Orin NX CVB DisplayPort can't display in kernel stage
Hi NV_Team,
We designed a CVB for Orin NX with Display-Port.
In UEFI stage DP works fine, but when Orin NX goes into kernel stage DP can’t display anything. Please give some help.
Here is the boot uart log.
T801_Orin_NX_Bootup_No_DP_20230112.txt (87.5 KB)
UEFI can see logo does not always mean the hardware is correct. Please check your hardware design again with the design guide document.
Especially the data lane 0 and lane2 order is correct or not.
Hi WayneWWW,
We designed the DP refer to the document and Pinmux is the same as Figure 9-1.
<Jetson_Orin_NX_Series_and_Orin_Nano_Series_Design_Guide_DG-10931-001_v0.99.pdf>
please complete your system configuration. Boot into device and share the result of xrandr.
Hi WanyeWWW,
(ssh to run xrandr)
last dmesg log :
[   42.855695] fuse: init (API version 7.32)
[   43.044031] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.2.0  Release Build  (buildbrain@mobile-u64-5320-d8000)  Sat Nov 12 22:58:44 PST 2022
[   43.044184] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[   43.044204] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[   43.044234] CPU: 1 PID: 1465 Comm: modprobe Tainted: G           OE     5.10.104-tegra #1
[   43.044243] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 2.0-31908911 11/13/2022
[   43.044252] Call trace:
[   43.044292]  dump_backtrace+0x0/0x1d0
[   43.044311]  show_stack+0x2c/0x40
[   43.044329]  dump_stack+0xd8/0x138
[   43.044657]  os_dump_stack+0x18/0x20 [nvidia]
[   43.044970]  tlsEntryGet+0x130/0x138 [nvidia]
[   43.045279]  gpumgrGetSomeGpu+0x7c/0x90 [nvidia]
[   43.045582]  threadPriorityStateFree+0xa8/0x2a8 [nvidia]
[   43.045884]  rmclientConstruct_IMPL+0x170/0x240 [nvidia]
[   43.046186]  __nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
[   43.046488]  __nvoc_objCreate_RmClient+0x78/0x110 [nvidia]
[   43.046791]  resservClientFactory+0x28/0x90 [nvidia]
[   43.047091]  serverAllocClient+0x19c/0x318 [nvidia]
[   43.047390]  serverAllocResource+0x140/0x2e0 [nvidia]
[   43.047693]  rmapiAllocWithSecInfo+0x180/0x2e0 [nvidia]
[   43.047992]  rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[   43.048291]  rmapiControlWithSecInfoTls+0x4a8/0x520 [nvidia]
[   43.048534]  nvkms_call_rm+0x60/0x98 [nvidia_modeset]
[   43.048764]  nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[   43.048781]  do_one_initcall+0x4c/0x2d0
[   43.048807]  do_init_module+0x4c/0x200
[   43.048820]  load_module+0x1ff8/0x22f0
[   43.048833]  __do_sys_finit_module+0xb4/0xf0
[   43.048847]  __arm64_sys_finit_module+0x28/0x40
[   43.048872]  el0_svc_common.constprop.0+0x7c/0x1c0
[   43.048887]  do_el0_svc+0x34/0xa0
[   43.048910]  el0_svc+0x1c/0x30
[   43.048924]  el0_sync_handler+0xa8/0xb0
[   43.048934]  el0_sync+0x16c/0x180
[   43.049080] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[   43.049122] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[   43.279937] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[   43.281390] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[   43.287358] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[   49.340717] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   49.342032] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
1673516599460
Please double check the pinmux configuration. Also, you need to do full flash.
Note that ssh or serial console won’t do the right thing with xrandr unless you’ve correctly set your “DISPLAY” environment variable (which might need to be exported as either “:0” or “:1”). Also, if using ssh for manipulating the GUI be sure to not use the “ssh -Y” or “ssh -X” options.
Hi linuxdev,
Before run xrandr, we have export DISPLAY=:0
1673516599460
If you run this command, does only the “Xorg.0.log” show up?
ls -ltr /var/log/Xorg.*.log
If a “Xorg.1.log” (or any other number) shows up, then you might be looking at the wrong server instance. If not, then I recommend setting the log to verbose, rebooting, and seeing what that log says about various modes. This would be an indication of whether the DDC wire is working to send the EDID configuration.
In “/etc/X11/xorg.conf”, add the “ModeDebug” to Section "Device":
Section "Device"
   Option "ModeDebug"
After reboot, post the Xorg.0.log.
Hi linuxdev,
Thanks for your information.
nvidia@nvidia-desktop:~$ ls -ltr /var/log/Xorg.*.log
-rw-r--r-- 1 root root 16480 1月  16 15:50 /var/log/Xorg.0.log
Here is the
Xorg.0.log (16.1 KB)
nvidia@nvidia-desktop:~$ cat /etc/X11/xorg.conf
# Copyright (c) 2011-2013 NVIDIA CORPORATION.  All Rights Reserved.
# This is the minimal configuration necessary to use the Tegra driver.
# Please refer to the xorg.conf man page for more configuration
# options provided by the X server, including display-related options
# provided by RandR 1.2 and higher.
# Disable extensions not useful on Tegra.
Section "Module"
    Disable     "dri"
    SubSection  "extmod"
        Option  "omit xfree86-dga"
    EndSubSection
EndSection
Section "Device"
    Option "ModeDebug"
    Identifier  "Tegra0"
    Driver      "nvidia"
# Allow X server to be started even if no display devices are connected.
    Option      "AllowEmptyInitialConfiguration" "true"
EndSection
Hi WayneWWW,
We have checked the Pinmux, and it’s correct.
