Several days ago, I call for RMA of my old Orin, because of a defective USB port(10).
Today, I received the new Orin from RMA with joy. However, the DP port did not work when I used DP-to-HDMI cable to connect Orin to Display. I have checked that the DP-to-HDMI cable and the Display were ok by connect my computer’s DP(out) to Display’s HDMI(in) with the DP-to-HDMI cable.
So, I have no choice but use headless mode to initiate Ubuntu on the Orin, then ssh login the Orin.
I used “sudo dmesg” and got the following output which showed “no port node found”.
Then I used “gdm”.
Then I got “Xorg.0.log”.
leon@orin:~$ cat /var/log/Xorg.0.log
[ 23.420] (--) Log file renamed from "/var/log/Xorg.pid-1380.log" to "/var/log/Xorg.0.log"
[ 23.421]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[ 23.421] Build Operating System: linux Ubuntu
[ 23.421] Current Operating System: Linux orin 5.10.65-tegra #1 SMP PREEMPT Tue Mar 15 00:53:43 PDT 2022 aarch64
[ 23.421] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 23.421] Build Date: 14 December 2021 02:14:13PM
[ 23.421] xorg-server 2:1.20.13-1ubuntu1~20.04.2 (For technical support please see http://www.ubuntu.com/support)
[ 23.421] Current version of pixman: 0.38.4
[ 23.421] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 23.421] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 23.421] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 20 21:35:07 2023
[ 23.425] (==) Using config file: "/etc/X11/xorg.conf"
[ 23.425] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 23.425] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 23.428] (==) No Layout section. Using the first Screen section.
[ 23.428] (==) No screen section available. Using defaults.
[ 23.428] (**) |-->Screen "Default Screen Section" (0)
[ 23.428] (**) | |-->Monitor "<default monitor>"
[ 23.428] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 23.428] (**) | |-->Device "Tegra0"
[ 23.428] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 23.428] (==) Automatically adding devices
[ 23.428] (==) Automatically enabling devices
[ 23.428] (==) Automatically adding GPU devices
[ 23.428] (==) Automatically binding GPU devices
[ 23.428] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 23.432] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 23.433] Entry deleted from font path.
[ 23.433] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 23.433] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 23.433] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 23.433] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 23.433] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 23.433] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 23.433] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 23.433] (II) Loader magic: 0xaaaacf18c010
[ 23.433] (II) Module ABI versions:
[ 23.433] X.Org ANSI C Emulation: 0.4
[ 23.433] X.Org Video Driver: 24.1
[ 23.433] X.Org XInput driver : 24.1
[ 23.433] X.Org Server Extension : 10.0
[ 23.433] (++) using VT number 1
[ 23.435] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 23.436] (II) no primary bus or device found
[ 23.436] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 23.436] (II) "glx" will be loaded by default.
[ 23.436] (II) LoadModule: "extmod"
[ 23.436] (II) Module "extmod" already built-in
[ 23.436] (II) LoadModule: "glx"
[ 23.437] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.446] (II) Module glx: vendor="X.Org Foundation"
[ 23.446] compiled for 1.20.13, module version = 1.0.0
[ 23.446] ABI class: X.Org Server Extension, version 10.0
[ 23.446] (II) LoadModule: "nvidia"
[ 23.447] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 23.468] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 23.468] compiled for 1.6.99.901, module version = 1.0.0
[ 23.468] Module class: X.Org Video Driver
[ 23.469] (II) NVIDIA dlloader X Driver 34.0.1 Release Build (bugfix_main) (buildbrain@mobile-u64-5266-d7000) Tue Mar 15 01:01:13 PDT 2022
[ 23.469] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 23.469] (WW) Falling back to old probe method for NVIDIA
[ 23.469] (II) Loading sub module "fb"
[ 23.469] (II) LoadModule: "fb"
[ 23.469] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.470] (II) Module fb: vendor="X.Org Foundation"
[ 23.470] compiled for 1.20.13, module version = 1.0.0
[ 23.470] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.470] (II) Loading sub module "wfb"
[ 23.471] (II) LoadModule: "wfb"
[ 23.471] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 23.472] (II) Module wfb: vendor="X.Org Foundation"
[ 23.472] compiled for 1.20.13, module version = 1.0.0
[ 23.472] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.472] (II) Loading sub module "ramdac"
[ 23.472] (II) LoadModule: "ramdac"
[ 23.472] (II) Module "ramdac" already built-in
[ 23.479] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 23.479] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 23.479] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 23.479] (==) NVIDIA(0): RGB weight 888
[ 23.479] (==) NVIDIA(0): Default visual is TrueColor
[ 23.479] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 23.479] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 23.479] (**) NVIDIA(0): Option "ModeDebug"
[ 23.479] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 23.479] (**) NVIDIA(0): Enabling 2D acceleration
[ 23.479] (II) Loading sub module "glxserver_nvidia"
[ 23.479] (II) LoadModule: "glxserver_nvidia"
[ 23.479] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 23.620] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 23.620] compiled for 1.6.99.901, module version = 1.0.0
[ 23.621] Module class: X.Org Server Extension
[ 23.621] (II) NVIDIA GLX Module 34.0.1 Release Build (bugfix_main) (buildbrain@mobile-u64-5266-d7000) Tue Mar 15 00:58:36 PDT 2022
[ 23.621] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 24.010] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 24.011] (--) NVIDIA(0): DFP-0
[ 24.011] (WW) NVIDIA: No DRM device: No direct render devices found.
