Optimizing Sub-Millisecond IPC & Hardware Interrupts between Jetson AGX Thor and ESP32-S3
I am building a sovereign robotics node where probabilistic AI execution (running locally on the Jetson) is physically bottlenecked by a deterministic hardware gatekeeper (an ESP32-S3).
We are implementing a “State-Locked Protocol.” Before the Jetson can actuate a motor or send a critical network payload, the AI’s “intent” must be routed to the ESP32, completely halting the Jetson’s execution thread until the ESP32 registers a physical GPIO interrupt (a human-in-the-loop button press) and returns a cryptographic hash.
The Hardware Stack:
  • Primary Compute: Jetson AGX Thor (Running local LLMs / Isaac ROS).
  • Hardware Gatekeeper: ESP32-S3 (Acting as the physical interrupt and cryptographic signer).
My Engineering Questions for the Community:
  1. Lowest-Latency Payload Routing (SPI with DMA vs. High-Baud UART): To pass the AI intent payload (approx. 256 bytes) from the Jetson to the ESP32-S3, what is the optimal protocol to ensure sub-10ms glass-to-glass latency? I am leaning toward SPI utilizing Direct Memory Access (DMA) on the Jetson side to avoid CPU overhead, but I want to know if setting up a custom high-baud UART over the 40-pin header is less prone to buffer issues in a high-stress AI environment.
  2. Kernel-Level Thread Halting (PREEMPT_RT): When the Jetson sends the payload to the ESP32, what is the safest way in a PREEMPT_RT patched Linux kernel to completely freeze that specific AI execution thread while waiting for the return signal? I need to avoid kernel panics and ensure we do not starve the concurrent sensor-fusion pipelines running in Isaac ROS.
  3. Pinmux & Hardware Isolation: If the Jetson user-space is compromised or hallucinating, it must not be able to bypass the ESP32 to actuate the motors directly. Is there a recommended pinmux configuration or hardware-level gating strategy on the AGX carrier board to ensure the output GPIO pins are physically isolated unless the ESP32 pulls a specific enable pin HIGH?
I am currently prototyping this logic on a bench setup and would appreciate any insights from those who have bridged Jetson SoCs with external microcontrollers for mission-critical safety systems.
Thanks in advance.
// Kytin Ltd Engineering
duplicate topic as Sub-millisecond GPIO Interrupts between Jetson AGX and ESP32-S3 for Hardware-Anchored AI Paralysis, let us just discuss there.