BTW the same SOM and SSD put on Orin NX Devkit DP display is Okay.
Then sorry to say. I really think you need to review your hardware.
Hi WayneWWW,
Okay, Orin NX Hardware design guide have update? What’s the newest version number?
The debug log shows no sign that there is EDID data (from the DDC wire; this is what makes it possible to query the monitor for capabilities). So this probably is hardware configuration in some way. In particular, does your monitor correctly output the EDID when queried? If so, does the DDC wire on your carrier have correct wiring? If wiring is correct, is power being provided (3.3V) on the DP_PWR pin? See:
https://en.wikipedia.org/wiki/DisplayPort#DP_PWR_(pin_20)
If power is not provided, then the i2c circuit cannot respond. Usually that power requires a device tree entry.
@Luna2020 Did you find a cause / fix for this issue? I am also seeing something similar; UEFI output works, nothing with Linux.
Hi Ursula,
Not solved yet.
BTW, we change to HDMI port instead.
Hi @Luna2020,
Sorry that I just realized what you are using is different from what I thought. Please check if your dcb image is based on below.
If it is not, then it probably the cause.
+	display@13800000 {
+		nvidia,dcb-image = [
+			55 aa 16 00 00 37 34 30 30 e9 4c 19 77 cc 56 49
+			44 45 4f 20 0d 00 00 00 70 01 00 00 00 00 49 42
+			4d 20 56 47 41 20 43 6f 6d 70 61 74 69 62 6c 65
+			01 00 00 00 10 00 82 18 30 38 2f 31 31 2f 32 32
+			00 00 00 00 00 00 00 00 21 18 50 00 e1 2b 00 00
+			50 4d 49 44 00 00 00 00 00 00 00 a0 00 b0 00 b8
+			00 c0 00 0e 47 41 31 30 42 20 56 47 41 20 42 49
+			4f 53 0d 0a 00 00 00 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 56 65 72 73 69 6f 6e 20 39 34 2e
+			30 42 2e 30 30 2e 30 30 2e 32 31 20 0d 0a 00 43
+			6f 70 79 72 69 67 68 74 20 28 43 29 20 31 39 39
+			36 2d 32 30 32 32 20 4e 56 49 44 49 41 20 43 6f
+			72 70 2e 0d 0a 00 00 00 ff ff 00 00 00 00 ff ff
+			47 50 55 20 42 6f 61 72 64 00 00 00 00 00 00 00
+			00 00 00 43 68 69 70 20 52 65 76 20 20 20 00 00
+			00 00 00 00 00 00 00 ba 91 98 96 91 9a 9a 8d 96
+			91 98 df ad 9a 93 9a 9e 8c 9a df d2 df b1 90 8b
+			df b9 90 8d df af 8d 90 9b 8a 9c 8b 96 90 91 df
+			aa 8c 9a f2 f5 ff 00 00 00 00 00 00 00 00 00 00
+			50 43 49 52 de 10 94 22 00 00 18 00 00 00 00 03
+			16 00 01 00 00 80 00 00 2e 8b c0 2e 8b c0 8b c0
+			4e 50 44 45 01 01 14 00 16 00 00 01 00 00 00 00
+			ff b8 42 49 54 00 00 01 0c 06 13 44 32 01 04 00
+			3e 02 42 02 25 00 4a 02 43 02 2c 00 6f 02 44 01
+			04 00 9b 02 49 01 24 00 9f 02 4d 02 29 00 c3 02
+			4e 00 00 00 00 00 50 02 fc 00 ec 02 53 02 18 00
+			e8 03 54 01 02 00 00 04 55 01 05 00 0a 04 56 01
+			06 00 0f 04 78 01 08 00 15 04 64 01 02 00 1d 04
+			70 02 04 00 1f 04 75 01 11 00 23 04 69 02 6e 00
+			34 04 45 01 04 00 02 04 73 01 04 00 06 04 00 00
+			a2 04 a2 04 e9 21 f0 21 e0 2b 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 0b 94 21 00
+			00 00 00 00 a8 07 00 00 00 00 00 00 00 00 02 00
+			5c 5c 2e 02 00 00 42 02 04 00 10 00 00 00 00 e9
+			0e 00 00 00 00 00 00 39 44 00 00 e7 2d 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 92 30 00 00 e5
+			44 00 00 23 45 00 00 4a 45 00 00 00 00 00 00 f6
+			04 00 00 00 00 fa 04 00 00 66 08 fa 04 16 2b 66
+			08 18 2b a2 04 ef 09 04 22 d4 09 c2 21 18 2b 90
+			00 9b 22 01 68 08 56 09 f4 43 00 00 fe 43 00 00
+			f7 0f 00 00 f0 21 00 00 fc 21 00 00 54 4a 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 d5 33 00 00
