Previous question: Is there a way to know how much GPU memory Optix will use?
If the number of meshes is small, it runs, but if there are a lot, it does not run, so I thought it was a GPU memory problem.
However, it did not run on the GTX 960 4GB graphics card,
but it did run on the GTX 1050 2GB graphics card.
I executed optixLaunch(…, width, height, 1) in the for statement. (width = mesh count)
“height” is set so that (width * height) is about 30% (range of 2^30 or less) of GPU available memory. (Adjust for loop index increment value accordingly).
In the above situation, GTX 960 4GB (width(=mesh count): 138056 / height: 7777) did not run.
When “height” was set to 1, it worked on GTX 960 4GB.
I think it may be an index access issue when putting the results into the buffer, but I don’t understand why the same code works on the GTX 1050 but not on the GTX 960.
Are there any restrictions on the execution size of optixLaunch for each graphics card?
This is part of the source code.
o main.cpp
// dimensionH is set so that (width * height) is about 30% (range of 2^30 or less) of GPU available memory.
for (unsigned int i = 0; i < meshesCnt; i += dimensionH)
const unsigned int width = meshesCnt;
const unsigned int height = (meshesCnt - i < dimensionH) ? (meshesCnt - i) : dimensionH; // last block
cudaMemset(params.Visibility, 0, blockSize * sizeof(char))); // blockSize = width * dimensionH
cudaMemcpy(… startIndex … );
optixLaunch(… width, height, 1);
CUDA_SYNC_CHECK();
o ray_gen()
const unsigned int resultIndex = (launch_index.y * width) + launch_index.x;
params.Visibility[resultIndex] = hit or miss;
Output error when running GTX 960 4GB
: options.validationMode = OPTIX_DEVICE_CONTEXT_VALIDATION_MODE_ALL; Setting, Debug x64 Mode
[ 2][ ERROR]: Error recording event to prevent concurrent launches on the same OptixPipeline (CUDA error string: unknown error, CUDA error code: 999)
Error recording resource event on user stream (CUDA error string: unknown error, CUDA error code: 999)
Caught exception: OPTIX_ERROR_CUDA_ERROR: Optix call ‘optixLaunch( scene.pipeline(), 0, reinterpret_cast(d_paramsOpX), sizeof(opx::LaunchParamsOpX), scene.sbt(), width, height, 1 )’ failed:
[ 2][ PIPELINE]: Error releasing namedConstant’s internal resources (CUDA error string: unknown error, CUDA error code: 999)
Error synching on OptixPipeline event (CUDA error string: unknown error, CUDA error code: 999)
Error destroying OptixPipeline event (CUDA error string: unknown error, CUDA error code: 999)
Thank you
