There is something weird result with DeepStream on Orin series.
I tested deepsteam-app to transmit video output with RTSP.
I received the stream on Window Laptop with VLC media player.
When I test it Agx Orin and Orin NX, the stream is open but the stream is just black screen at the beginning.
The correct image is shown after 3 ~20 minutes. The time is very randomly.
In case of Xavier Series, correct image is shown from the beginning.
There is no error message, the log of Orin series and Xavier Series are same on Jetson.
JetPack version is 5.1.2 and DeepStream version is 6.3.
I tried to run deepstream-app twice.
And I accessed rtsp stream 4 times.
First time, it takes over 2 minutes to display out correct imaage.
Second time, it takes 1 minutes.
And then any other 2 times are taking 10 seconds.
dmesg has warning message about NvMap Allocations.
Xavier has same warning message but Xavier has no issue.
