OptiX 7.1.0 works great with my application. But now I wanted to checkout the new curve primitives (optixHair sample) but I have trouble setting up the samples project.
I followed the steps in INSTALL-WIN.txt;
In CMAKE I used a copy of the contents in “C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.1.0\SDK” as source.
And added a “build” folder into that directory.
CUDA 11.0 was correctly found; also VS 2015 64bit (to force the use of v140 toolset);
OptiX_DIR was not found even after I added it there; which specific folder is required there?
CMAKE OutPut:
Selecting Windows SDK version 10.0.14393.0 to target Windows 10.0.19041.
The C compiler identification is MSVC 19.0.24218.2
The CXX compiler identification is MSVC 19.0.24218.2
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
CMake Error at CMakeLists.txt:132 (include):
include could not find load file:
Macros
CMake Error at CMakeLists.txt:134 (include):
CompilerInfo
CMake Error at CMakeLists.txt:136 (include):
ConfigCompilerFlags
Found CUDA: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.0 (found suitable version "11.0", minimum required is "5.0")
CMake Error at CMakeLists.txt:235 (find_package):
By not providing "FindOptiX.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "OptiX", but
CMake did not find one.
Could not find a package configuration file provided by "OptiX" with any of
the following names:
OptiXConfig.cmake
optix-config.cmake
Add the installation prefix of "OptiX" to CMAKE_PREFIX_PATH or set
"OptiX_DIR" to a directory containing one of the above files. If "OptiX"
provides a separate development package or SDK, be sure it has been
installed.
Configuring incomplete, errors occurred!
I nowhere found the files OptiXConfig.cmake and optix-config.cmake
There is also no field “CMAKE_PREFIX_PATH”.
Changing the folder in “OptiX_DIR” also does not give any other result. Which exact folder is required there? I tried these folders:
C:/ProgramData/NVIDIA Corporation/OptiX SDK 7.1.0\include
#my custom path#\OptiX7_1
Thank you!
Btw, the link in CMakeLists.txt https://devtalk.nvidia.com/default/board/90/
does not link to this forum here, instead it says: “Sorry, this page may have moved, doesn’t exist or is private.”
My System: OptiX 7.1.0 SDK CUDA 11.0.1 GTX 1050 2GB Win10PRO 64bit (version 2004; build 19041.264) device driver: 451.48 VS2019 v16.6.3 (toolkit v140 of VS2015) MDL SDK 2020.0.1
(no difference after updating VS2019 v16.6.2 to VS2019 v16.6.3)
CMAKE v3.14.4
