Orin nano es889 audio
我想适配es8389音频驱动,但是现在没有节点生成,帮我分析下原因
这是我的overlay设备树,
i2c0,i2s2
// SPDX-License-Identifier: GPL-2.0-only
// SPDX-FileCopyrightText: Copyright (c) 2021-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
  • Copyright (c) 2021-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
  • This program is free software; you can redistribute it and/or modify it
  • under the terms and conditions of the GNU General Public License,
  • version 2, as published by the Free Software Foundation.
  • This program is distributed in the hope it will be useful, but WITHOUT
  • ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
  • FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
  • more details.
  • You should have received a copy of the GNU General Public License
  • along with this program. If not, see http://www.gnu.org/licenses/.
include <dt-bindings/pinctrl/pinctrl-tegra.h>
include <dt-bindings/clock/tegra234-clock.h>
include <dt-bindings/sound/tegra-asoc-dais.h>
overlay-name = “Jetson 40pin Header”;
fragment@0 {
	target = <&pinmux>;
	__overlay__ {
		pinctrl-names = "default";
		pinctrl-0 = <&jetson_io_pinmux>;
		jetson_io_pinmux: exp-header-pinmux {
		//MCU RESET
		uart2_rts_px6 {
			nvidia,pins = "uart2_rts_px6";
			nvidia,function = "rsvd1";
			nvidia,pull = <TEGRA_PIN_PULL_NONE>;
			nvidia,tristate = <TEGRA_PIN_DISABLE>;
			nvidia,enable-input = <TEGRA_PIN_DISABLE>;
			// nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
			nvidia,lpdr = <TEGRA_PIN_DISABLE>;
			nvidia,io-hv = <TEGRA_PIN_ENABLE>;
		spi3_cs1_py4 {
			nvidia,pins = "spi3_cs1_py4";
		spi1_cs1_pz7 {
			nvidia,pins = "spi1_cs1_pz7";
		//UART
		uart2_tx_px4 {
			nvidia,pins = "uart2_tx_px4";
			nvidia,function = "uartb";
		uart2_rx_px5 {
			nvidia,pins = "uart2_rx_px5";
			nvidia,pull = <TEGRA_PIN_PULL_UP>;
			nvidia,tristate = <TEGRA_PIN_ENABLE>;
			nvidia,enable-input = <TEGRA_PIN_ENABLE>;
		dap4_dout_pa5 {
			nvidia,pins = "dap4_dout_pa5";
		dap4_din_pa6 {
			nvidia,pins = "dap4_din_pa6";
		dap4_fs_pa7 {
			nvidia,pins = "dap4_fs_pa7";
		dap4_sclk_pa4 {
			nvidia,pins = "dap4_sclk_pa4";
		pex_l7_rst_n_pag1 {
			nvidia,pins = "pex_l7_rst_n_pag1";
			nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
		soc_gpio32_pq5 {
			nvidia,pins = "soc_gpio32_pq5";
			nvidia,function = "rsvd0";
		soc_gpio25_pp6 {
			nvidia,pins = "soc_gpio25_pp6";
			nvidia,function = "vi0";
		soc_gpio19_pg6 {
			nvidia,pins = "soc_gpio19_pg6";
			nvidia,function = "gp";
		soc_gpio33_pq6 {
			nvidia,pins = "soc_gpio33_pq6";
		soc_gpio39_pn1 {
			nvidia,pins = "soc_gpio39_pn1";
		soc_gpio21_ph0 {
			nvidia,pins = "soc_gpio21_ph0";
		pex_l1_clkreq_n_pk2 {
			nvidia,pins = "pex_l1_clkreq_n_pk2";
		pex_l1_rst_n_pk3 {
			nvidia,pins = "pex_l1_rst_n_pk3";
			hdr40-pin7 {
				nvidia,pins = "soc_gpio59_pac6";
				nvidia,function = "aud";
				nvidia,pin-label = "aud_mclk";
