automatically enter recovery mode at startup, log as follow:
** WARNING: Test Key is used. **
…DisplayLocateChildGopHandle: failed to enumerate graphics output device handles: Not Found
UpdatePcieControllersWithGpuDevice: failed to enumerate GPU device handles: Not Found
InstallFdt: Installing Kernel DTB
Processing “L4T Configuration Settings” DTB overlay
Deleting fragment fragment@0
Processing “P3767 Overlay Support” DTB overlay
Deleting fragment fragment@1
Deleting fragment fragment@2
Deleting fragment fragment@3
Processing “P3768 Overlay Support” DTB overlay
UpdateRamOopsMemory: RamOopsBase: 0x46EB70000, RamOopsSize: 0x200000
FtpmProtocol Not Found - Not Found
[Bds]Booting UEFI KINGSTON OM8PGP41024Q-A0 50026B738300C208
add-symbol-file /out/nvidia/bootloader/uefi/Jetson_RELEASE/Build/Jetson/RELEASE_GCC5/AARCH64/Silicon/NVIDIA/Application/L4TLauncher/L4TLauncher/DEBUG/L4TLauncher.dll 0x45B43C000
Loading driver at 0x0045B43B000 EntryPoint=0x0045B4478AC L4TLauncher.efi
717 switch (mRootfsInfo.RootfsVar[RF_REDUNDANCY].Value) {
718 case NVIDIA_OS_REDUNDANCY_BOOT_ONLY:
719 ErrorPrint (L"ValidateRootfsStatus TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT 6 \r\n");
720 // There is no rootfs B. Ensure to set rootfs slot to A.
721 if (mRootfsInfo.CurrentSlot != ROOTFS_SLOT_A) {
722 mRootfsInfo.CurrentSlot = ROOTFS_SLOT_A;
723 }
724
725 // If current slot is bootable, decrease slot RetryCount by 1 and go on boot;
726 // if current slot is unbootable, set slot status as unbootable and boot to recovery kernel.
727 if (IsRootfsSlotBootable (mRootfsInfo.CurrentSlot)) {
728 Status = DecreaseRootfsRetryCount(mRootfsInfo.CurrentSlot);
each time the machine starts, “RootfsRetryCount” will decrease by one, my question is where to restored “RootfsRetryCount”?
my system does not enable A/B rootfs, after flashing the machne , SLOT B is in used,
why is slot A checked here?
hi @DavidDDD ,
在系统服务中更新SCRATCH MEM计数不是一个好的选择。之前测试过,在rc.loacl中执行reboot,很容易复现这个问题。我这里没有使用AB分区,即使标记了rootfs无法使用,也没有更好策略进行下一步。我可能会把这个更新动作添加到内核模块中,或者UEFI中禁止这个功能。感谢!
