Build custom device tree for jetson orin nano 8GB
Currently I am using the orin nano 8GB board. I need to compile my own device tree.
I am trying to find the exact device tree that is used for this device from the linux kernel source but I was unable to find it as per this following information.
root@orin-nano:~# cat /proc/device-tree/model
NVIDIA Jetson Orin Nano Developer Kit
root@orin-nano:~#
root@orin-nano:~# cat /proc/device-tree/compatible
nvidia,p3768-0000+p3767-0005nvidia, nvidia,tegra234
root@orin-nano:~#
Can anyone help me to find the device tree and modify it for my custom board ?.
Even in the dmesg logs I am unable to find the device tree used and in the linux kernel source tree I found only the folllowing
tegra234-sim-vdk.dts
tegra234-p3737-0000+p3701-0000.dts
tegra234-p3737-0000.dtsi
tegra234-p3701-0000.dtsi
tegra234.dtsi
Thanks in advance
Hi mallempati.rajesh,
Are you using the devkit or custom board for Orin Nano?
Please run the following command and share the results.
$ cat /etc/nv_boot_control.conf
$ cat /boot/extlinux/extlinux.conf
$ ls -l /boot/dtb
Actually, you can also check the full flash log to know which DTB is used for your board.
