I have a hit program using Optix 7.4 which works fine if I issue only a single optixTrace call in the program.
I changed the code to issue multiple optixTrace calls in a loop using the same origin point for each, but in a randomized direction. If the loop issues two or more optixTrace calls, I get the exception after a short while.
I’m puzzled since I do pass the current depth as the first (p0) trace program parameters, check the depth against the limit before calling optixTrace, and increment it each time, and since it works if the loop only iterates once.
I’ve probably got a conceptual problem here, that I’m missing. What comes to mind is that recursion is not working like I expect it to work in host based functions. I don’t know if all local variables in a hit program are being treated as a local stack frame, which potentially means lots of register save and restore for each recursive call, or if the model is different.
The other idea I had is I’m running into a self-intersection problem I’m not dealing with properly, but then it still seems that checking the depth limit should protect me.
One of the hit programs is below. At the moment the first loop does not run since params.numLights is zero, but that makes no difference.
I’ve set MAX_TRACE_DEPTH to 4 but also trying values up to 16 with no difference. I should be using the same MAX_TRACE_DEPTH value in calls to optixUtilComputeStackSizes and in the linkOptions.maxTraceDepth passed to optixPipelineCreate. Maybe I’m missing setting it elsewhere, but that’s not obvious.
extern "C" __global__ void __closesthit__lambert_material() {
/// printf("Depth: %d %s\n", optixGetPayload_0(), __FUNCTION__);
// This closest hit program deals with a mesh that has one or more material specifications
// Adapted from /home/dave/src/NVIDIA-OptiX-SDK-7.3.0-linux64-x86_64/SDK/cuda/LocalGeometry.h and /home/dave/src/NVIDIA-OptiX-SDK-7.3.0-linux64-x86_64/SDK/cuda/whitted.cu
const uint3 idx = optixGetLaunchIndex();
const uint3 dim = optixGetLaunchDimensions();
int rayIndex = idx.y * dim.x + idx.x;
#ifdef TIMING
params.profileCounters[HIT_COUNTER][rayIndex] = params.profileCounters[HIT_COUNTER][rayIndex] + 1;
#endif
unsigned int randomNumber;
#ifndef EMPTY_SHADER
// Get the index into the texture array for the triangle that was hit. optixGetPrimitiveIndex returns the index of the triangle as defined when building the
// acceleration data structures.
const int primIndex = optixGetPrimitiveIndex();
// Get access to hit data structure used by this shader
const HitGroupData *hitData = reinterpret_cast<HitGroupData*>(optixGetSbtDataPointer());
const float2 barycentrics = optixGetTriangleBarycentrics();
// Get the texture color for this pixel
const int materialIndex = hitData->mesh.materials.indices[primIndex];
const float3 color = hitData->mesh.lambertMaterial.specs[materialIndex].diffuseColor;
const float3 currentRayDirection = optixGetWorldRayDirection();
const float3 currentRayOrigin = optixGetWorldRayOrigin();
const float3 ourRayOrigin = currentRayOrigin + optixGetRayTmax() * currentRayDirection;
// Now get the triangle vertices as object coordinates
float3 data[3];
optixGetTriangleVertexData(optixGetGASTraversableHandle(), optixGetPrimitiveIndex(), optixGetSbtGASIndex(), 0.0f, data);
const float3 triangleNormal = normalize(optixTransformNormalFromObjectToWorldSpace(cross((data[1] - data[0]), (data[1] - data[2]))));
const float3 triangleP = optixTransformPointFromObjectToWorldSpace((1.0f - barycentrics.x - barycentrics.y) * data[0] + barycentrics.x * data[1] + barycentrics.y * data[2]);
// Accumulate the light received from all lights in the scene that are not obscured by another mesh
float3 totalLight = make_float3(0.0f, 0.0f, 0.0f);
float lightDistance;
unsigned int currentDepth = optixGetPayload_0();
for (unsigned int i = 0; i < params.numLights; i++) {
#ifdef TIMING
params.profileCounters[OCCLUSION_COUNTER][rayIndex] = params.profileCounters[OCCLUSION_COUNTER][rayIndex] + 1;
#endif
lightDistance = length(params.lights[i].location - ourRayOrigin);
float3 lightDirection = (params.lights[i].location - triangleP) / lightDistance;
unsigned int traceResult;
optixTrace(params.handle, ourRayOrigin, lightDirection, 0.01f, 100.0f, 0.0f, OptixVisibilityMask(255), OPTIX_RAY_FLAG_NONE, SHADOW_RAY, NUM_RAY_TYPES, SHADOW_RAY_MISS, traceResult);
if (traceResult == LIGHT_HIT) {
// If a light is not obscured, the intensity of the light reflected to the viewer is intensity * (cos(angleOfIncidence) / (4 * pi * distance**2), from section 1.2.3 of
// https://pbr-book.org/3ed-2018/Introduction/Photorealistic_Rendering_and_the_Ray-Tracing_Algorithm
// cos(angleOfIncidence) is calculated by dot(normalize(triangleNormal), normalize(lightDirection))
totalLight = totalLight + params.lights[i].color * params.lights[i].intensity / dot(normalize(triangleNormal), normalize(lightDirection)) / (12.56637061f * lightDistance * lightDistance);
if (currentDepth < MAX_TRACE_DEPTH) {
printf("Depth %d limit %d in %s\n", currentDepth, MAX_TRACE_DEPTH, __FUNCTION__);
float3 reflectionDirection = currentRayDirection - 2 * dot(currentRayDirection, triangleNormal) * triangleNormal;
randomNumber = params.randomSeed * rayIndex;
// Adjust ray direction by a random amount to simulate a surface that is not a perfect mirror.
float fuzz = hitData->mesh.lambertMaterial.fuzzFactor;
for (unsigned int i = 0; i < LAMBERT_RAYS; i++) {
/// printf("%03d:%03d:%03d lambert material depth %d\n", idx.x, idx.y, idx.z, currentDepth);
float3 adjustedDirection;
adjustedDirection.x = reflectionDirection.x + rand(&randomNumber) * fuzz;
adjustedDirection.y = reflectionDirection.y + rand(&randomNumber) * fuzz;
adjustedDirection.z = reflectionDirection.z + rand(&randomNumber) * fuzz;
adjustedDirection = normalize(adjustedDirection);
unsigned int p0;
unsigned int p1;
unsigned int p2;
unsigned int newDepth = currentDepth + 1;
optixTrace(params.handle, ourRayOrigin, reflectionDirection, 0.01f, 100.0f, 0.0f, OptixVisibilityMask(255), OPTIX_RAY_FLAG_NONE, NORMAL_RAY, NUM_RAY_TYPES, NORMAL_RAY_MISS, newDepth, p0,
p1, p2);
// Get the light reflected to us by the mesh that was hit and add it to the total light received by the current mesh
totalLight = totalLight + make_float3(uint_as_float(p0), uint_as_float(p1), uint_as_float(p2));
#ifdef TIMING
params.profileCounters[REFLECTION_COUNTER][rayIndex] = params.profileCounters[REFLECTION_COUNTER][rayIndex] + 1;
#endif
// Combine the texture color of our pixel with the total light received from all non-obscured lights by multiplying the color vectors. This gives us the actual light color for this pixel.
// Light returned has to be adjusted to account for distance from current point to ray origin.
float3 finalColor = color * totalLight;
lightDistance = length(ourRayOrigin - currentRayOrigin);
setIntersectPayload(RAY_HIT, clamp(finalColor / dot(normalize(triangleNormal), normalize(currentRayDirection)) / (12.56637061f * lightDistance * lightDistance), 0.0f, 1.0f));
#endif