[ 24.011] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[ 24.011] (--) NVIDIA(0): Memory: 31390212 kBytes
[ 24.011] (--) NVIDIA(0): VideoBIOS:
[ 24.011] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.011] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 24.011] (--) NVIDIA(GPU-0): DFP-0 Name Aliases:
[ 24.011] (--) NVIDIA(GPU-0): DPY-0
[ 24.011] (--) NVIDIA(GPU-0): DP-0
[ 24.011] (--) NVIDIA(GPU-0): Connector-0
[ 24.011] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 24.011] (==) NVIDIA(0):
[ 24.011] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 24.011] (==) NVIDIA(0): will be used as the requested mode.
[ 24.011] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 24.011] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 24.013] (II) NVIDIA(0): Validated MetaModes:
[ 24.013] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 24.014] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 24.014] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 24.014] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 24.014] (II) NVIDIA: access.
[ 24.014] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 24.024] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 24.024] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 24.024] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 24.025] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 24.025] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 24.025] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 24.025] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 24.025] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 24.025] (II) NVIDIA(0): Config Options in the README.
[ 24.047] (II) NVIDIA(0): Setting mode "NULL"
[ 24.061] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 24.061] (==) NVIDIA(0): Backing store enabled
[ 24.061] (==) NVIDIA(0): Silken mouse enabled
[ 24.061] (==) NVIDIA(0): DPMS enabled
[ 24.061] (II) Loading sub module "dri2"
[ 24.061] (II) LoadModule: "dri2"
[ 24.061] (II) Module "dri2" already built-in
[ 24.061] (II) NVIDIA(0): [DRI2] Setup complete
[ 24.061] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 24.061] (II) Initializing extension Generic Event Extension
[ 24.062] (II) Initializing extension SHAPE
[ 24.062] (II) Initializing extension MIT-SHM
[ 24.062] (II) Initializing extension XInputExtension
[ 24.062] (II) Initializing extension XTEST
[ 24.062] (II) Initializing extension BIG-REQUESTS
[ 24.062] (II) Initializing extension SYNC
[ 24.062] (II) Initializing extension XKEYBOARD
[ 24.063] (II) Initializing extension XC-MISC
[ 24.063] (II) Initializing extension SECURITY
[ 24.063] (II) Initializing extension XFIXES
[ 24.063] (II) Initializing extension RENDER
[ 24.063] (II) Initializing extension RANDR
[ 24.063] (II) Initializing extension COMPOSITE
[ 24.063] (II) Initializing extension DAMAGE
[ 24.063] (II) Initializing extension MIT-SCREEN-SAVER
[ 24.063] (II) Initializing extension DOUBLE-BUFFER
[ 24.064] (II) Initializing extension RECORD
[ 24.064] (II) Initializing extension DPMS
[ 24.064] (II) Initializing extension Present
[ 24.064] (II) Initializing extension DRI3
[ 24.064] (II) Initializing extension X-Resource
[ 24.064] (II) Initializing extension XVideo
[ 24.064] (II) Initializing extension XVideo-MotionCompensation
[ 24.064] (II) Initializing extension SELinux
[ 24.064] (II) SELinux: Disabled on system
[ 24.064] (II) Initializing extension GLX
[ 24.064] (II) Indirect GLX disabled.
[ 24.065] (II) GLX: Another vendor is already registered for screen 0
[ 24.065] (II) Initializing extension XFree86-VidModeExtension
[ 24.065] (II) Initializing extension XFree86-DGA
[ 24.065] (II) Initializing extension XFree86-DRI
[ 24.065] (II) Initializing extension DRI2
[ 24.065] (II) Initializing extension NV-GLX
[ 24.065] (II) Initializing extension NV-CONTROL
[ 24.219] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 (/dev/input/event1)
[ 24.219] (II) No input driver specified, ignoring this device.
[ 24.219] (II) This device may have been added with another device file.
[ 24.220] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 (/dev/input/event2)
[ 24.220] (II) No input driver specified, ignoring this device.
[ 24.220] (II) This device may have been added with another device file.
[ 24.220] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 (/dev/input/event3)
[ 24.220] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 (/dev/input/event4)
[ 24.221] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[ 24.221] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[ 24.221] (II) LoadModule: "libinput"
[ 24.221] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 24.269] (II) Module libinput: vendor="X.Org Foundation"
[ 24.269] compiled for 1.20.4, module version = 0.29.0
[ 24.269] Module class: X.Org XInput Driver
[ 24.269] ABI class: X.Org XInput driver, version 24.1
[ 24.269] (II) Using input driver 'libinput' for 'gpio-keys'
[ 24.271] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 31 paused 0
[ 24.272] (**) gpio-keys: always reports core events
[ 24.272] (**) Option "Device" "/dev/input/event0"
[ 24.272] (**) Option "_source" "server/udev"
[ 24.326] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 24.326] (II) event0 - gpio-keys: device is a keyboard
[ 24.326] (II) event0 - gpio-keys: device removed
[ 24.327] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[ 24.327] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[ 24.327] (**) Option "xkb_model" "pc105"
[ 24.327] (**) Option "xkb_layout" "us"
[ 24.328] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 24.328] (II) event0 - gpio-keys: device is a keyboard
[ 24.874] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.874] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 24.874] (--) NVIDIA(GPU-0): DFP-0 Name Aliases:
[ 24.874] (--) NVIDIA(GPU-0): DPY-0
[ 24.874] (--) NVIDIA(GPU-0): DP-0
[ 24.874] (--) NVIDIA(GPU-0): Connector-0
[ 24.874] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
leon@orin:~$
