Orin Nano flashing as Orin NX - No MAXN Mode
Tried to flash my Orin Nano once again but after flashing it shows:
cat /proc/device-tree/model
NVIDIA Jetson Orin NX Engineering Reference Developer Kit
Just as in the post below:
The main issue is that the MAXN Power mode is not available… what can I do?
Was first flashing with Jetpack 6.2, then tried with 6.1 but same result.
I’m flashing with SDK Manager with NVMe.
Any clues?
Please download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide guide to flash your device.
Hi @DavidDDD, thanks for the reply, will try and circle back here.
Just to understand, what should be the difference between this and installing via SDK Manager?
SDK manager might choose config without super, so use manual flash could config with your demand.
