Unfortunately, your link does work so I can’t see the log file. However, you should be able to look through the log file and determine what the actual problem is. Check that the compilers are install and working properly. Can you compile a ‘Hello World’ program?
We were having trouble with our OpenMPI 1.2.3 build as well. We isolated it to a problem with pgCC (7.0-5) using -O2 and -g. When we build without the -g option, we’re OK.
I submitted a bug report with a simple-minded reproducer, but I can’t find it in the system.