+			bb 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 b3 3c 00 00
+			00 00 00 00 ed 3c 00 00 12 43 00 00 00 00 00 00
+			00 00 00 00 df 33 00 00 32 3d 00 00 a0 43 00 00
+			ad 36 00 00 00 00 00 00 00 00 00 00 c2 43 00 00
+			00 00 00 00 61 0b 00 00 dd 0a 00 00 77 0b 00 00
+			11 3c 00 00 17 3c 00 00 1c 3c 00 00 20 3c 00 00
+			2a 3c 00 00 31 3c 00 00 3f 3c 00 00 81 3c 00 00
+			00 00 00 00 00 00 00 00 96 3c 00 00 f0 45 00 00
+			96 47 00 00 0b 48 00 00 91 49 00 00 80 4b 00 00
+			bc 4b 00 00 e6 49 00 00 9c 3c 00 00 79 3c 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 ec 4d 00 00
+			a0 3c 00 00 a9 3c 00 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 64 00 50 b5 00 19 cf 00
+			28 91 0e 14 a5 0e 23 00 01 23 23 01 14 00 00 00
+			0c 11 00 00 00 00 83 17 00 00 c8 0e 01 00 00 0d
+			0e df 0c 00 00 00 00 01 01 00 00 00 00 af 1d 31
+			4e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+			b2 2d 00 00 00 00 0b 94 21 00 00 09 65 e3 01 f0
+			03 00 00 30 38 2f 31 31 2f 32 32 00 00 00 00 00
+			00 00 00 00 00 00 00 21 01 10 00 00 00 80 01 00
+			00 00 00 00 30 30 30 30 30 30 30 30 30 30 30 30
+			00 00 00 00 00 00 00 00 03 42 00 00 e4 1b 6e a6
+			e1 58 4e 04 89 12 1c 44 46 eb b6 6b 54 33 00 00
+			00 00 00 00 c9 4c 00 00 00 00 00 00 00 00 97 4e
+			00 00 01 00 10 00 bf 09 30 00 02 00 94 22 00 00
+			00 00 01 00 44 00 6b 09 00 00 a2 04 00 00 56 09
+			00 00 fa 04 00 00 00 00 00 00 66 08 00 00 78 08
+			00 00 61 0b 00 00 dd 0a 00 00 77 0b 00 00 8d 0b
+			00 00 0d 0e 00 00 df 0c 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 2c 22 00 00 30 c0 61 40 00 00
+			00 10 00 00 00 00 08 23 61 00 80 00 00 00 80 00
+			00 00 88 23 61 00 80 00 00 00 80 00 00 00 08 24
+			61 00 80 00 00 00 80 00 00 00 88 24 61 00 80 00
+			00 00 80 00 00 00 08 25 61 00 80 00 00 00 80 00
+			00 00 88 25 61 00 80 00 00 00 80 00 00 00 08 26
+			61 00 80 00 00 00 80 00 00 00 00 2a 13 00 00 00
+			04 00 00 00 04 00 00 2a 13 00 00 00 01 00 00 00
+			01 00 00 6e 13 00 00 00 04 00 00 00 04 00 00 6e
+			13 00 00 00 01 00 00 00 01 00 4c 00 12 00 3f 00
+			00 00 00 00 00 00 0c 24 02 00 01 00 00 00 00 00
+			00 00 e4 05 02 00 7c 00 00 00 00 00 00 00 e4 05
+			02 00 7c 00 00 00 18 00 00 00 e4 05 02 00 7c 00
+			00 00 0c 00 00 00 e4 05 02 00 7c 00 00 00 04 00
+			00 00 e4 05 02 00 7c 00 00 00 08 00 00 00 e4 05
+			02 00 7c 00 00 00 14 00 00 00 20 0e 9a 00 00 00
+			02 00 00 00 02 00 00 0e 9a 00 00 00 02 00 00 00
+			02 00 00 0e 9a 00 01 00 00 00 01 00 00 00 34 c0
+			61 40 00 00 00 80 00 00 00 00 00 0c 82 00 ff ff
+			ff ff 00 00 00 00 00 0c 82 00 01 00 00 00 00 00
+			00 00 00 0c 82 00 02 00 00 00 00 00 00 00 00 0c
+			82 00 04 00 00 00 00 00 00 00 00 0c 82 00 08 00
+			00 00 00 00 00 00 00 0c 82 00 10 00 00 00 00 00
+			00 00 00 0c 82 00 20 00 00 00 00 00 00 00 90 02
+			82 00 01 00 00 00 00 00 00 00 88 02 82 00 ff 00
+			00 00 00 00 00 00 c0 04 82 00 07 00 00 00 00 00
+			00 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 88 80
+			08 00 00 00 0f 00 00 00 01 00 40 c0 08 00 00 00
+			0c 00 00 00 0c 00 40 c0 08 00 1f 00 00 00 00 00
+			00 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 74 09
+			9a 00 0f 00 00 00 00 00 00 00 e8 73 13 00 01 00
+			00 00 01 00 00 00 0c 06 9a 00 40 00 00 00 40 00
+			00 00 64 00 12 00 40 00 00 00 40 00 00 00 04 14
+			00 00 04 00 00 00 00 00 00 00 04 14 00 00 08 00
+			00 00 08 00 00 00 14 38 82 00 00 00 01 00 00 00
+			01 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 0c 14
+			00 00 01 00 00 00 01 00 00 00 0c 14 00 00 02 00
