Thanks for reply, my USB to serial cable arrived today and I started debugging.
Well, I ran impatient before, and I bought two 64 GB cards yesterday and started experimenting.
I programmed one with JetPack 6.2.1 (sd-blob.img) and it did not boot - let us call it JP6 for short.
I programmed another SD Card with JetPack 5.1.3 (sd-blob.img) and it did not boot - let us call it JP5 for short.
I did not do more tries, may be I should…
Now, the magic happened when I connected the USB to serial today, first I booted Jetson when I still had my JP5 card installed, I got
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: ERROR: Invalid header detected on UEFI supplied FDT, ignoring ...
EFI stub: Generating empty DTB
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
then the device stopped responding, needed poweroff
Next, I removed JP5 and inserted JP6 card and powered on, I got Linux booting until this point:
[ 9.849807] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 9.849812] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 9.849930] pcieport 0008:00:00.0: Adding to iommu group 8
[ 9.850024] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[ 9.850340] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[ 17.402398] ERROR: nvme1n1p1 not found
I see this both coming from UART and from HDMI screen
The Linux Terminal drops into “bash-5.1#“ recovery shell.
So obviously still somewhere is reference to nvme1n1p1…
Well, in my Jetson 1 device I have both M2. slots populated with SSDs, and seems this is the tripping point now, shall I update GRUB somehow to understand that the disks are not there?
