When I applied the CUDA_driver_36.4.4.tbz2 patch, attempting to pull the imx477 video stream still resulted in memory leakage.
The pull command uses
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
When pulling real-time images, the memory used by kmalloc256 will gradually and continuously increase. It will grow by approximately 30M in about one hour. Even when the streaming test process is shut down, kmalloc256 is not released.
This bug has seriously affected our batch processing. Please verify the issue and resolve it as soon as possible.