+			00 00 01 00 00 00 88 54 62 00 00 00 01 00 00 00
+			00 00 88 54 62 00 00 00 02 00 00 00 00 00 88 54
+			62 00 00 00 04 00 00 00 00 00 9c 8b 11 00 00 00
+			00 80 00 00 00 00 14 0c 82 00 01 00 00 00 00 00
+			00 00 14 0c 82 00 02 00 00 00 00 00 00 00 14 0c
+			82 00 04 00 00 00 00 00 00 00 14 0c 82 00 08 00
+			00 00 00 00 00 00 14 0c 82 00 10 00 00 00 00 00
+			00 00 14 0c 82 00 20 00 00 00 00 00 00 00 9c 8b
+			11 00 00 00 00 80 00 00 00 00 10 01 82 00 01 00
+			00 00 00 00 00 00 d4 06 82 00 ff 03 00 00 00 00
+			00 00 14 0c 82 00 3f 00 00 00 01 00 00 00 00 14
+			00 00 02 00 00 00 00 00 00 00 44 c1 61 60 01 00
+			00 00 01 00 00 00 20 87 08 00 04 00 00 00 00 00
+			00 00 40 00 82 00 01 00 00 00 00 00 00 00 54 9b
+			41 00 ff 00 00 00 00 00 00 00 68 9b 41 00 03 00
+			00 00 00 00 00 00 40 80 11 00 02 00 00 00 00 00
+			00 00 04 0c 82 00 01 00 00 00 00 00 00 00 04 14
+			00 00 00 04 00 00 00 00 00 00 34 04 82 00 01 00
+			00 00 00 00 00 00 68 08 00 01 02 03 04 05 06 07
+			00 01 02 03 04 05 06 07 41 06 24 06 00 00 00 07
+			00 02 bf 00 01 51 00 04 bf 00 02 5e 00 01 bf 00
+			03 52 00 03 bf 00 84 19 00 00 4f 00 85 7b 59 98
+			4f 00 06 ff 00 00 4f 00 07 ff 00 00 ef 00 08 ff
+			00 00 ef 00 09 ff 00 00 ef 00 0a ff 00 00 ef 00
+			0b ff 00 00 ef 00 0c ff 00 00 ef 00 0d ff 00 00
+			ef 00 0e ff 00 00 ef 00 0f ff 00 00 ef 00 10 42
+			50 11 e4 00 11 41 42 0b e2 00 12 40 41 0a e1 00
+			13 70 51 12 e5 00 14 ff 00 00 ef 00 15 ff 00 00
+			ef 00 16 ff 00 00 ef 00 17 ff 00 00 ef 00 18 ff
+			00 00 ef 00 19 ff 00 00 ef 00 1a ff 00 00 ef 00
+			1b ff 00 00 ef 00 1c ff 00 00 ef 00 1d ff 00 00
+			ef 00 1e ff 00 00 ef 00 1f ff 00 00 ef 00 00 ff
+			00 00 0f 00 00 ff 00 00 0f 00 00 ff 00 00 0f 00
+			00 ff 00 00 0f 00 10 07 16 10 00 bd 0a 01 f0 10
+			03 00 00 00 00 ff ff ff 00 ff ff 00 10 00 00 00
+			00 00 00 1f 01 00 00 00 00 00 00 ff ff ff 00 ff
+			ff 00 10 00 00 00 00 00 00 2f 02 00 00 00 00 00
+			00 ff ff ff 00 ff ff 00 10 00 00 00 00 00 00 3f
+			03 00 00 00 00 00 00 ff ff ff 00 ff ff 00 10 00
+			00 00 00 00 00 4f 04 00 00 00 00 00 00 ff ff ff
+			00 ff ff 00 10 00 00 00 00 00 00 5f 05 00 00 00
+			00 00 00 ff ff ff 00 ff ff 00 10 00 00 00 00 00
+			00 6f 06 00 00 00 00 00 00 ff ff ff 00 ff ff 00
+			10 00 00 00 00 00 00 7f 07 00 00 00 00 00 00 ff
+			ff ff 00 ff ff 00 10 00 00 00 00 00 00 8f 00 00
+			00 00 00 00 00 ff ff ff 00 ff ff 00 10 00 00 00
+			00 00 00 9f 01 00 00 00 00 00 00 ff ff ff 00 ff
+			ff 00 10 00 00 00 00 00 00 af 02 00 00 00 00 00
+			00 ff ff ff 00 ff ff 00 10 00 00 00 00 00 00 bf
+			00 00 00 00 00 cf 04 00 00 00 00 00 00 ff ff ff
+			00 ff ff 00 10 00 00 00 00 00 00 df 05 00 00 00
+			00 ef 06 00 00 00 00 00 00 ff ff ff 00 ff ff 00
+			10 00 00 00 00 00 00 ff 07 00 00 00 00 00 00 ff
+			ff ff 00 ff ff 00 10 00 00 00 00 00 00 00 01 02
+			03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12
+			13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 10 04 20
+			04 00 00 80 00 b8 4c 0a ff e0 93 04 00 20 d6 13
+			00 e0 93 04 01 20 d6 13 00 ff 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00
+			00 00 00 00 01 00 00 00 00 ff 00 00 00 00 00 00
+			00 20 05 11 01 00 00 35 0c 00 ff ff ff ff ff ff
+			ff ff ff 00 00 00 00 10 05 11 01 00 00 00 00 ff
+			ff 00 00 00 00 00 00 00 00 00 00 00 00 30 08 10
+			01 14 01 15 0e 00 00 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
+			0d 17 34 b0 8f 11 00 00 00 00 00 00 00 00 00 34
