OpenCV with CUDA Support in Jetson AGX Orin 64gb
Hi all,
I’m working with a Jetson AGX Orin running JetPack 6.2 (Ubuntu 22.04), and I’m trying to build OpenCV with full CUDA support for GPU-accelerated computer vision tasks, but I didn’t able to do that.
Setup:
  • Device: Jetson AGX Orin 64GB
  • JetPack: 6.2
  • OS: Ubuntu 22.04
  • CUDA: 12.6 (preinstalled with JetPack)
  • Python: 3.10 (preinstalled)
  • OpenCV: 4.8.0 (preinstalled, but without CUDA support)
Any help with the installation process or troubleshooting tips would be greatly appreciated.
We have a prebuilt package that can be found in the below link:
Thank you.
but why the OpenCV missing?
jtop
Do you get the package imported with Python?
If so, it should be okay as jtop only check the installation by calling opencv_version on the console:
Thank you,
I used a Python script to check if CUDA was working, it returned True. However, when I first ran jtop, it showed that OpenCV with CUDA was not enabled (NO). After uninstalling the default OpenCV installed through the SDK, I saw that OpenCV was missing.
Thanks again, The issue is resolved now.
