My machine is TX1, and I built the source code, The source code link is : VK-GL-CTS/external/openglcts at main · KhronosGroup/VK-GL-CTS · GitHub
and then run the test ./cts-runner --type=es2 , But I met some issues, just like followings:
running OpenGL ES 2 conformance
No WGL configs enumerated: WGL is not supported on this OS
found 22 compatible and 36 excluded configs
Test run 1 / 26
DONE!
Test run totals:
Passed: 14/14 (100.0%)
Failed: 0/14 (0.0%)
Not supported: 0/14 (0.0%)
Warnings: 0/14 (0.0%)
Test run 2 / 26
Config: --deqp-caselist-file=gl_cts/data/mustpass/egl/aosp_mustpass/3.2.4.x/egl-master.txt, --deqp-screen-rotation=unspecified, --deqp-surface-width=256, --deqp-surface-height=256, --deqp-watchdog=disable, --deqp-gl-config-name=rgba8888d24s8ms0, --deqp-log-filename=config-egl-master-cfg-1-run-0-width-256-height-256.qpa, --deqp-log-images=disable, --deqp-log-shader-sources=disable,
Writing test log into config-egl-master-cfg-1-run-0-width-256-height-256.qpa
dEQP Core git-e52de55c0c107405cdcd56256d088ee50eb39aac (0xe52de55c) starting…
target implementation = ‘Default’
Test case ‘dEQP-EGL.info.version’…
Pass (Pass)
Test case ‘dEQP-EGL.info.vendor’…
Pass (Pass)
Test case ‘dEQP-EGL.info.client_apis’…
Pass (Pass)
Test case ‘dEQP-EGL.info.extensions’…
Pass (Pass)
Test case ‘dEQP-EGL.info.configs’…
Pass ()
Test case ‘dEQP-EGL.functional.create_context.rgb565_no_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgb565_no_depth_stencil’…
NotSupported (No compatible configs found at teglSimpleConfigCase.cpp:78)
Test case ‘dEQP-EGL.functional.create_context.rgb565_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgb565_depth_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgb888_no_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgb888_no_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgb888_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgb888_depth_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgba4444_no_depth_no_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba4444_no_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba4444_depth_no_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba4444_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba5551_no_depth_no_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba5551_no_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba5551_depth_no_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba5551_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba8888_no_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgba8888_no_depth_stencil’…
Test case ‘dEQP-EGL.functional.create_context.rgba8888_depth_no_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.rgba8888_depth_stencil’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.create_context.other’…
Test case ‘dEQP-EGL.functional.create_context.no_config’…
NotSupported (EGL_KHR_no_config_context is not supported at teglCreateContextTests.cpp:129)
Test case ‘dEQP-EGL.functional.query_context.simple.query_api’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.query_context.get_current_context.rgb565_window’…
Test case ‘dEQP-EGL.functional.query_context.get_current_context.rgb565_pixmap’…
Test case ‘dEQP-EGL.functional.query_context.get_current_context.rgb565_pbuffer’…
Pass (Pass)
Test case ‘dEQP-EGL.functional.query_context.get_current_context.rgb888_window’…
X operation 1:0 failed: BadMatch (invalid parameter attributes)
X operation 18:0 failed: BadWindow (invalid Window parameter)
X operation 8:0 failed: BadWindow (invalid Window parameter)
X operation 2:0 failed: BadWindow (invalid Window parameter)
So can you tell me how can I solve the problem? And then go on doing the test?
