Orin NX can't use ddcutil
nvidia@ubuntu:~$ ddcutil detect
(i2c_set_addr ) set_addr(/dev/i2c-0,I2C_SLAVE,0x50) failed, error = EBUSY
No displays found.
Is DDC/CI enabled in the monitor’s on screen display?
Run “ddcutil environment” to check for system configuration problems.
nvidia@ubuntu:~$ ddcutil environment
The following tests probe the runtime environment using multiple overlapping methods.
*** Basic System Information ***
ddcutil version: 1.2.2
/proc/version:
Linux version 5.15.136-tegra (buildbrain@mobile-u64-6367-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024
Architecture: aarch64
Distributor id: Ubuntu
Release: 22.04
Found a known architecture
/proc/cmdline:
root=PARTUUID=5cce7512-1504-4620-9f70-6e6153ab29c3 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
*** Primary Check 1: Identify video card and driver ***
Obtaining card and driver information from /sys…
*** Primary Check 2: Check that /dev/i2c-* exist and writable ***
Current user: nvidia (1000)
Checking /dev/i2c-* devices…
Devices /dev/i2c-* must exist and the logged on user must have read/write permission for those devices (or at least those devices associated
with monitors).
Typically, this access is enabled by:
  • setting the group for /dev/i2c-* to i2c
  • setting group RW permissions for /dev/i2c-*
  • making the current user a member of group i2c
Alternatively, this can be enabled by just giving everyone RW permission
The following tests probe for these conditions.
Checking for /dev/i2c-* devices…
crw-rw---- 1 root i2c 89, 0 6月 6 13:35 /dev/i2c-0
crw-rw---- 1 root i2c 89, 1 6月 6 13:35 /dev/i2c-1
crw-rw---- 1 root i2c 89, 10 6月 6 13:35 /dev/i2c-10
crw-rw---- 1 root i2c 89, 11 6月 6 13:35 /dev/i2c-11
crw-rw---- 1 root i2c 89, 2 6月 6 13:35 /dev/i2c-2
crw-rw---- 1 root i2c 89, 4 6月 6 13:35 /dev/i2c-4
crw-rw---- 1 root i2c 89, 5 6月 6 13:35 /dev/i2c-5
crw-rw---- 1 root i2c 89, 7 6月 6 13:35 /dev/i2c-7
crw-rw---- 1 root i2c 89, 9 6月 6 13:35 /dev/i2c-9
Current user (nvidia) has RW access to all /dev/i2c-* devices.
*** Primary Check 3: Check that module i2c_dev is loaded ***
Checking for driver i2c_dev…
sysfs reports module i2c_dev is NOT loaded.
Module i2c_dev is built into the kernel
*** Primary Check 4: Driver specific checks ***
Performing driver specific checks…
No driver specific checks apply.
*** Additional probes ***
Examining /sys/bus/i2c/devices…
/sys/bus/i2c/devices/4-003c/name: vrs-pseq
/sys/bus/i2c/devices/i2c-0/name: 3160000.i2c
/sys/bus/i2c/devices/i2c-1/name: c240000.i2c
/sys/bus/i2c/devices/i2c-2/name: 3180000.i2c
/sys/bus/i2c/devices/i2c-4/name: Tegra BPMP I2C adapter
/sys/bus/i2c/devices/i2c-5/name: 31b0000.i2c
/sys/bus/i2c/devices/i2c-7/name: c250000.i2c
/sys/bus/i2c/devices/i2c-9/name: i2c-2-mux (chan_id 1)
/sys/bus/i2c/devices/i2c-10/name: i2c-2-mux (chan_id 0)
/sys/bus/i2c/devices/10-0010/name: imx219
/sys/bus/i2c/devices/9-0010/name: imx219
/sys/bus/i2c/devices/i2c-11/name: NVIDIA SOC i2c adapter 0
/sys/bus/i2c/devices/1-0025/name: fusb301
/sys/bus/i2c/devices/1-0040/name: ina3221
/sys/bus/i2c/devices/0-0050/name: 24c02
/sys/bus/i2c/devices/0-0057/name: 24c02
Env_Accumulator:
architecture: aarch64
distributor_id Ubuntu
Drivers detected:
/dev/i2c device numbers: 0 1 2 4 5 7 9 10 11
sysfs_i2c_devices_exist: true
/sys/bus/i2c device numbers: 0 1 2 4 5 7 9 10 11
dev_i2c_devices_required: true
module_i2c_dev_needed: true
module_i2c_dev_builtin: true
loadable_i2c_dev_exists: false
i2c_dev_loaded_or_builtin: true
group_i2c_checked: true
group_i2c_exists: true
dev_i2c_common_group_name: i2c
all_dev_i2c_has_group_i2c: true
any_dev_i2c_has_group_i2c: true
all_dev_i2c_is_group_rw: true
any_dev_i2c_is_group_rw: true
cur_uname: nvidia
cur_uid: 1000
cur_user_in_group_i2c: true
cur_user_any_devi2c_rw: true
cur_user_all_devi2c_rw: true
Configuration suggestions:
Current user has RW access to all /dev/i2c-N devices.
Skipping further group and permission checks.
nvidia@ubuntu:~$
It is no support on Orin.
Do you have any plans to support this feature?
And Why ? I can use it on “Xavier AGX”
Driver structure is totally changed. What supported on Xaiver does not mean it would work on Orin.
Well, whether it can be supported after updating the driver
