Platform: Jetson Orin Nano
JetPack Version: 6.2
I’m trying to modify the default MAC address on our custom carrier board.
Before making any changes, I was able to read the MAC address correctly from the EEPROM, and it matched the actual hardware address.
So I attempted to modify the EEPROM at address 0x50, specifically bytes 68 to 73, to update the MAC address as below.
root@tegra-ubuntu:/home/ubuntu# hexdump -C /sys/devices/platform/bus@0/3160000.i2c/i2c-0/0-0050/eeprom
00000000 02 00 fe 00 00 00 00 00 00 00 00 ff 00 00 00 00 |................|
00000010 00 01 00 01 36 39 39 2d 31 33 37 36 37 2d 30 30 |....699-13767-00|
00000020 30 33 2d 33 30 31 20 41 2e 31 00 00 00 00 00 00 |03-301 A.1......|
00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000040 b0 48 00 00 **66 55 44 33 22 11** 31 34 32 34 33 32 |.H..c,.-.H142432|
00000050 33 30 31 38 33 31 34 00 00 00 00 00 00 00 00 00 |3018314.........|
00000060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000090 00 00 00 00 00 00 4e 56 43 42 00 ff 4d 31 00 00 |......NVCB..M1..|
000000a0 00 00 00 00 00 00 00 00 00 00 00 00 33 22 11 e1 |............3"..|
000000b0 03 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000000c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000000f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ad |................|
However, after rebooting the system, the MAC address did not change as expected.
I would like to ask:
- Is it valid to change the MAC address by modifying the EEPROM directly?
- What is the actual process or flow the system uses to retrieve the MAC address during boot?
Thanks in advance for your help!