+			a8 04 82 00 00 00 00 00 00 00 00 00 34 a0 04 82
+			00 00 00 00 00 00 00 00 00 34 d4 02 82 00 00 00
+			00 00 00 00 00 00 34 a4 04 82 00 00 00 00 00 00
+			00 00 00 34 7c 14 00 00 00 00 00 00 00 00 00 00
+			34 08 0e 82 00 00 00 00 00 00 00 00 00 34 0c 0e
+			82 00 00 00 00 00 00 00 00 00 34 a8 83 11 00 00
+			00 00 00 00 00 00 00 34 78 01 82 00 00 00 00 00
+			00 00 00 00 34 78 01 82 00 00 00 00 00 00 00 00
+			00 34 ac 04 82 00 00 00 00 00 00 00 00 00 34 94
+			10 82 00 00 00 00 00 00 00 00 00 34 88 10 82 00
+			00 00 00 00 00 00 00 00 34 8c 10 82 00 00 00 00
+			00 00 00 00 00 34 90 10 82 00 00 00 00 00 00 00
+			00 00 34 ac 83 11 00 00 00 00 00 00 00 00 00 34
+			78 01 82 00 00 00 00 00 00 00 00 00 34 d4 02 82
+			00 00 00 00 00 00 00 00 00 34 78 05 82 00 00 00
+			00 00 00 00 00 00 34 b0 04 82 00 00 00 00 00 00
+			00 00 00 34 78 01 82 00 00 00 00 00 00 00 00 00
+			34 7c 07 82 00 00 00 00 00 00 00 00 00 10 03 1b
+			05 80 00 07 60 05 08 40 08 09 60 0d 0a 40 10 0d
+			f0 17 0c e0 15 0e 60 18 0f 40 1c 10 e0 23 15 80
+			24 16 26 29 17 60 2d 18 40 30 19 60 35 1a 60 39
+			1b 60 3d 1d e0 43 1e a5 44 1f 60 49 20 60 4d 21
+			60 51 22 fc 47 23 a0 58 24 66 59 25 2c 5a 26 f2
+			5a 68 74 e1 61 8d e9 54 da de d0 33 c4 0d 30 30
+			cb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+			00 4e 56 49 44 49 41 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 4e 56 49 44 49 41 20 43 6f 72 70
+			6f 72 61 74 69 6f 6e 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 22 05 02 0e 0c 00 00 00
+			00 00 00 00 00 00 00 00 00 50 04 13 0e 07 95 01
+			95 01 d0 07 a0 0f 1b 00 1b 00 0f 0f 32 ff 01 3f
+			08 95 01 95 01 d0 07 a0 0f 1b 00 1b 00 0f 0f 32
+			ff 01 3f 0b 95 01 95 01 d0 07 a0 0f 1b 00 1b 00
+			0f 0f 32 ff 01 3f 04 e1 00 13 01 94 11 28 23 e1
+			00 13 01 01 01 14 ff 01 02 0c 1b 00 1b 00 40 06
+			80 0c 1b 00 1b 00 01 01 28 ff 01 3f 41 1b 00 1b
+			00 40 06 8c 0a 1b 00 28 00 01 ff 28 ff 03 3f 42
+			1b 00 1b 00 40 06 8c 0a 1b 00 28 00 01 ff 28 ff
+			03 3f 80 1b 00 1b 00 20 03 54 06 1b 00 1b 00 01
+			01 14 ff 01 3f 81 1b 00 1b 00 20 03 54 06 1b 00
+			1b 00 01 01 14 ff 01 3f 82 1b 00 1b 00 20 03 54
+			06 1b 00 1b 00 01 01 14 ff 01 3f 83 1b 00 1b 00
+			20 03 54 06 1b 00 1b 00 01 01 14 ff 01 3f 0d 1b
+			00 1b 00 20 03 54 06 1b 00 1b 00 01 01 14 ff 01
+			3f 0e 1b 00 1b 00 e8 03 d0 07 0d 00 1b 00 01 ff
+			28 ff 01 1f 0f 95 01 95 01 d0 07 a0 0f 1b 00 1b
+			00 0f 0f 32 ff 01 3f 10 04 02 06 00 00 00 07 00
+			07 00 07 00 07 00 07 10 05 04 10 04 0f 0f 0f 0f
+			2f 2f 2f 2f 1c 1c 1c 1c 0f 46 40 00 0f 0f 0f 0f
+			2f 2f 2f 2f 1d 1d 1d 1d 0f 46 40 00 0f 0f 0f 0f
+			2f 2f 2f 2f 1e 1e 1e 1e 0f 46 40 00 0f 0f 0f 0f
+			2f 2f 2f 2f 1f 1f 1f 1f 0f 46 40 00 0f 0f 0f 0f
+			2d 2d 2d 2d 19 19 19 19 0f 46 40 00 0f 0f 0f 0f
+			2c 2c 2c 2c 1b 1b 1b 1b 0f 46 40 00 0f 0f 0f 0f
+			2b 2b 2b 2b 1d 1d 1d 1d 0f 46 40 00 0f 0f 0f 0f
+			2a 2a 2a 2a 1f 1f 1f 1f 0f 46 40 00 0e 0e 0e 0e
+			29 29 29 29 18 18 18 18 0f 46 40 00 0e 0e 0e 0e
+			28 28 28 28 1a 1a 1a 1a 0f 46 40 00 0e 0e 0e 0e
+			27 27 27 27 1c 1c 1c 1c 0f 46 40 00 0e 0e 0e 0e
+			26 26 26 26 1e 1e 1e 1e 0f 46 40 00 0f 0f 0f 0f
+			2a 2a 2a 2a 1f 1f 1f 1f 0f 46 40 00 20 19 04 00
+			00 50 32 74 40 e8 80 e4 57 01 04 04 06 31 1a 00
+			00 07 10 00 00 3d 11 00 00 3b 12 00 00 39 13 00
+			00 37 14 00 00 35 15 00 00 33 16 00 00 10 08 0e
+			05 00 2c 04 04 d1 84 00 00 00 00 0a 05 00 06 00
+			00 00 00 00 38 3d 3e 3f 3a 00 00 00 00 05 05 05
+			05 00 00 00 00 00 00 00 00 88 58 24 00 00 00 00
