I am trying to run a small application that I wrote by using the OptiX samples as references. The application compiles just fine, but when I run the application I get the following error:
Optix Error: Unknown error(Details: Function “RT Result _rtContextLaunch2D (RTcontext_api*, unsigned int, RTSize, RTSize)” caught exception: Assertion failed: [5767628] )
By making use of debug commands, I realized that the error takes place in the following function:
Also: it sounds like you’re using/still referencing an uninitialized/destroyed variable or buffer. Please double check the dependencies for your program
I have not yet found a solution to my problem. Going to double check the dependencies now.
Concerning the OBJLoader in sutil, I am curious about the ASRefine char pointer that is passed to the constructor OBJLoader::OBJLoader. If I recall correctly, the OBJLoader constructor did not always have this parameter. I therefor just effectively passed ‘0’ to the constructor. Could this be a problem?
Changing between ‘0’ and “0” had the same effect - I defined ASRefine as a char at first, not a std::string. Made sure that ASRefine is properly set such as was done in Sample 6. So now it actually is declared to have a value of “0”.
Anyway, I fixed my problem. The problem was with how I handled a buffer in my application.
