Orin Nano T234: DPHY_ERR_CLK_LANE_CTRL before SoT with ST VL53L9CX, same CSI stream works on Raspberry Pi
Hi NVIDIA team,
I am bringing up an ST VL53L9CX / STEVAL-VL53L9 one-lane MIPI CSI-2 source on a Jetson Orin Nano Super devkit running JetPack 6.2.3 / L4T R36.5.2.
I have narrowed the failure substantially and would appreciate guidance specifically on the T234 NVCSI CIL clock-lane LP state machine, rather than basic DT / tegracam bring-up.
Hardware / known-good comparison
Jetson:
  • Orin Nano Super devkit
  • P3767-0005 module + P3768 carrier
  • J21 / serial_c
  • port-index = 2
  • 1 D-PHY data lane
  • VC0
  • RAW8 / CSI DT 0x2A
Sensor:
  • ST STEVAL-VL53L9 / VL53L9CX
  • Sensor controlled over I2C with the ST ULD
  • Sensor remains in streaming FSM state
  • Frame counter advances at approximately 99-100 fps
  • Sensor error state remains zero
The exact same VL53 board and ribbon works correctly on Raspberry Pi 5 RP1:
  • 1 Gbps: approximately 100 fps, clean capture
  • matched 100 Mbps: approximately 100 fps, clean capture
  • no RP1 D-PHY / packet / frame errors
The same Jetson J21 receiver also works correctly with a Raspberry Pi Global Shutter IMX296 camera at approximately 1188 Mbps, so J21 itself is known-good.
Jetson configuration path
The live device tree and endpoint graph have been verified from the running system.
The active path is serial_c / port-index 2 / one lane.
RCE SET_CONFIG and STREAM_OPEN both return success.
The sensor continues producing frames, but Jetson captures 0 bytes.
The receiver never reaches:
  • SoT
  • FS
  • FE
  • CHANSEL
  • STREAM
  • HOST1X packet activity
Failure signature
With camrtc log level 2, the dominant error is:
PHY_INTR0, brick 1 / CIL A, raw status 0x00000001
R36.5.2 identifies this as:
At matched 100 Mbps, this occurs in repeatable bursts. No packet-level progress follows.
At 1 Gbps the same CLK_LANE_CTRL error class occurs, although much less frequently.
With lp_bypass_mode = 0, CLK_LANE_CTRL remains present and CIL_INTR1 additionally reports:
0x00000400
which corresponds to the public T234 symbol:
DPHY_CLK_LANE_ULPM_REQ
I am NOT assuming that this means the VL53 transmitted a standards-valid ULPS request. I would specifically like clarification on what physical / state-machine condition causes T234 to assert this bit.
Controls already eliminated
We have already tested or source-audited the following:
  • lane polarity
  • one-lane configuration
  • 100 Mbps and 1 Gbps operation
  • receiver-before-sensor sequencing
  • sensor-before-receiver sequencing
  • repeated sensor STOP / START
  • sensor reset / firmware restart
  • lp_bypass_mode = 0 and 1
  • discontinuous_clk
  • t_clk_settle
  • different L4T 36.5.x Linux-side versions
  • live DT / endpoint configuration
discontinuous_clk was source-audited in R36.5.2. It is parsed into the sensor signal properties, but I could not find it propagated into csi5_fops / RCE / CIL programming, so changing that property does not appear to change the receiver configuration.
t_clk_settle
I patched the official nvcsi_cil_config::t_clk_settle field through the RCE ABI and verified that the requested value changes the programmed CIL state.
At 100 Mbps:
request 0/default:
CONTROL_0 = 0x2346b2b3
request 27:
CONTROL_0 = 0x0d1ab2b3
request 35:
CONTROL_0 = 0x1122b2b3
request 43:
CONTROL_0 = 0x152ab2b3
request 70:
request 120:
CONTROL_0 = 0x3c78b2b3
Explicit 70 reproduces the firmware-computed default bit-for-bit.
Values below and above the default changed the number of CLK_LANE_CTRL interrupt bursts, but did not change the failure class.
No tested settle value produced:
  • SoT
  • FS / FE
  • CHANSEL
  • STREAM
  • HOST1X
  • nonzero captured bytes
The default-equivalent value produced the lowest error activity of the tested series.
Inverse-order acquisition test
We also tested whether this was specifically caused by the VL53 LP-to-HS START transition.
Sequence:
  1. Jetson CSI receiver fully closed
  2. VL53 started at 100 Mbps
  3. Sensor confirmed continuously streaming at approximately 100 fps, FSM healthy, ERR 0
  4. Sensor left completely untouched
  5. Jetson CSI receiver opened into the already-running stream
  6. Capture attempted
  7. Receiver closed again while VL53 continued streaming
  8. Receiver re-opened again into the same continuously running stream
  9. Only after both attempts was the VL53 stopped
Both acquisitions reproduced the same pre-SoT CLK_LANE_CTRL failure with 0 bytes.
