Orin nano JetPack 5.1.1 pinmux problem
device: orin nano 8gb devkit
function: modify gpio07 to pwm
problem: why it dont work
opretion:
  1. modify Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template.xlsm,generate dtsi file
  2. modify jetson-orin-nano-devkit.conf, copy dtsi to bootloader/t186ref
  3. modify devicetree file
  4. flash to device
  5. start device
Hi gengqi_yz,
Please refer to the following steps to verify PWM on Orin Nano devkit.
Unable to generate PWM with Nvidia Jetson AGX Orin Development Kit - #6 by KevinFFF
  1. By default in simple_pwm.py, it will perform PWM signal from pwm5(PIN33)
  2. but i modify simple_pwm.py,it does not work in pwm7(pin32)
  3. If I want to change the system image, I need to modify which files to make it successful, Instead of using Python script
hi KevinFFF,
Based on the examples you give, I still have the following questions
https://forums.developer.nvidia.com/t/orin-nano-jetpack-5-1-1-pinmux-problem/291892/3
Please configure the pwm7 through Jetson-IO. (i.e. enable pwm7 in jetson-io and reboot to apply the change)
Yes, I did this, but there is still this problem
Sorry for the late response.
Hi gengqi_yz,
Do you mean that you would still hit “Channel 32 is not a PWM” issue with simple_pwm.py after you use Jetson-IO to enable it?
yes, i configure channnel 32 , then reboot, but it does not work
It seems not the expected result to me.
Coud you also verify with the latest Jetpack 5.1.3 (R35.5.0)?