+			00 75 40 00 00 00 00 0a 05 00 06 00 00 00 00 00
+			38 3d 3e 3f 3a 3f 3f 3f 3f 05 05 05 05 0a 0a 0a
+			0a 00 00 00 00 88 58 24 00 00 00 00 00 65 19 00
+			00 00 00 0a 05 00 06 00 00 00 00 00 48 3a 3a 3a
+			3a 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00 00 00
+			00 f8 5a 24 00 00 00 00 00 00 00 00 00 00 00 0a
+			0a 00 06 00 00 00 00 00 58 3a 3a 3a 3a 3a 3a 3a
+			3a 00 00 00 00 00 00 00 00 00 00 00 00 f8 5a 24
+			00 00 00 00 00 03 00 00 01 0a 05 0f 46 40 00 00
+			03 00 44 06 00 00 01 0a 08 0f 46 40 00 00 03 00
+			44 08 00 00 01 0a 05 0f 46 40 00 00 03 00 44 0a
+			00 00 01 0a 05 0f 46 40 00 00 03 00 44 0c 00 00
+			01 0a 08 0f 46 40 00 00 03 00 44 10 08 0e 05 00
+			2c 04 04 d1 84 00 00 00 00 0a 05 00 06 00 00 00
+			00 00 38 3d 3e 3f 3a 00 00 00 00 05 05 05 05 00
+			00 00 00 00 00 00 00 88 58 24 00 00 00 00 00 75
+			40 00 00 00 00 0a 05 00 06 00 00 00 00 00 38 3d
+			3e 3f 3a 00 00 00 00 05 05 05 05 00 00 00 00 00
+			00 00 00 88 58 24 00 00 00 00 00 65 19 00 00 00
+			00 0a 05 00 06 00 00 00 00 00 48 3a 3a 3a 3a 00
+			00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f8
+			5a 24 00 00 00 00 00 00 00 00 00 00 00 0a 0a 00
+			06 00 00 00 00 00 58 3a 3a 3a 3a 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 00 f8 5a 24 00 00
+			00 00 00 0c 00 00 01 0a 05 0f 46 40 00 00 03 00
+			44 0d 00 00 01 0a 08 0f 46 40 00 00 03 00 44 0e
+			00 00 01 0a 05 0f 46 40 00 00 03 00 44 0f 01 00
+			01 0a 05 0f 46 40 00 00 03 00 44 10 01 00 01 0a
+			08 0f 46 40 00 00 03 00 44 10 08 0e 05 00 2c 04
+			04 d1 84 00 00 00 00 0a 05 00 06 00 00 00 00 00
+			38 3d 3e 3f 3a 00 00 00 00 05 05 05 05 00 00 00
+			00 00 00 00 00 88 58 24 00 00 00 00 00 75 40 00
+			00 00 00 0a 05 00 06 00 00 00 00 00 38 3d 3e 3f
+			3a 3f 3f 3f 3f 05 05 05 05 05 05 05 05 00 00 00
+			00 88 58 24 00 00 00 00 00 65 19 00 00 00 00 0a
+			05 00 06 00 00 00 00 00 48 3a 3a 3a 3a 3a 3a 3a
+			00 00 00 00 00 00 00 00 00 00 00 0a 0a 00 06 00
+			00 00 00 00 58 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00
+			00 00 00 00 00 00 00 00 00 f8 5a 24 00 00 00 00
+			00 0c 01 00 01 0a 05 0f 46 40 00 00 03 00 44 0d
+			01 00 01 0a 08 0f 46 40 00 00 03 00 44 0e 02 00
+			01 0a 05 0f 46 40 00 00 03 00 44 0f 02 00 01 0a
+			05 0f 46 40 00 00 03 00 44 10 02 00 01 0a 08 0f
+			46 40 00 00 03 00 44 10 08 0e 05 00 2c 04 04 d1
+			84 00 00 00 00 0a 05 00 06 00 00 00 00 00 38 3d
+			00 00 00 88 58 24 00 00 00 00 00 75 40 00 00 00
+			00 0a 05 00 06 00 00 00 00 00 38 3d 3e 3f 3a 00
+			00 00 00 05 05 05 05 00 00 00 00 00 00 00 00 88
+			58 24 00 00 00 00 00 65 19 00 00 00 00 0a 05 00
+			06 00 00 00 00 00 48 3a 3a 3a 3a 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 0a 0a 00 06 00 00 00
+			00 00 58 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 f8 5a 24 00 00 00 00 00 0c
+			00 00 01 0a 05 0f 46 40 00 00 03 00 44 0d 00 00
+			01 0a 08 0f 46 40 00 00 03 00 44 0e 00 00 01 0a
+			05 0f 46 40 00 00 03 00 44 0f 01 00 01 0a 05 0f
+			46 40 00 00 03 00 44 10 01 00 01 0a 08 0f 46 40
+			00 00 03 00 44 10 08 0e 05 00 2c 04 04 d1 84 00
+			3a 00 00 00 00 05 05 05 05 00 00 00 00 00 00 00
+			00 88 58 24 00 00 00 00 00 75 40 00 00 00 00 0a
+			05 00 06 00 00 00 00 00 38 3d 3e 3f 3a 3f 3f 3f
+			3f 05 05 05 05 08 08 08 08 00 00 00 00 88 58 24
+			00 00 00 00 00 65 19 00 00 00 00 0a 05 00 06 00
+			00 00 00 00 48 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00
+			00 00 00 00 00 00 00 0a 0a 00 06 00 00 00 00 00