			hdr40-pin8 {
				nvidia,pins = "uart1_tx_pr2";
			hdr40-pin10 {
				nvidia,pins = "uart1_rx_pr3";
			hdr40-pin11 {
				nvidia,pins = "uart1_rts_pr4";
				nvidia,function = "uarta";
				nvidia,pin-group = "uarta-cts/rts";
			hdr40-pin12 {
				nvidia,pins = "soc_gpio41_ph7";
				nvidia,function = "i2s2";
				nvidia,pin-label = "i2s2_sclk";
			hdr40-pin13 {
				nvidia,pins = "spi3_sck_py0";
				nvidia,function = "spi3";
				nvidia,pin-label = "spi3_sck";
			hdr40-pin15 {
				nvidia,pin-group = "pwm1";
			hdr40-pin18 {
				nvidia,pins = "spi3_cs0_py3";
				nvidia,pin-label = "spi3_cs0";
			hdr40-pin19 {
				nvidia,pins = "spi1_mosi_pz5";
				nvidia,function = "spi1";
				nvidia,pin-label = "spi1_dout";
			hdr40-pin21 {
				nvidia,pins = "spi1_miso_pz4";
				nvidia,pin-label = "spi1_din";
			hdr40-pin22 {
				nvidia,pins = "spi3_miso_py1";
				nvidia,pin-label = "spi3_din";
			hdr40-pin23 {
				nvidia,pins = "spi1_sck_pz3";
				nvidia,pin-label = "spi1_sck";
			hdr40-pin24 {
				nvidia,pins = "spi1_cs0_pz6";
				nvidia,pin-label = "spi1_cs0";
			hdr40-pin29 {
				nvidia,function = "extperiph3";
				nvidia,pin-group = "extperiph3_clk";
			hdr40-pin31 {
				nvidia,function = "extperiph4";
				nvidia,pin-group = "extperiph4_clk";
			hdr40-pin32 {
				nvidia,pin-group = "pwm7";
			hdr40-pin33 {
				nvidia,pin-group = "pwm5";
			hdr40-pin35 {
				nvidia,pins = "soc_gpio44_pi2";
				nvidia,pin-label = "i2s2_fs";
			hdr40-pin36 {
				nvidia,pins = "uart1_cts_pr5";
			hdr40-pin37 {
				nvidia,pins = "spi3_mosi_py2";
				nvidia,pin-label = "spi3_dout";
			hdr40-pin38 {
				nvidia,pins = "soc_gpio43_pi1";
				nvidia,pin-label = "i2s2_din";
			hdr40-pin40 {
				nvidia,pins = "soc_gpio42_pi0";
				nvidia,pin-label = "i2s2_dout";
fragment@1 {
	target = <&pinmux_aon>;
	__overlay__ {
		pinctrl-0 = <&jetson_io_pinmux_aon>;
		jetson_io_pinmux_aon: exp-header-pinmux {
			hdr40-pin3 {
				nvidia,pins = "gen8_i2c_sda_pdd2";
				nvidia,pin-label = "i2c8";
			hdr40-pin5 {
				nvidia,pins = "gen8_i2c_scl_pdd1";
			hdr40-pin27 {
				nvidia,pins = "gen2_i2c_sda_pdd0";
			hdr40-pin28 {
				nvidia,pins = "gen2_i2c_scl_pcc7";
			spi2_sck_pcc0 {
				nvidia,pins = "spi2_sck_pcc0";
			spi2_miso_pcc1 {
				nvidia,pins = "spi2_miso_pcc1";
			spi2_mosi_pcc2 {
				nvidia,pins = "spi2_mosi_pcc2";
			spi2_cs0_pcc3 {
				nvidia,pins = "spi2_cs0_pcc3";
			hdmi_cec_pgg0 {
				nvidia,pins = "hdmi_cec_pgg0";
fragment@2 {
	target-path = "/bus@0/cam_i2cmux";
	__overlay__ {
		status = "disabled";  // 直接禁用整个节点
fragment@3 {
	target = <&uniubi_i2c0>;
	__overlay__ {
		#address-cells = <1>;
		#size-cells = <0>;
		es8389: es8389@10 {
			compatible = "everest,es8389";
			reg = <0x10>;
			#sound-dai-cells = <0>;
			clocks = <&bpmp TEGRA234_CLK_AUD_MCLK>;
			clock-names = "mclk";
			status = "okay";
			sound-name-prefix = "H40-AC";
			port {
				es8389_ep: endpoint {
