapsed.count() << "s\n";
cap.release();
out.release();
return 0;
When I start the application, the first ~2 seconds are working fine, but after that the framerate drops to ~(0.5 - 1) fps instead of the desired 50fps.
Using jtop (the nano is in MAX mode) when my application runs, it shows that all cpu cores are running at ~25-35%, the GPU is even at 0%.
Anyone has a clue what causes this behavior?