+			58 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00 00 00 00 00
+			00 00 00 00 00 f8 5a 24 00 00 00 00 00 0c 01 00
+			01 0a 05 0f 46 40 00 00 03 00 44 0d 01 00 01 0a
+			08 0f 46 40 00 00 03 00 44 0e 02 00 01 0a 05 0f
+			46 40 00 00 03 00 44 0f 02 00 01 0a 05 0f 46 40
+			00 00 03 00 44 10 02 00 01 0a 08 0f 46 40 00 00
+			03 00 44 10 08 0e 05 00 2c 04 04 d1 84 00 00 00
+			58 24 00 00 00 00 00 75 40 00 00 00 00 0a 05 00
+			06 00 00 00 00 00 38 3d 3e 3f 3a 00 00 00 00 05
+			05 05 05 00 00 00 00 00 00 00 00 88 58 24 00 00
+			00 00 00 65 19 00 00 00 00 0a 05 00 06 00 00 00
+			00 00 48 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 f8 5a 24 00 00 00 00 00 00
+			00 00 00 00 00 0a 0a 00 06 00 00 00 00 00 58 3a
+			3a 3a 3a 00 00 00 00 00 00 00 00 00 00 00 00 00
+			00 00 00 f8 5a 24 00 00 00 00 00 0c 00 00 01 0a
+			05 0f 46 40 00 00 03 00 44 0d 00 00 01 0a 08 0f
+			46 40 00 00 03 00 44 0e 00 00 01 0a 05 0f 46 40
+			00 00 03 00 44 0f 01 00 01 0a 05 0f 46 40 00 00
+			03 00 44 10 01 00 01 0a 08 0f 46 40 00 00 03 00
+			44 7a 14 c0 61 40 01 00 c2 0d 74 05 00 6e 14 c0
+			61 40 ff ff bf ff 00 00 00 00 6e e4 c5 61 40 fe
+			ff ff ff 00 00 00 00 71 5b b0 1a 71 5b 63 17 5b
+			68 17 71 56 00 ff 72 71 6e 0c c1 61 40 fe ff ff
+			ff 00 00 00 00 6e 40 65 61 80 fe ff ff ff 00 00
+			00 00 71 10 07 01 60 01 60 00 00 00 00 00 00 00
+			00 00 00 00 00 00 00 00 00 00 6e 00 23 61 40 ff
+			ff 80 fc 00 00 23 00 71 6e 00 23 61 40 ff ff 80
+			fc 00 00 27 00 71 6e 00 23 61 40 ff ff 80 fc 00
+			00 2b 00 71 6e 00 23 61 40 ff ff 80 fc 00 00 2f
+			00 71 41 23 10 08 25 19 cb bd dc 4e 78 08 00 00
+			00 00 00 00 67 19 ec 19 c1 00 00 00 00 00 00 00
+			00 00 00 00 00 06 03 80 01 10 00 60 04 02 03 80
+			01 10 00 02 04 0e 11 02 01 10 00 02 00 2e 32 03
+			02 10 00 02 00 fe 40 04 00 00 00 00 00 0f 00 00
+			00 00 00 00 00 0f 00 00 00 00 00 00 00 0f 00 00
+			00 00 00 00 00 41 06 0f 04 02 0f 06 00 00 10 ff
+			03 00 80 ff 03 00 80 ff 03 00 10 ff 03 00 10 ff
+			03 00 10 ff 03 00 10 ff 03 00 10 ff 03 00 10 ff
+			03 00 10 ff 03 00 00 ff 03 00 00 ff 03 00 00 ff
+			03 00 00 ff 03 00 00 40 05 20 04 01 ff 00 00 00
+			ff 00 00 00 ff 00 00 00 ff 00 00 00 ff 00 00 00
+			ff 00 00 00 ff 00 00 00 ff 00 00 00 40 05 10 04
+			00 46 10 00 00 ff 01 00 00 ff 02 00 00 ff 03 00
+			00 ff 04 00 00 ff 00 00 00 ff 00 00 00 ff 00 00
+			00 ff 00 00 00 ff 00 00 00 ff 00 00 00 ff 00 00
+			00 10 05 40 01 00 00 00 0b 03 00 00 0a 02 00 00
+			08 02 00 20 04 02 00 80 00 00 00 80 00 00 00 80
+			00 00 00 80 00 00 00 20 00 00 00 20 00 03 00 00
+			0c 03 00 00 0a 03 00 80 0b 03 00 80 0b 03 00 80
+			0b 03 00 80 0b 03 71 71 6e 14 c0 61 40 ff ff 3f
+			fa 00 00 c0 01 74 05 00 6e 14 c0 61 40 f7 ff ff
+			ff 08 00 00 00 6e b8 c1 61 40 ff ff 3f 81 00 03
+			00 08 6e 00 23 61 40 ff ff 83 fc 00 00 00 00 71
+			58 40 c0 61 40 10 00 00 0a 1d 00 00 0a 04 00 00
+			08 04 00 20 04 04 00 80 00 00 00 80 00 00 00 80
+			00 00 00 80 00 00 00 20 00 00 00 20 00 1d 00 00
+			0c 1d 00 00 0a 1d 00 80 0a 1d 00 80 0a 1d 00 80
+			0a 1d 00 80 0a 1d 71 6e 00 23 61 40 ff ff fc fc
+			00 00 02 03 71 7a 14 c0 61 40 14 00 c2 0d 74 05
+			00 6e 14 c0 61 40 ff ff bf ff 00 00 00 00 74 14
+			00 71 6e 14 c0 61 40 ff ff ff f2 00 00 00 00 74
+			0a 00 6e 00 23 61 40 ff ff fc ff 00 00 01 00 6e
+			0c c1 61 60 ff bf ff ff 00 40 00 00 6e 14 c0 61
+			40 ff ff 7f ff 00 00 00 00 6e 30 c1 61 60 f0 ff
+			ff ff 0f 00 00 00 6e 34 c0 61 40 ff ff ee 7f 00
+			00 00 80 56 17 ff 6e 0c c1 61 60 fc ff ff ff 01
