my nvidia GPU is A100-PCIE-40GB and my driver version is 570.86.115 just like this:
i have installed cuda toolkit :
nvcc --version
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Tue_Feb_27_16:19:38_PST_2024
Cuda compilation tools, release 12.4, V12.4.99
Build cuda_12.4.r12.4/compiler.33961263_0
But when i installed optix 9.0 , i got this problem:
sionna/NVIDIA-OptiX-SDK-9.0.0-linux64-x86_64/SDK/bin$ ./optixHello
Caught exception: OPTIX_ERROR_LIBRARY_NOT_FOUND: Optix call ‘optixInit()’ failed: /home/zhonggp/sionna/NVIDIA-OptiX-SDK-9.0.0-linux64-x86_64/SDK/optixHello/optixHello.cpp:125)
my env path is :
echo $PATH
/usr/local/cuda-12.4/bin:/usr/local/cuda-12.4/bin:/home/software/OPTIX_SDK/bin:/usr/local/cuda-12.4/bin:/opt/miniconda3/envs/sionna/bin:/opt/miniconda3/condabin:/home/postgres/postgresql/bin:/opt/miniconda3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
echo $LD_LIBRARY_PATH
/home/software/OPTIX_SDK/lib:/usr/local/cuda-12.4/lib64:/usr/local/cuda-12.4/lib64:/home/software/OPTIX_SDK/lib
Another proble is :
after i installed sionna , i run the demo , i got this issue:
jit_optix_api_init(): libnvoptix.so.1 could not be loaded – disabling OptiX backend! Set the DRJIT_LIBOPTIX_PATH environment variable to specify its path. If you are using the Windows Subsystem for Linux 2 (“WSL 2”), please follow the setup instructions at mitsuba3/docs/src/optix_setup.rst at master · mitsuba-renderer/mitsuba3 · GitHub to make OptiX availablet to WSL.
File “/home/zhonggp/sionna/test.py”, line 20, in
scene = load_scene(sionna.rt.scene.munich) # Try also sionna.rt.scene.etoile
File “/opt/miniconda3/envs/sionna/lib/python3.12/site-packages/sionna/rt/scene.py”, line 1054, in load_scene
mi_scene = mi.load_string(processed)
RuntimeError: [xml.cpp:1078] Error while loading “” (near line 1, col 1): could not instantiate scene plugin of type “scene”: Could not initialize OptiX!
Hope reply , thx~
