Optical Flow SDK is not supported on GeForce GTX 1650.
The NVIDIA optical flow hardware is supported for all Turing GPUs except TU117.
For your reference, this information is also captured in Doc/NVOFA_Application_Note.pdf.
Thank you for your explanation. I understood.
If you possible, I hope you add the description of this limitation to https://developer.nvidia.com/opticalflow-sdk.
Because, current description misleads about this limitation.