+			00 00 00 6e 30 c1 61 60 0f ff ff ff f0 00 00 00
+			74 0a 00 6e 30 c1 61 60 0f ff ff ff 00 00 00 00
+			6e 10 c1 61 40 e0 e0 e0 e0 00 00 00 00 6e 2c c1
+			61 40 e0 e0 e0 e0 00 00 00 00 3a 05 15 6e 40 c1
+			61 60 fd ff ff ff 02 00 00 00 98 0a 01 00 00 01
+			fe 01 71 98 02 01 00 00 01 d0 00 6e 10 c1 61 40
+			e0 e0 e0 e0 10 10 10 10 6e 2c c1 61 40 e0 e0 e0
+			e0 10 10 10 10 71 5f 0c c1 61 60 00 01 40 ff 40
+			00 00 00 00 40 65 61 80 fe bf 00 bf 3a 00 03 5b
+			14 1c 72 71 3a 07 01 38 6e 40 c1 61 60 fe ff ff
+			ff 01 00 00 00 72 5b 68 1d 52 e8 df 00 71 71 6e
+			0c c1 61 60 fe ff 00 ff 00 00 00 00 6e 30 c1 61
+			40 f0 ff ff ff 00 00 00 00 6e b0 c1 61 40 f0 ff
+			ff ff 00 00 00 00 6e 34 c0 61 40 ff ff ee 7f 00
+			00 11 80 56 17 ff 6e 14 c0 61 40 ff ff 7f ff 00
+			00 80 00 6e 00 23 61 40 ff ff fc ff 00 00 02 00
+			74 05 00 6e 14 c0 61 40 ff ff ff f2 00 00 00 0d
+			74 05 00 6e 14 c0 61 40 ff ff bf ff 00 00 40 00
+			74 05 00 6e 14 c0 61 40 f7 ff ff ff 08 00 00 00
+			6e 0c c0 61 40 ff f0 f0 f0 00 03 05 05 6e b8 c1
+			61 40 ff ff ff 81 00 03 00 08 6e 00 23 61 40 ff
+			ff 83 fc 00 00 00 00 6e 40 c1 61 60 fe ff ff ff
+			00 00 00 00 71 6e 0c c1 61 60 fd ff ff ff 02 00
+			00 00 6e 30 c1 61 60 ff ff bf ff 00 00 40 00 71
+			10 05 40 01 01 00 00 00 00 0a 10 00 00 00 a0 40
+			00 00 80 40 00 00 80 40 00 00 80 40 00 00 80 40
+			00 00 80 40 00 00 20 00 00 32 10 80 00 0a 90 80
+			00 00 80 80 00 00 80 80 00 00 80 80 00 00 80 80
+			00 00 80 80 00 71 71 6e 40 65 61 80 fe ff ff ff
+			00 00 00 00 71 71 98 07 01 00 00 01 ef 10 71 98
+			07 01 00 00 01 ef 00 71 58 40 c0 61 40 10 00 00
+			00 00 32 10 00 00 00 a0 40 00 00 80 40 00 00 80
+			40 00 00 80 40 00 00 80 40 00 00 80 40 00 00 20
+			00 00 32 10 80 00 96 90 80 00 00 80 80 00 00 80
+			80 00 00 80 80 00 00 80 80 00 00 80 80 00 71 42
+			15 02 07 13 04 03 0a 04 28 23 28 23 01 04 04 06
+			00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+			00 00 14 00 02 19 0a 03 1e 14 04 2b 28 06 1e 00
+			03 25 0f 04 2f 21 06 28 00 04 32 14 06 3c 00 06
+			14 00 02 19 0a 03 1e 14 04 2b 28 06 1e 00 03 25
+			0f 04 2f 21 06 28 00 04 32 14 06 3c 00 06 14 00
+			02 19 0a 03 1e 14 04 2b 28 06 1e 00 03 25 0f 04
+			2f 21 06 28 00 04 32 14 06 3c 00 06 0f 00 02 16
+			09 03 1d 0e 04 27 12 06 17 00 03 21 09 04 27 0e
+			06 1f 00 04 27 09 06 27 00 06 62 1e 00 00 f2 1e
+			00 00 82 1f 00 00 12 20 00 00 a2 20 00 00 32 21
+			00 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 01
+			05 05 00 40 00 00 00 00 00 30 00 14 00 00 00 00
+			01 05 05 00 40 00 00 00 00 00 30 00 10 00 00 00
+			00 01 05 05 00 40 00 00 00 00 00 30 00 0c 00 00
+			00 00 01 05 05 00 40 00 00 00 00 00 30 00 0a 00
+			00 00 00 01 05 05 00 40 00 00 00 00 00 30 00 09
+			00 00 00 00 01 05 05 00 40 00 00 00 00 00 30 00
+			08 00 00 00 00 01 05 05 00 40 00 00 00 00 00 30
+			00 06 00 00 00 00 01 05 05 00 40 00 00 00 00 00
+			30 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 00
+			05 05 00 00 00 00 00 00 00 00 00 14 00 00 00 00
+			00 05 05 00 00 00 00 00 00 00 00 00 10 00 00 00
+			00 03 00 01 00 50 00 00 00 00 00 00 00 0c 00 00
+			00 00 03 00 01 00 50 00 00 00 00 00 00 00 0a 00
+			00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 09
+			00 00 00 00 03 00 01 00 40 00 00 00 00 00 00 00
+			08 00 00 00 00 03 00 01 00 40 00 00 00 00 00 00
+			00 06 00 00 00 00 00 05 05 00 00 00 00 00 00 00
+			00 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 00
+			00 00 ];