					remote-endpoint = <&hdr40_snd_i2s_dap_ep>;
					mclk-fs = <256>;
					link-name = "es8389-audio";
fragment@4 {
	target = <&hdr40_snd_i2s_dap_ep>;
	__overlay__ {
		dai-format = "i2s";
		bitclock-master;
		frame-master;
		remote-endpoint = <&es8389_ep>;
fragment@5 {
	target = <&tegra_sound>;
	__overlay__ {
		nvidia-audio-card,widgets =
			"Microphone",   "H40-AC Mic",
			"Headphone",    "H40-AC Headphone";
		nvidia-audio-card,routing =
			"H40-AC Mic",    "H40-AC INPUT1",
			"H40-AC Headphone", "H40-AC HPOL",
			"H40-AC Headphone", "H40-AC HPOR";
fragment@6 {
	target = <&hdr40_snd_link_i2s>;
	__overlay__ {
		status = "okay";
		format = "i2s";
		link-type = <C2C_LINK>;
		bitclock-master;
		frame-master;
		cpu {
			sound-dai = <&tegra_i2s2 I2S_DAP>;
		codec {
			sound-dai = <&es8389>;
			prefix = "H40-AC";
/* Audio graph fragments */
fragment@7 {
	target = <&tegra_sound_graph>;
	__overlay__ {
		widgets = "Microphone",		"H40-AC Mic",
		routing = "H40-AC Mic",		"H40-AC INPUT1",
fragment@8 {
	target = <&tegra_i2s2>;
	__overlay__ {
		status = "okay";
Please provide the dmesg, DT, mixer controls, pinmux logs. Refer How to fetch debug logs.
pinmux.txt (12.9 KB)
dt.log (328.0 KB)
dmesg.log (98.3 KB)
tegra234-audio-es8389.log (4.2 KB)
tegra234-p3768-0000+p3767-0005-nv.log (16.2 KB)
我可以在cat /proc/asound/cards看到节点信息,但是进行音频测试的时候就会报错
Which Jetpack release is being used?
**JetPack 6.2.1
sdk3.4.4**
tegra234-audio-es8389-tmp-ok.log (3.3 KB)这是我使用的最新的dtsi
同时我也参考了下面的论坛
使用的设备树如下,不过效果好像一样
tegra234-audio-es8389-nvidia.log (2.9 KB)
DT updates are not done as per the instructions here: Interface customized audio card
  • Rather than creating simple_sound: simple-sound { node, sound node is supposed to be updated.
  • i2s2 dai-link nvidia-audio-card,dai-link@77 is not connected to the codec.
Also, for more details refer 如何配置es8389 - #11 by Sheetal.G
我修改了一版本设备树,启动打印报错
es8389 0-0010: ASoC: error at soc_component_read_no_lock on es8389.0-0010: -121
[ 14.190591] es8389 0-0010: ASoC: error at soc_component_read_no_lock on es8389.0-0010: -121
[ 14.190964] es8389 0-0010: ASoC: error at soc_component_read_no_lock on es8389.0-0010: -121
[ 14.223412] tegra-asoc: sound: ASoC: no source widget found for HPOL
[ 14.223419] tegra-asoc: sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 14.223449] tegra-asoc: sound: ASoC: no source widget found for HPOR
[ 14.223450] tegra-asoc: sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 14.223474] tegra-asoc: sound: ASoC: no sink widget found for INPUT1
[ 14.223475] tegra-asoc: sound: ASoC: Failed to add route Mic Jack → direct → INPUT1
[ 14.223500] tegra-asoc: sound: ASoC: no sink widget found for INPUT2
[ 14.223502] tegra-asoc: sound: ASoC: Failed to add route Mic Jack → direct → INPUT2
tegra234-audio-es8389-tmp2.log (1.9 KB)
Please refer to 如何配置es8389 - #11 by Sheetal.G for right routing and widgets.
