We have a issue with DP MST mode, same like topic below
It happened when using the same resolution and same frame rate,display goes fail
example: two monitor out ,1080P@60Hz and 1080P@60Hz–>both monitor fail
set different frame rate, 1080P@60Hz and 1080P@59.94Hz that is OK
1080P@60 and 1080P@50Hz that is OK ,too
I’m seeing exactly the same assertion with an HDMI display connected to an Orin Nano on an AverMedia DL131L carrier board running JetPack 5.1.2. It does not appear to affect the display but it would be nice to get rid of it.
