I need to build a GAS with a single build input (triangle array) and several SBT records.
My test code is list in the following and I get OPTIX_ERROR_INVALID_VALUE when calling optixAccelComputeMemoryUsage():
OptixBuildInput triangleInput = {};
// some settings for triangleInput...(not shown here)
CUdeviceptr temp;
TArray<uint8> testArrays;
CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&temp), triangleInput.triangleArray.numIndexTriplets * sizeof(uint8)));
CUDA_CHECK(cudaMemset(reinterpret_cast<void*>(temp), 0, triangleInput.triangleArray.numIndexTriplets * sizeof(uint8)));
triangleInput.triangleArray.numSbtRecords = 2;
triangleInput.triangleArray.sbtIndexOffsetBuffer = temp;
triangleInput.triangleArray.sbtIndexOffsetSizeInBytes = sizeof(uint8);
triangleInput.triangleArray.sbtIndexOffsetStrideInBytes = sizeof(uint8);
OptixAccelBufferSizes gasBufferSizes;
OPTIX_CHECK(optixAccelComputeMemoryUsage(m_context, &accelOptions, &triangleInput, 1, &gasBufferSizes));
However, it works if I set the numSbtRecoeds to 1:
triangleInput.triangleArray.numSbtRecords = 1;
Where is the problem?
