So I’m designing a custom carrier board based on the official reference design by NVIDIA through a third-party manufacturer, I’m making no changes except copied the USB-C UART 3 more times, removed Displayport and ethernet and modified one USB-C to have DP + PD (Displayport + Power Delivery). It also has an EEPROM similar to the Jetson Orin Nano Devkit.
I don’t know this but do I need to generate a device tree for this or will it automatically detect the USB-C DP + PD?
If not, what files do I need to change and where do I need to change to add the DP + PD USB-C? Is there a way to avoid compiling the Linux Kernel and just change the device tree? I want to use Jetpack 6.0. Any step by step documentation available for newcomers like me?
I want to use Jetpack 6.0DP on the custom carrier board as I’m already using it on my orin nano devkit.
Thanks for linking the adaptation guide. I’m not sure what to download from here in order to follow the adaptation guide: Jetson Linux | NVIDIA Developer For example, where can I get this directory? Linux_for_Tegra
Also, when you say changing the kernel image, you mean modifying the dtsi files?