Interestingly, the second receiver arm generated a burst beginning with data-lane control errors similar to the previous “START burst”, even though the transmitter had made no START / LP transition at all.
This suggests that at least some of that signature is generated by the CIL arming and interpreting the current lane state rather than by a new sensor-side transition.
CAPTURE_PHY_STREAM_DUMPREGS_REQ
I also tested CAPTURE_PHY_STREAM_DUMPREGS_REQ on this RCE firmware.
It was attempted:
  • before / after open
  • before / after close
  • real CSI port and unspecified port
  • both bricks
  • camrtc log level 3 with string tracing
All attempts returned INVALID_PARAMETER and RCE emitted no register dump.
RCE firmware is unchanged between those tests and the current experiments.
Questions for NVIDIA
  1. On T234, what exact electrical / LP-state condition causes PHY_INTR0 bit 0, DPHY_ERR_CLK_LANE_CTRL?
The public definition describes a clock-lane LP sequence error, but I would like to understand what specific state transition or illegal state the CIL is detecting.
  1. What exactly causes CIL_INTR1 bit 10, DPHY_CLK_LANE_ULPM_REQ, on T234?
Does this correspond to detection of LP10, attempted ULPS entry, an aborted LP sequence, remote-reset detection, or another clock-lane condition?
  1. Does the T234 D-PHY receiver require observing LP11 / Stop State before entering HS reception?
In particular, is opening / arming the CIL while the source is already continuously transmitting HS expected to fail acquisition?
  1. Are there T234-specific controls for any of the following which are programmed internally by camrtc/RCE but are not exposed through nvcsi_cil_config?
  • LP comparator thresholds
  • LP input filtering
  • deglitch / debounce
  • Stop State qualification
  • ULPS / ULPM detection
  • LP sequence timing
  • clock-lane state-machine configuration
  1. Is there a supported RCE / NVCSI diagnostic that exposes the current clock-lane LP state or Stop State on T234?
  2. Are there known interoperability issues between T234 NVCSI and ST CSI-2 transmitters where the same D-PHY stream is accepted by Raspberry Pi RP1 but T234 reports CLK_LANE_CTRL before SoT?
  3. Are there additional T234 clock-lane timing parameters calculated internally by RCE besides t_clk_settle that are not represented in the public nvcsi_cil_config structure?
  4. Is there an internal NVIDIA diagnostic or register dump that can distinguish something like:
LP11 → LP01 → LP00 → HS
from a clock lane being interpreted as:
LP11 → LP10 / ULPS-like state
without requiring external electrical measurement?
Related ST / Orin case
I found another ST camera case on the NVIDIA forum with a notably similar architecture: ST VD66GY / VD56G3 evaluation hardware works on Raspberry Pi, the sensor is confirmed streaming, but Orin receives no frames.
That thread is here:
At this point we are preparing a Pi-versus-Orin electrical comparison of CLK_P / CLK_N, but I want to make sure there is no T234-specific CIL requirement, closed-RCE control, or internal diagnostic we are missing before moving to physical probing.
The key question is:
T234 CIL reports PHY_INTR0 bit 0 / CLK_LANE_CTRL before SoT, while the exact transmitter is accepted by RP1. What exact T234 state-machine condition generates this error, and what internal controls or state visibility are available for diagnosing it?
I can provide the complete RTCPU traces, patched csi5_fops.c, live device tree, RCE register snapshots, raw interrupt classification, and full test matrix if useful.
hello trex442,
PHY_INTR0 = 0x00000001, it means LP sequence error detected on clock lane [A/B]. it should follow by LP11->LP01->LP00->LP11 sequence.
it’s only CSI0 D1 and CSI1 D0 P/N will always been swizzled for P/N. you should set lane_polarity = "0"; since you’re using CSI-C.
it’s cil_settletime to configure THS settle time of the MIPI lane, the unit is in nanoseconds.
Thanks Jerry, that matches what we see. lane_polarity is already “0” on CSI-C (the same port streams an IMX296 and an OV64A40 fine with “0” and fails with “1”), and sweeping the settle time changed nothing, which fits since the error is on the clock lane. Two follow-ups:
  1. The sensor (ST VL53L9) gates its clock lane between frames. Raspberry Pi receivers accept its LP11→LP01→LP00 entry, but NVCSI raises PHY_INTR0 0x1 in bursts locked to the sensor’s frame rate. In r36.5, is there a way to tell NVCSI the clock is non-continuous, or to relax or mask the clock-lane LP sequence check? discontinuous_clk in the DT doesn’t seem to reach the RCE.
  2. What minimum LP-01 / LP-00 duration (TLPX) does the NVCSI LP receiver need on the clock lane? That would tell us whether the sensor’s timing is below what the Orin can detect.
hello trex442,
you may arrange hardware resources to probe the high-speed signaling,
please capture CLK_P and CLK_N individually relative to ground near the Jetson connector.
