I am new to Optix,
I want to build SDK’s example project( for example "optixSphere").
The equipment list is below.
- Windows 7 Prof 64 bit,
- Microsoft Visual Studio Professional 2012
Version 11.0.50727.1 RTMREL
Microsoft .NET Framework
Version 4.5.50709
Installed Version: Professional - NVIDIA CUDA 6.0 Wizards 6.0
- GPU: TeslaK20
- Optix SDK version : v4.0.2
I build this project file("optixSphere") in Visual Studio without Cmake. I also changed these parameters;
- Property->Configuration Properties-> Cuda C/C++ -> Common -> NVCC Compilation Type : changed to Generate .ptx file(-ptx)
- Property->Configuration Properties-> Cuda C/C++ -> Device -> Code Generation: changed compute_35,sm_35
I add to include files in this link :"Property->Configuration Properties -> VC++ Directories -> Include Directories" and I add to library files in this link: "Property->Configuration Properties -> VC++ Directories -> Library Directories"
In conclusion, with these project specs I couldn’t build any optix SDK example. For example, with "optixSphere" project I took these errors;
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::displayBufferPPM(char const *,struct RTbuffer_api *)" (_imp?displayBufferPPM@sutil@@YAXPEBDPEAURTbuffer_api@@@Z)
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::calculateCameraVariables(struct optix::float3,struct optix::float3,struct optix::float3,float,float,struct optix::float3 &,struct optix::float3 &,struct optix::float3 &,bool)" (_imp?calculateCameraVariables@sutil@@YAXUfloat3@optix@@00MMAEAU23@11_N@Z)
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::reportErrorMessage(char const *)" (_imp?reportErrorMessage@sutil@@YAXPEBD@Z)
error LNK2001: unresolved external symbol "__declspec(dllimport) char const * __cdecl sutil::samplesPTXDir(void)" (_imp?samplesPTXDir@sutil@@YAPEBDXZ)
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::displayBufferGlut(char const *,struct RTbuffer_api *)"
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::parseDimensions(char const *,int &,int &)" (_imp?parseDimensions@sutil@@YAXPEBDAEAH1@Z)
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::handleError(struct RTcontext_api *,enum RTresult,char const *,int)" (_imp?handleError@sutil@@YAXPEAURTcontext_api@@W4RTresult@@PEBDH@Z)
error LNK2001: unresolved external symbol "__declspec(dllimport) void __cdecl sutil::initGlut(int *,char * *)" (_imp?initGlut@sutil@@YAXPEAHPEAPEAD@Z)
Why could these problems occur? I couldn’t fix these problems. Can we use optix tool without cmake? If yes How can I make project in Visual Studio? Could you tell me this solution step by step? Thanks for your help.
